Why data mining? |
1. |
What is the primary motivation for applying statistical
data mining to the AERS database?
The
Empirica Signal application acts as a screening device to sort
through several million potential drug/event combinations. You
can use the application to prioritize tasks and decide what is
random noise versus associations that need further investigation.
The output is available as new questions are raised. |
2. |
How might the availability of a safety data mining
system affect the way that safety evaluators go about doing their
work?
The data mining
feature identifies and investigates potential problems in spontaneous
safety data. You can use data mining to identify potential signals,
prioritize pharmacovigilance activities, and complete evidence-based
reviews. |
Interpretation of results |
1. |
How can you determine that you are seeing more
of some AE than expected for a particular
drug when you do not know the number of prescriptions filled for
that drug (the denominator)?
The technique of
disproportionality analysis, upon which the Empirica Signal application
is based, uses all reports that mention a drug as a surrogate
for the exposure. |
2. |
Does the lack of exposure data make it impossible
to differentiate between a relatively safe drug that reports few
events and another drug that reports more events?
The method looks
at particular adverse events rather than overall reporting rate.
If prescription data is available, then overall reporting rate
is worth looking at. In most circumstances, however, the method
is less biased than a reporting rate for a particular AE. |
3. |
Does the fact that you do not know the reporting
rate for a drug and/or event (for example, what percentage of
true drug-related adverse events are actually reported to FDA)
create a problem in obtaining quantitative estimates of product-event
association?
The fact that the
reporting rate is unusually high or low for a particular drug
does not affect the results as long as the reporting rate for
that drug is uniformly high or low across all events. An
unusually high or low reporting rate for a particular event does
not affect the results as long as the reporting rate for that
event is uniformly high or low across all drugs. It is possible
that publicity about a particular problem with a drug might cause
the report rates for particular product-event combinations to
increase without corresponding increases in the overall report
rates for the drug or the event. If that happens, the corresponding
associations from disproportionality methods, such as MGPS, becomes
biased upward. |
Counts |
1. |
Where does the notion of an expected count
come from?
Observed counts
for each product-event combination of interest:
Expected counts
(E):
E(a) = ((a+b)(a+c))/(a+b+c+d) |
E(b) = ((a+b)(b+d))/(a+b+c+d) |
E(c) = ((c+d)(a+c))/(a+b+c+d) |
E(d) = ((c+d)(b+d))/(a+b+c+d) |
The quantity E(a) is the number of product-event combinations
of interest that would be expected if the event of interest appears
in reports independently of the drug of interest.
Observed count /
Expected count = Relative Reporting Ratio (N/E = RR).
Do not confuse the
use of RR as an abbreviation for Relative Reporting Ratio in the
Empirica Signal application with the concept of relative risk,
which cannot be estimated from spontaneous report frequencies.
Relative Reporting Ratio is also different from reporting rate,
which can only be estimated if you know both the number of reported
and unreported events. RR in the context of data mining of a spontaneous
report database is the ratio of the number of occurrences of the
product-event combination of interest to the expected number if
the proportion of reports with that event among reports involving
that drug were the same as the overall proportion in the database.
RR is a disproportionality measure. |
2. |
What does it mean if the expected count is less
than 1?
Based on the total
number of reports separately for the drug and event, it is expected,
statistically, that there would be less than one report of the
combination if the drug and event are not associated. The expected
count (E) for a product-event combination can be less than 1 when
either the number of reports for the drug, or the number of reports
for the AE, is small. It is common for
E to be less than 1 (sometimes even E < .001) for a rarely
reported drug combined with a rarely reported event. This causes
the ratio N/E to fluctuate wildly when N goes from 0 to 1 or more. |
3. |
How does the EBGM statistic differ
from the concept of an observed count (for a product-event combination)
divided by an expected count?
EBGM is an improved
estimate of the Relative Reporting Ratio (RR). Technically, EBGM
is defined as the exponential of expectation value of log(RR), where, in this case, the probabilities
determining expected value are not based on assuming independence
of drugs and events, but are based on statistical measures of
the dependencies exhibited in the database overall and for each
product-event combination. (In Bayesian terminology, this is called
the posterior distribution.) EBGM has the property that it is
nearly identical to N/E when the counts are moderately large,
but it shrinks towards the average value of N/E (typically ~1.0)
when N/E is unreliable, because of instability issues with small
counts.
The posterior probability
distribution also supports the calculation of lower and upper
95% confidence limits (EB05, EB95) for the relative reporting
ratio. |
EB05 and EB95 |
1. |
Explain the meaning of EB05 and EB95.
