Cabling Tables and Diagrams for Oracle ZFS Storage Appliance Racked System ZS7-2 MR Capacity Configurations
The following table describes the locations and port connections for two controllers and nine disk shelves in the base cabinet, using 3-meter optical SAS cables. The first disk shelf is located in RU01, and each disk shelf has two IOMs.
The following tables are for a full base rack configuration consisting of two chains, and an expansion rack configuration consisting of two chains.Table 11-10 Base Cabinet: Controller and Disk Shelf Locations and Connections
| FROM | TO | |||
RU |
CONTROLLER |
HBA PORT |
RU |
DISK SHELF PORT |
20 |
1 |
Slot 2, Port 0 |
1 |
IOM 1, Port 2 |
17 |
0 |
Slot 10, Port 0 |
1 |
IOM 0 Port 2 |
20 |
1 |
Slot 2, Port 1 |
23 |
IOM 1, Port 2 |
17 |
0 |
Slot 10, Port 1 |
23 |
IOM 0 Port 2 |
17 |
0 |
Slot 2, Port 0 |
1, 5, 13 |
IOM 1, Port 0 |
20 |
1 |
Slot 10, Port 0 |
1, 5, 13 |
IOM 0, Port 0 |
17 |
0 |
Slot 2, Port 1 |
27, 35, 39 |
IOM 1, Port 0 |
20 |
1 |
Slot 10, Port 1 |
27, 35, 39 |
IOM 0, Port 0 |
The following table describes the locations and port connections for 10 disk shelves in an expansion cabinet, using 6-meter optical SAS cables. The first disk shelf is located in RU01, and each disk shelf has two IOMs. The expansion Cabinet supports disk shelves 10 through 19.
Table 11-11 Expansion Cabinet: Controller and Disk Shelf Locations and Connections
| FROM | TO | |||
RU |
CONTROLLER |
HBA PORT |
RU |
DISK SHELF PORT |
20 |
1 |
Slot 2, Port 2 |
1 |
IOM 1, Port 2 |
17 |
0 |
Slot 10, Port 2 |
1 |
IOM 0, Port 2 |
20 |
1 |
Slot 2, Port 3 |
21 |
IOM 1, Port 2 |
17 |
0 |
Slot 10, Port 3 |
21 |
IOM 0, Port 2 |
17 |
0 |
Slot 2, Port 2 |
5, 9, 13, 17 |
IOM 1, Port 0 |
20 |
1 |
Slot 10, Port 2 |
5, 9, 13, 17 |
IOM 0, Port 0 |
17 |
0 |
Slot 2, Port 3 |
25, 33, 37 |
IOM 1, Port 0 |
20 |
1 |
Slot 10, Port 3 |
25, 33, 37 |
IOM 0, Port 0 |
The following diagrams illustrate how pre-racked systems are cabled, as well as how to expand your system in the future. The legend for each diagram is as follows:
A hollow circle indicates the cable connection to the top IOM (IOM 1).
A solid circle indicates the cable connection to the bottom IOM (IOM 0).
11 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
13 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
14 Oracle Storage Drive Enclosure DE3-24C Disk Shelves (Half Rack)
15 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
17 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
19 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
