Oracle ZFS Storage ZS3-4 Rear Panel Components
The following graphic shows the rear panel of the Oracle ZFS Storage ZS3-4 controller. Base configuration HBAs are not depicted in this illustration.
For information about PCIe cards, see Oracle ZFS Storage ZS3-4 PCIe I/O Cards in Oracle ZFS Storage Appliance Customer Service Manual, Release OS8.8.x.
1 Power supply unit 0 status LEDs OK: green Power Supply Fail: amber AC OK: green |
2 Power supply unit 0 AC inlet |
3 Power supply unit 1 status LEDs OK: green Power Supply Fail: amber AC OK: green |
4 Power supply unit 1 AC inlet |
5 System status LEDs Power: green Attention: amber Locate: white |
6 PCIe slots 0-4 |
7 Cluster card slot |
8 Network (NET) 10/100/1000 ports: NET 0-NET 3 |
9 USB 2.0 ports |
10 PCIe slots 5-9 |
11 Network management (NET MGT) 10/100 BASE-T Ethernet port |
12 Serial management (SER MGT) port |
13 DB-15 video connector |
Ethernet Ports - Oracle ZFS Storage ZS3-4 has four RJ-45 Gigabit Ethernet connectors (NET 0, NET 1, NET 2, NET 3) located on the motherboard that operate at 10/100/1000 Mbit/sec. These network interfaces must be configured before use.
Network Management Port - The network management connector (NET MGT) is an RJ-45 10/100 BASE-T Ethernet port and provides a LAN interface to the SP console.
Serial Management Port - The serial management connector (SER MGT) is an RJ-45 connector and provides a terminal connection to the SP console.
HBA Ports - The 4x4 SAS-2 HBA, installed in Oracle ZFS Storage ZS3-4, provides connectivity to external Oracle Storage Drive Enclosure DE2 and Sun Disk Shelves. The HBA logical ports are numbered 3-0, top to bottom:
