Installing an Oracle ZFS Storage ZS7-2 Cable Management Arm
Use the following procedure to install the cable management arm (CMA) for an Oracle ZFS Storage ZS7-2 controller. The CMA is an assembly that you can use to route the controller cables in the rack. This procedure is completed from the back of the rack.
Before You Begin
To prepare for installing the optional CMA, follow these guidelines:
Route cables in the following priority until the CMA is full:
Cluster cables
SAS active optical cables (AOCs)
SAS copper cables
Host optical cables
Host copper cables (Ethernet, InfiniBand, Fibre Channel)
Power cables
All excess cabling that cannot be fitted through the CMA should be attached to the side of the rack and properly dressed (Velcro straps, and so on). Allow enough slack (service loop) for serviceability.
Up to 16 AOC SAS cables can be routed through the CMA.
Oracle ZFS Storage ZS7-2 controllers that support a mix of AOC and copper SAS cables can route up to 12 AOC and 4 copper SAS cables through the CMA.
Do not route short SAS daisy chain cables through the CMA. Do not route an excess of cables such that the CMA clamps bow or appear structurally unfit to support the weight.
If using two clustered controllers mounted in the middle of the rack with disk shelves located above and below them, you can divide the disk shelf SAS cables between the two CMAs so that they properly route to the upper and lower disk shelves.
If uninstalling equipment and the CMA requires removal, be sure to support the CMA as you remove the connectors.
