Sun ZFS Storage 7320 Rear Panel Components
Following is an illustration of the Sun ZFS Storage 7320 storage controller rear panel. The Sun 375-3609 belongs in slot 2, cannot be installed in any other slots, and a second is not offered as an option.
For information about PCIe cards, see Sun ZFS Storage 7320 Configuration Options in Oracle ZFS Storage Appliance Customer Service Manual, Release OS8.8.x.
1 Power supplies |
2 SC summary status LEDs |
3 Serial management port |
4 Network management (NET MGT) 10/100 BASE-T Ethernet port |
5 Ethernet ports |
6 PCIe slots |
The Sun ZFS Storage 7320 controller has the following ports:
Ethernet Ports - There are four RJ-45 Gigabit Ethernet ports (NET 0, NET 1, NET 2, NET 3) located on the motherboard that operate at 10/100/1000 Mbit/sec. These network interfaces must be configured before use.
Network Management Port - The network management connector (NET MGT) is an RJ-45 10/100 BASE-T Ethernet port and provides an alternate terminal interface to the SP console.
Serial Management Port - The serial management connector (SERIAL MGT) is an RJ-45 connector and is a terminal connection to the SP console.
