Cabling Tables and Diagrams for Oracle ZFS Storage Appliance Racked System ZS5-2 Capacity Configurations
The following table describes the locations and port connections for two controllers and eight disk shelves in the base cabinet, using 3-meter SAS cables. The first disk shelf is located in RU01, and each disk shelf has two IOMs.
Table 13-2 Base Cabinet: Controller and Disk Shelf Locations and Connections
| FROM | TO | ||||
RU |
CONTROLLER |
HBA PORT |
RU |
DISK SHELF |
DISK SHELF PORT |
20 |
1 |
Slot 2, Port 0 |
1 |
1 |
IOM 1, Port 2 |
17 |
0 |
Slot 6, Port 0 |
1 |
1 |
IOM 0 Port 2 |
20 |
1 |
Slot 2, Port 1 |
23 |
3 |
IOM 1, Port 2 |
17 |
0 |
Slot 6, Port 1 |
23 |
3 |
IOM 0 Port 2 |
17 |
0 |
Slot 2, Port 0 |
1, 5, 13 |
1, 2, 6 |
IOM 1, Port 0 |
20 |
1 |
Slot 6, Port 0 |
1, 5, 13 |
1, 2, 6 |
IOM 0, Port 0 |
17 |
0 |
Slot 2, Port 1 |
27, 35 |
4, 8 |
IOM 1, Port 0 |
20 |
1 |
Slot 6, Port 1 |
27, 35 |
4, 8 |
IOM 0, Port 0 |
The following table describes the locations and port connections for eight disk shelves in an expansion cabinet, using 6-meter SAS cables. The first disk shelf is located in RU01, and each disk shelf has two IOMs. The expansion Cabinet supports disk shelves 9 through 16.
Table 13-3 Expansion Cabinet: Controller and Disk Shelf Locations and Connections
| FROM | TO | ||||
RU |
CONTROLLER |
HBA PORT |
RU |
DISK SHELF |
DISK SHELF PORT |
20 |
1 |
Slot 2, Port 2 |
1 |
9 |
IOM 1, Port 2 |
17 |
0 |
Slot 6, Port 2 |
1 |
9 |
IOM 0, Port 2 |
20 |
1 |
Slot 2, Port 3 |
21 |
11 |
IOM 1, Port 2 |
17 |
0 |
Slot 6, Port 3 |
21 |
11 |
IOM 0, Port 2 |
17 |
0 |
Slot 2, Port 2 |
5, 9, 13 |
10, 13, 14 |
IOM 1, Port 0 |
20 |
1 |
Slot 6, Port 2 |
5, 9, 13 |
10, 13, 14 |
IOM 0, Port 0 |
17 |
0 |
Slot 2, Port 3 |
25, 33 |
12, 16 |
IOM 1, Port 0 |
20 |
1 |
Slot 6, Port 3 |
25, 33 |
12, 16 |
IOM 0, Port 0 |
The following diagrams illustrate how pre-racked systems are cabled, as well as how to expand your system in the future. The legend for each diagram is as follows:
A hollow circle indicates the cable connection to the top IOM (IOM 1).
A solid circle indicates the cable connection to the bottom IOM (IOM 0).
10 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
12 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
13 Oracle Storage Drive Enclosure DE3-24C Disk Shelves (Half Rack)
14 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
16 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
