Oracle ZFS Storage ZS11-2 Front and Rear Panel Components
Oracle ZFS Storage ZS11-2 Front Panel Components - The Oracle ZFS Storage ZS11-2 controller drive slots and front panel components are shown in the following figure.
1 RFID tag |
2 System status LED: Locator (white) |
3 System status LED: Service Action Required (amber) |
4 System status LED: Power/OK (green) |
5 Power button |
6 Fan service action required (amber) |
7 Power Supply (PS) service action required (amber) |
8 Over-temperature warning (amber) |
9 Service Processor (SP) OK (green) |
10 Do Not Service indicator |
11 System disk 0 |
12 System disk 1 |
13 Filler panel |
14 Filler panel |
Oracle ZFS Storage ZS11-2 Rear Panel Components - The Oracle ZFS Storage ZS11-2 controller PCIe slots and rear panel components are shown in the following figure (Oracle ZFS Storage ZS11-2 high-end model shown).
1 Power Supply Unit (PSU) 1 |
2 PSU 1 status indicators (top to bottom):
3 PSU 1 AC power inlet (AC1) |
4 Power Supply Unit (PSU) 0 |
5 PSU 0 status indicators (top to bottom):
6 PSU 0 AC power inlet (AC0) |
7 Not available |
8 Sixth PCIe option (slot 1) |
9 Second PCIe option (slot 2) |
10 External SAS-3 HBA (slot 3) |
11 Slot 4: One of the following options:
12 Third PCIe option (slot 5) |
13 Ethernet cluster interface card (slot 6) |
14 Slot 7: One of the following options:
15 External SAS-3 HBA (slot 8) |
16 First PCIe option (slot 9) |
17 LOCATE: System locate LED |
18 SP: Reset service processor (SP) |
19 NET 0: Network (NET 0) 1GbE RJ-45 100/1000BASE-T port |
20 NET MGT: Oracle Integrated Lights Out Manager (ILOM) service processor (SP) network management (NET MGT) 1GbE RJ-45 100/1000BASE-T port |
21 USB 3.1 port |
22 System status LEDs (top to bottom):
23 SER MGT: Serial management (SER MGT) RJ-45 serial port |
Cluster Interface Card Compatibility - Oracle ZFS Storage ZS11-2 and ZS9-2 controllers employ Ethernet-based clustering via two Ethernet ports in the Oracle Quad Port 10GBASE-T Ethernet Adapter. All other controller cluster interface cards use serial-based clustering via two serial cluster links, and provide Ethernet connectivity via one link. Therefore, the Oracle ZFS Storage ZS11-2 and ZS9-2 cluster interface card is not compatible with older controller models.
For information about how to connect cables to form a cluster, see Connecting Cluster Cables in Oracle ZFS Storage Appliance Cabling Guide, Release OS8.8.x.