The Empirica Signal
application distinguishes between the observed value of RR = N/E
and the true value of the Relative Reporting Ratio that would
be observed if a much larger database (so large that sampling
error would be negligible) were to be drawn from the same conceptual
population of reports. This unknown quantity, sometimes abbreviated
as true RR or true N/E, can be bounded probabilistically:
EB05 is a value
such that there is about a 5% probability that the true value
of N/E lies below it.
EB95 is a value
of N/E lies above it.
The interval from
EB05 to EB95 is the 90% confidence interval. The confidence interval
is a way to describe the uncertainty in an estimate due to small
sample size (the larger the number of reports, the narrower the
confidence interval). EB05 and EB95 describe the probability distribution
for the correct answer. For example, an EB05 of 3 means that there
is a 95% chance that the true Relative Reporting Ratio is at least
3. |
2. |
What is the relationship of other safety data mining
report statistics, such as the Proportional Reporting Ratio, the
Reporting Odds Ratio, and the Information Component, to EBGM (EB05,
EB95)?
These different
disproportionality statistics all get at basically the same things,
and the values for each in any given situation are likely to be
similar, provided the sample size is large.
MGPS allows the
use of stratification for elimination of some confounding effects,
so it will typically provide lower and more realistic scores if
there is a confounding variable involved, such as age or gender,
compared to a statistic that does not involve stratification.
(Randomized trials are the only way of being sure there is no
confounding in a dataset.)
You can specify
whether or not you want to calculate Proportional Reporting Ratios
(PRR) and Reporting Odds Ratios (ROR) for a data mining run. Further,
for a data mining run that is stratified, the PRR and ROR calculations
can also be computed using stratification. |
3. |
When we apply data mining to evaluate the
significance of many different product-event combinations, are
we making a multiple comparison? Does this cause problems?
Multiple comparisons
refers to searching out the largest association (such as the largest
value of N/E among a large number of product-event pairs) in a
database and then evaluating it statistically as if that product-event
pair had been the focus of the study before looking at the data.
Bayesian shrinkage estimates shrink (modify the estimate of N/E
towards 1 based on a theoretically sound statistical method) and
the raw values of N/E so that all values of EB05 have the same
95% chance of being no larger than the true RR (Relative Reporting
Ratio), even if you search out the largest value of EB05 in the
output table. |
Threshold EB05 |
1. |
If
MGPS yields a ranked list of associations according to the EBGM
signal score, what threshold should be used for determining that
an association is an alert that warrants further investigation?
There is no absolute
threshold. An alert is an indication that there may be a signal.
Where to put the cut-off point demanding further investigation
is a business decision that is based, among other considerations,
on the nature of the data, seriousness of the AE,
available resources, and other signal discovery mechanisms. |
2. |
Why
has the threshold EB05 > 2 been recommended?
Although the threshold
EB05 > 1 might meet a typical definition of statistical significance,
there are many biases in spontaneous report data and costs to
following up each alert. Therefore, Oracle suggests you use a
somewhat higher threshold. The value 2 is a round number that
is often reasonable for relatively rare AEs.
(For a rare AE, a doubling of the number
of reports may not be a large absolute increase.)
For further discussion,
see:
Szarfman
A, Machado SG,
O'Neill RT.
Use of screening algorithms
and computer systems to efficiently signal higher-than-expected
combinations of drugs and events in the US FDA's spontaneous reports
database. Drug Saf. 2002;25(6):381-92. |
3. |
If there
is a product-event combination with an EB05 greater than my chosen
threshold (for example, EB05>2), what can I say with certainty
about the relationship between the drug and the event? Are they
definitely related? Are they causally related?
This value suggests
only that there is a statistical association between this drug
and event. The association may indicate a causal relationship
or a reverse causal relationship; that is, the AE
is an indication for the drug. It may indicate a relationship
that is already labeled, or it may indicate a relationship that
is not clinically significant for other reasons. The most frequent
explanation is that there is a third variable common to both the
drug and the event, often related to the drug’s indication (confounding
by indication).
You should conduct
further investigation, including reading the label, doing a literature
review, or, at the very least, expert evaluation of the individual
medical records leading to the series of reports, to determine
whether they seem causally related. Additional studies, such as
clinical trials or case control studies, may be warranted in some
cases. |
False positives and negatives |
1. |
What
is meant by alerts potentially being false positives?
