Suspend Problem Notification
Servicing the appliance can generate false failures. To avoid sending unwanted Service Requests (SRs), you can suspend all notifications during the period when you are performing the service.
For a description of what happens when problem notification is suspended, see Suspending Problem Notification in Oracle ZFS Storage Appliance Customer Service Manual, Release OS8.8.x.
Show Status of Notification Suspension
Use the following command to check whether problem notifications are suspended.
Example Request:
GET /api/problem/v2/suspend_notification HTTP/1.1 Host: zfs-storage.example.com:215 Accept: application/json
Example Result:
The period property shows the number of minutes remaining in
the notification suspension.
"suspend_notification": {
"href": "/api/problem/v2/suspend_notification",
"suspend_notification": "enabled",
"period": 472
