Replacing a Sun ZFS Storage 7x20 Power Supply
Sun ZFS Storage 7x20 controllers are equipped with redundant hot-swappable power supplies. If a power supply fails and you do not have a replacement, leave the failed power supply installed to ensure proper air flow. A faulted power supply is indicated by an amber-colored status LED. Use the following procedure to replace a Sun ZFS Storage 7x20 power supply.
