Replacing an Oracle ZFS Storage ZS4-4 Power Supply
Oracle ZFS Storage ZS4-4 controllers are equipped with redundant, hot-swappable power supplies. If a power supply fails and you do not have a replacement available, leave the failed power supply installed to ensure proper air flow. A faulted power supply is indicated by an amber-colored status LED. Use the following procedure to replace an Oracle ZFS Storage ZS4-4 power supply.
