Cabling Tables and Diagrams for Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configurations
The following table describes the locations and port connections for two controllers and nine disk shelves in the base cabinet, using 3-meter optical SAS cables. The first disk shelf is located in RU01, and each disk shelf has two IOMs.
The following tables are for configurations of two chains in the base cabinet and two chains per expansion cabinet, therefore allowing a maximum of 39 disk shelves.
Table 10-2 Base Cabinet: Controller and Disk Shelf Locations and Connections (Two Chains)
FROM | TO | |||
RU |
CONTROLLER |
HBA PORT |
RU |
DISK SHELF PORT |
20 |
1 |
Slot 2, Port 0 |
1 |
IOM 1, Port 2 |
17 |
0 |
Slot 3, Port 0 |
1 |
IOM 0, Port 2 |
20 |
1 |
Slot 9, Port 0 |
23 |
IOM 1, Port 2 |
17 |
0 |
Slot 10, Port 0 |
23 |
IOM 0, Port 2 |
17 |
0 |
Slot 2, Port 0 |
1, 5, 13 |
IOM 1, Port 0 |
20 |
1 |
Slot 3, Port 0 |
1, 5, 13 |
IOM 0, Port 0 |
17 |
0 |
Slot 9, Port 0 |
27, 35, 39 |
IOM 1, Port 0 |
20 |
1 |
Slot 10, Port 0 |
27, 35, 39 |
IOM 0, Port 0 |
The following table describes the locations and port connections for 10 disk shelves in Expansion Cabinet 1, using 6-meter optical SAS cables. The first disk shelf is located in RU01, and each disk shelf has two IOMs. Expansion Cabinet 1 supports disk shelves 10 through 19.
Table 10-3 Expansion Cabinet 1: Controller and Disk Shelf Locations and Connections (Two Chains)
FROM | TO | |||
RU |
CONTROLLER |
HBA PORT |
RU |
DISK SHELF PORT |
20 |
1 |
Slot 2, Port 1 |
1 |
IOM 1, Port 2 |
17 |
0 |
Slot 3, Port 1 |
1 |
IOM 0, Port 2 |
20 |
1 |
Slot 9, Port 1 |
21 |
IOM 1, Port 2 |
17 |
0 |
Slot 10, Port 1 |
21 |
IOM 0, Port 2 |
17 |
0 |
Slot 2, Port 1 |
5, 9, 13, 17 |
IOM 1, Port 0 |
20 |
1 |
Slot 3, Port 1 |
5, 9, 13, 17 |
IOM 0, Port 0 |
17 |
0 |
Slot 9, Port 1 |
25, 33, 37 |
IOM 1, Port 0 |
20 |
1 |
Slot 10, Port 1 |
25, 33, 37 |
IOM 0, Port 0 |
The following table describes the locations and port connections for 10 disk shelves in Expansion Cabinet 2, using 6-meter optical SAS cables. The first disk shelf is located in RU01, and each disk shelf has two IOMs. Expansion Cabinet 2 supports disk shelves 20 through 29.
Table 10-4 Expansion Cabinet 2: Controller and Disk Shelf Locations and Connections (Two Chains)
FROM | TO | |||
RU |
CONTROLLER |
HBA PORT |
RU |
DISK SHELF PORT |
20 |
1 |
Slot 2, Port 2 |
1 |
IOM 1, Port 2 |
17 |
0 |
Slot 3, Port 2 |
1 |
IOM 0, Port 2 |
20 |
1 |
Slot 9, Port 2 |
21 |
IOM 1, Port 2 |
17 |
0 |
Slot 10, Port 2 |
21 |
IOM 0, Port 2 |
17 |
0 |
Slot 2, Port 2 |
5, 9, 13, 17 |
IOM 1, Port 0 |
20 |
1 |
Slot 3, Port 2 |
5, 9, 13, 17 |
IOM 0, Port 0 |
17 |
0 |
Slot 9, Port 2 |
25, 33, 37 |
IOM 1, Port 0 |
20 |
1 |
Slot 10, Port 2 |
25, 33, 37 |
IOM 0, Port 0 |
The following table describes the locations and port connections for 10 disk shelves in Expansion Cabinet 3, using 6-meter optical SAS cables. The first disk shelf is located in RU01, and each disk shelf has two IOMs. Expansion Cabinet 2 supports disk shelves 30 through 39.