A false positive
occurs when any signaling system, such as the EBGM or EB05 value,
exceeds a pre-set threshold (such as EB05 > 2), while, in reality,
the drug is either not related to the event or is related, but
not causally. |
2. |
What
is meant by alerts potentially being false negatives?
A false negative
did not exceed a pre-set threshold (such as EB05 > 2), while,
in reality, the drug is causally related to the event. |
3. |
How
do I set up an alerting system that gives hardly any false positives
and hardly any false negatives. Is this possible?
No. While the chances
of finding false positives or false negatives can be reduced,
you cannot eliminate them. It is possible to decrease the chances
of finding false positives or false negatives by improving the
current statistical algorithms with the addition of extra information,
such as stratification, or by improving the data collection itself.
Otherwise, any decrease in false positives is automatically accompanied
by an increase in false negatives, and vice versa.
There are two possible
reasons for a false positive: there actually is no correlation
between the drug and event, or there is a correlation, but it
is not causal. The first can be dealt with to some degree statistically
(although there will always be unresolved uncertainty for small
sample sizes). The second is not a statistical issue, and can
only be dealt with through medical knowledge.
Similarly, a false
negative can be due to a small sample or be the result of masking
from another signal. Given a hypothesis based on medical knowledge
you can reduce the masking. Oracle is experimenting with techniques
for providing clues about when such masking may be occurring.
A third reason for
either a false positive or a false negative is that you are using
the wrong threshold. |
Signaling sensitivity |
1. |
What
is meant by the sensitivity and specificity of signaling systems?
Sensitivity is defined
as the percentage of truly causal associations that are identified
by the alerting system. Low sensitivity means a high number of
false negatives. For example, in a database with counts for 10,000
product-event pairs where 1,000 of the pairs have a truly causal
relationship, if MGPS identifies 700 out of the 1,000 true associations,
the sensitivity of MGPS is 700/1000 or 70%. This calculation assumes
that the true status of every product-event pair is known. You
have to have a gold standard.
Specificity indicates
the percentage of noncausal (including nonexistent) associations
for which the system does not show an alert. Low specificity means
a high false positive rate. If MGPS declares that 3,000 of the
99,000 non-causal pairs are associated, that is a 96,000/99,000
= 97% specificity rate or a 3% false-positive rate. Again, this
calculation assumes that you know the actual negatives.
Because there is
no gold standard in most pharmacovigilance situations, you cannot
usually estimate the values of sensitivity and specificity very
well. Sometimes, the gold standard is whether a reaction is on
the label. This is problematical. It is a difficult and subjective
task to transform the language on a label into an accurate and
complete list of MedDRA terms. The label itself may be wrong or
incomplete. |
2. |
If
EB05 is large, does that mean that you can be 95% sure that there
is a true signal?
No, you can only
be 95% sure that an association this large will hold up as the
database becomes larger and larger. When EB05 > 2, almost all
the false positives are due to noncausal associations that are
reliably likely to continue as more data is collected, such as
events being related to indications for the drugs, or publicity
effects. A large EB05 rules out mere statistical fluctuation,
but not other spurious causes of the association. Thus, medical
knowledge is very important for interpretation of data mining
results. |
3. |
If
my threshold for signaling is EB05 > 2, is a product-event
combination with an EB05 < 2 definitely not a signal?
The application
distinguishes between an alert that occurs when a data mining
statistic exceeds a predetermined threshold and a signal that
might be declared upon review of all relevant information. Since
there can easily be strong evidence of causality from other information
in the absence of a data mining alert, EB05 < 2 would not rule
out the possibility of a signal. Considering the data mining results,
you would require EB95 < 1, rather than EB05 < 2, to say
that there is strong statistical evidence against a positive association
between the drug and the event. Remember, all of the values of
true RR that lie within the interval (EB05, EB95) are reasonably
compatible with the observed data. |
4. |
Are
there any guidelines regarding the smallest N (for a product-event
combination) for which you can get a meaningful signal score?
It is not necessary
to take the sample size into account. The methodology does that.
In practice, however, the built-in conservatism of the MGPS methodology,
and the choice of threshold, prevents EB05 > 2 when analyzing
AERS data unless N is at least 3. This suggests that reducing
the threshold to EB05 > 1 might be advised as part of screening
for very serious adverse events, if you want to be warned whenever
the first two reports show up significantly earlier than expected
for a new drug. |
Working with new drugs and small samples sizes |
1. |
If
a drug is new and only has a handful of reports (e.g., 50) overall
in the AERS database, can useful data mining signals be obtained?
