The following text conventions are used in this document:
| Convention | Meaning |
boldface |
Boldface type indicates graphical user interface elements associated with an action, such as "From the File menu, select Save." Boldface also is used for terms defined in text or in the glossary. |
italic
Italic type indicates placeholder variables for which you supply particular values, such as in the parameter statement: |
Monospace type indicates code components such as user exits and scripts; the names of files and database objects; URL paths; and input and output text that appears on the screen. Uppercase monospace type is generally used to represent the names of Oracle GoldenGate parameters, commands, and user-configurable functions, as well as SQL commands and keywords. |
UPPERCASE |
Uppercase in the regular text font indicates the name of a utility unless the name is intended to be a specific case. |
Braces within syntax enclose a set of options that are separated by pipe symbols, one of which must be selected, for example: |
Brackets within syntax indicate an optional element. For example in this syntax, the |