Table 10-5 Expansion Cabinet 3: Controller and Disk Shelf Locations and Connections (Two Chains)
FROM | TO | |||
RU |
CONTROLLER |
HBA PORT |
RU |
DISK SHELF PORT |
20 |
1 |
Slot 2, Port 3 |
1 |
IOM 1, Port 2 |
17 |
0 |
Slot 3, Port 3 |
1 |
IOM 0, Port 2 |
20 |
1 |
Slot 9, Port 3 |
21 |
IOM 1, Port 2 |
17 |
0 |
Slot 10, Port 3 |
21 |
IOM 0, Port 2 |
17 |
0 |
Slot 2, Port 3 |
5, 9, 13, 17 |
IOM 1, Port 0 |
20 |
1 |
Slot 3, Port 3 |
5, 9, 13, 17 |
IOM 0, Port 0 |
17 |
0 |
Slot 9, Port 3 |
25, 33, 37 |
IOM 1, Port 0 |
20 |
1 |
Slot 10, Port 3 |
25, 33, 37 |
IOM 0, Port 0 |
The following diagrams illustrate how pre-racked systems are cabled, as well as how to expand your system in the future. The legend for each diagram is as follows:
A hollow circle indicates the cable connection to the top IOM (IOM 1).
A solid circle indicates the cable connection to the bottom IOM (IOM 0).
11 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 11 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 11 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/7-2hers_11.png)
13 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 13 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 13 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/7-2hers_13.png)
14 Oracle Storage Drive Enclosure DE3-24C Disk Shelves (Expansion Cabinet 1 Half Rack)
![Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 14 Oracle Storage Drive Enclosure DE3-24C Disk Shelves (Expansion Cabinet 1 Half Rack) Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 14 Oracle Storage Drive Enclosure DE3-24C Disk Shelves (Expansion Cabinet 1 Half Rack)](img/7-2hers_14.png)
15 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 15 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 15 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/7-2hers_15.png)
17 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 17 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 17 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/7-2hers_17.png)
19 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 19 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 19 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/7-2hers_19.png)
21 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 21 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 21 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/7-2hers_21.png)
23 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 23 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 23 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/7-2hers_23.png)
24 Oracle Storage Drive Enclosure DE3-24C Disk Shelves (Expansion Cabinet 2 Half Rack)
![Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 24 Oracle Storage Drive Enclosure DE3-24C Disk Shelves (Expansion Cabinet 2 Half Rack) Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 24 Oracle Storage Drive Enclosure DE3-24C Disk Shelves (Expansion Cabinet 2 Half Rack)](img/7-2hers_24.png)
25 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 25 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 25 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/7-2hers_25.png)
27 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 27 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 27 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/7-2hers_27.png)
29 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 29 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 29 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/7-2hers_29.png)
31 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 31 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 31 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/7-2hers_31.png)
33 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 33 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 33 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/7-2hers_33.png)
34 Oracle Storage Drive Enclosure DE3-24C Disk Shelves (Expansion Cabinet 3 Half Rack)
![Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 34 Oracle Storage Drive Enclosure DE3-24C Disk Shelves (Expansion Cabinet 3 Half Rack) Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 34 Oracle Storage Drive Enclosure DE3-24C Disk Shelves (Expansion Cabinet 3 Half Rack)](img/7-2hers_34.png)
35 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 34 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 34 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/7-2hers_35.png)
37 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 34 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 34 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/7-2hers_37.png)
39 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 39 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS7-2 HE Capacity Configuration: 39 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/7-2hers_39.png)
