Maximum Disk Shelves per Controller Configuration
When determining how many disk shelves an Oracle controller configuration supports, it is important to remember that each disk shelf chain can support up to six disk shelves, and some controller configurations are limited to a specific number of total disk shelves. The following table details the number of supported disk shelf chains per HBA type.
Table 1-3 Supported Disk Shelf Chains per HBA
HBA Type | Number of Disk Shelf Chains per HBA |
SAS-3 4x4 port |
2 |
SAS-2 4x4 port |
2 |
SAS-2 2x4 port |
1 |
As of software release OS8.7.0, 4x4 port SAS-3 HBAs and 4x4 port SAS-2 HBAs can be used together in the same system. Controllers cannot simultaneously use 2x4 port SAS-2 HBAs and 4x4 port SAS-2 HBAs. Sun Disk Shelves are not supported in any system that includes a SAS-3 HBA, or a combination of SAS-3 and SAS-2 HBAs.
The following table shows the maximum number of HBAs per controller, and the maximum number of drive bays supported per controller configuration (including drive bays with filler panels). Both standalone and clustered controllers support the same maximum number of drive bays. For information on disk compatibility, see the Oracle Systems Handbook.
Table 1-4 Maximum Drive Bays per Controller Configuration
Controller | Max. Drive Bays | Max. 2x4 Port SAS-2 HBA | Max. 4x4 Port SAS-2 HBA | Max. 4x4 Port SAS-3 HBA | Guidelines |
Oracle ZFS Storage ZS9-2 high-end model |
1,152 (48 DE3-24 or 96 DE3-12C) |
NA |
NA |
4 |
Disk shelves can include 24x HDD/SSD, or combine 20x HDD/SSD plus 4x write-optimized and/or read-optimized flash accelerators (SSDs). Oracle Storage Drive Enclosure DE3-12C disk shelves can include 12x HDD, or combine 10x HDD plus 2x write-optimized and/or read-optimized flash accelerators (SSDs). Total number of chains is eight. Any combination of disk-only and write- or read-optimized shelves may be combined within the chain in any order. |
Oracle ZFS Storage ZS9-2 mid-range model |
576 (24 DE3-24 or 48 DE3-12C) |
NA |
NA |
2 |
Disk shelves can include 24x HDD/SSD, or combine 20x HDD/SSD plus 4x write-optimized and/or read-optimized flash accelerators (SSDs). Oracle Storage Drive Enclosure DE3-12C disk shelves can include 12x HDD, or combine 10x HDD plus 2x write-optimized and/or read-optimized flash accelerators (SSDs). Total number of chains is four. Any combination of disk-only and write- or read-optimized shelves may be combined within the chain in any order. |
Oracle ZFS Storage ZS7-2 high-end model |
1,152 |
NA |
NA |
4 |
Disk shelves can include 24x HDD/SSD, or combine 20x HDD/SSD plus 4x write-optimized and/or read-optimized flash accelerators (SSDs). Total number of chains is eight. Any combination of disk-only and write- or read-optimized shelves may be combined within the chain in any order. |
Oracle ZFS Storage ZS7-2 mid-range model |
576 |
NA |
NA |
2 |
Disk shelves can include 24x HDD/SSD, or combine 20x HDD/SSD plus 4x write-optimized and/or read-optimized flash accelerators (SSDs). Total number of chains is four. Any combination of disk-only and write- or read-optimized shelves may be combined within the chain in any order. |
Oracle ZFS Storage ZS5-4 |
1,152 |
NA |
4 |
4 |
Oracle ZFS Storage ZS5-2 |
384 |
NA |
2 |
2 |
Oracle ZFS Storage ZS4-4 |
864 |
NA |
4 |
4 |
Disk shelves can include 24x HDD/SSD, or combine 20x HDD/SSD plus 4x write-optimized and/or read-optimized flash accelerators (SSDs). Total number of chains is eight. Any combination of disk-only and write-optimized shelves can be combined within the chain in any order. |
Oracle ZFS Storage ZS3-4 |
864 |
NA |
4 |
NA |
Disk shelves can include 24x HDD, or combine 20x HDD plus 4x write-optimized flash accelerators (SSDs). Total number of chains is eight. Any combination of disk-only and write-optimized shelves can be combined within the chain in any order. You can also connect mixed disk shelf types (Oracle Storage Drive Enclosure DE2 and legacy Sun Disk Shelves) to the same controllers, but each chain must contain only the same disk shelf type. Directly connecting different disk shelf types is not supported. |
Oracle ZFS Storage ZS3-2 |
384 |
NA |
2 |
2 |
Disk shelves can include 24x HDD, or combine 20x HDD plus 4x write-optimized flash accelerators (SSDs). Total number of chains is four. Any combination of disk-only and write-optimized shelves can be combined within the chain in any order. You can also connect mixed disk shelf types (Oracle Storage Drive Enclosure DE2 and legacy Sun Disk Shelves) to the same controllers, but each chain must contain only the same disk shelf type. Directly connecting different disk shelf types is not supported. |
Sun ZFS Storage 7420 |
864 |
6 |
6 |
NA |
Disk shelves can include 24x HDD, or combine 20x HDD plus 4x write-optimized flash accelerators (SSDs). Total number of chains is six with 2X4 port SAS-2 HBAs, and 12 with 4X4 port SAS-2 HBAs. Any combination of disk-only and write-optimized shelves can be combined within the chain in any order. You can also connect mixed disk shelf types (Oracle Storage Drive Enclosure DE2 and legacy Sun Disk Shelves) to the same controllers, but each chain must contain only the same disk shelf type. Directly connecting different disk shelf types is not supported. |
Sun ZFS Storage 7320 |
144 |
1 |
1 |
NA |
Any combination of disk-only and write-optimized shelves may be combined within the chain in any order. The cabling configurations are unchanged. You can also connect mixed disk shelf types (Oracle Storage Drive Enclosure DE2 and legacy Sun Disk Shelves) to the same controllers, but each chain must contain only the same disk shelf type. Directly connecting different disk shelf types is not supported. |
Sun ZFS Storage 7120 |
48 |
1 |
NA |
NA |
Write-optimized SSDs are not supported in the expansion storage for the Sun ZFS Storage 7120. The disk shelves must be fully populated with 24 HDDs. You can also connect mixed disk shelf types (Oracle Storage Drive Enclosure DE2 and legacy Sun Disk Shelves) to the same controllers. |
