Oracle ZFS Storage ZS3-4 Front and Rear Panel Components
Oracle ZFS Storage ZS3-4 Front Panel Components - The Oracle ZFS Storage ZS3-4 controller drive slots and front panel components are shown in the following figure.
1 Locator LED and button (white) |
9 USB 2.0 Connectors |
2 Service Required LED (amber) |
10 DB-15 video connector |
3 Power/OK LED (green) |
11 Boot drive 0 |
4 Power button |
12 Boot drive 1 (required) |
5 Service Processor (SP) OK LED (green) |
13 Solid state drive 2 (optional) |
6 Fan/CPU/Memory Service Required LED |
14 Solid state drive 3 (optional) |
7 Power Supply (PS) Service Required LED |
15 Solid state drive 4 (optional) |
8 Over Temperature Warning LED |
16 Solid state drive 5 (optional) |
Oracle ZFS Storage ZS3-4 Rear Panel Components - The following graphic shows the rear panel. Base configuration HBAs are not depicted in this illustration.
1 Power supply unit 0 status LEDs OK: green Power Supply Fail: amber AC OK: green |
8 Network (NET) 10/100/1000 ports: NET0-NET3 |
2 Power supply unit 0 AC inlet |
9 USB 2.0 ports |
3 Power supply unit 1 status LEDs OK: green Power Supply Fail: amber AC OK: green |
10 PCIe slots 5-9 |
4 Power supply unit 1 AC inlet |
11 Network management (NET MGT) 10/100 BASE-T Ethernet port |
5 System status LEDs Power: green Attention: amber Locate: white |
12 Serial management (SER MGT) port |
6 PCIe slots 0-4 |
13 DB-15 video connector |
7 Cluster card slot |
Cluster Interface Card Compatibility - The Oracle ZFS Storage ZS3-4 controller contains a Version 2 cluster interface card. This card cannot be replaced with a Version 3 cluster interface card.
For information about how to connect cables to form a cluster, see Connecting Cluster Cables in Oracle ZFS Storage Appliance Cabling Guide, Release OS8.8.x.
Ethernet Ports
There are four RJ-45 Gigabit Ethernet connectors (NET0, NET1, NET2, NET3) located on the Oracle ZFS Storage ZS3-4 motherboard that operate at 10/100/1000 Mbit/sec. These network interfaces must be configured before use.