Yes, the EB05 statistic
takes the sample size into account. |
2. |
What
about the case of an event term for which there is a small number
of reports (<100) overall?
Stratification and subsets |
1. |
What
is the difference between stratification and subsetting?
Stratification is
a way of normalizing data to eliminate confounding by some variable
or variables. You generally stratify by age group, gender, and
receipt year. The Empirica Signal application calculates
the expected count separately for each stratum, then sums those
counts and uses this total expected count for the RR and EBGM
calculations. This process can be used, for example, to deal with
confounding due to a drug being administered only to the elderly
or only to males, or to the drug being new on the market. This
process is often called adjustment for confounding variables in
the epidemiology literature. Other possible confounding variables
are not generally available in AERS data.
Subsetting is a
way of repeating the entire data mining analysis using different
subsets of the database. Subsets are typically used to study how
the strength of a product-event association evolved over time,
but can also be used to compare strength of associations for different
age or gender subsets. For each subset, the application calculates
the observed count and expected count, then uses those values
to calculate a separate RR and EBGM value for each subset. Different
subsets of the reports can be overlapping or non-overlapping,
depending on how the subset run parameters are specified. |
2. |
Is
it meaningful to compare signal scores across subsets (e.g., signal
scores for males versus signal scores for females)?
Yes. Non-overlapping
confidence intervals can alert you to the possibility of a gender
difference in response to the drug. |
Cross-drug comparisons |
1. |
Under
what circumstances might it be meaningful to compare signal scores
across different drugs?
Non-overlapping
confidence intervals can alert you to the possibility of a difference
between the safety profiles of the drugs. Alternately, if the
confidence intervals overlap a lot, the signal scores can help
corroborate evidence that there is no difference. |
2. |
What
are the advantages and disadvantages of including concomitant
medications (as well as suspect drugs) in the data mining analysis?
An advantage of
including concomitant medications is that you can eliminate the
bias from physicians who pre-determined the suspect drugs. Each
drug will be weighted equally. In addition, including both concomitant
and suspect drugs provides a larger background case set for each
drug and may reveal associations unsuspected by the reporter.
A disadvantage is
that potentially valuable judgments from physicians regarding
which drug(s) is/are suspect are
not taken into account.
More research is
needed to understand whether it is advantageous to include concomitant
drugs in an MGPS analysis. Because logistic regression analysis
is specifically designed to assess the results of polytherapy, Oracle advises always using
a data configuration that includes concomitant drugs in logistic
regressions. |
3. |
What
are the advantages and disadvantages of fully breaking apart combination
drugs into their component ingredients for purposes of data mining?
An advantage is
that the number of unique drugs in the database becomes much smaller,
and the counts of each unique ingredient are higher. It is also
easier to implement drug classification.
A disadvantage is
that ingredients are equally weighted no matter whether they were
part of combination drugs or not. |
Combining reports in a single data mining analysis |
1. |
Is
it acceptable to combine foreign and domestic reports in a single
data mining run?
Yes, although there
is only a small proportion of foreign reports (12%) in the FOI FDA AERS+SRS data.
WHO data contains approximately 50% cases reported in the US and
50% with foreign sources. It is possible to specify that report
source (US/non-US) be used as an additional stratification variable,
which may help protect from biases due to differential reporting
rates in US and non-US reports. |
2. |
Is
it acceptable to combine health professional and consumer reports
in a single data mining analysis?
It can be interesting
to compare the two to see whether there is a significant difference.
It is not clear that consumer reports are more likely to give
false positives or negatives than health professional reports,
given that the application examines disproportional reporting
as opposed to absolute numbers.
Subsetting by the
report source or occupation code of the reporter allows comparison
of values calculated for reports by consumers to those reported
by health care professionals. Also, you can use stratification
on these variables to eliminate the possibility of confounding
based on report source. |
3. |
Is
it acceptable to combine serious and non-serious adverse events
in a single data mining analysis? What if some drugs have non-serious
reports entered into AERS and others you are interested in, for
purposes of comparing signal scores, do not?
Yes, although AERS
contains mostly serious events. Including large numbers of non-serious
events probably improves the performance of the system, since
some analyses have shown that the ratios of non-serious event
reports are a reasonable surrogate for the exposure ratios. If,
for some reason, non-serious reports have been suppressed to a
much greater degree for some drugs than for others, the result
would be to bias comparisons of alerting scores across the two
sets of drugs. |
Data issues |
1. |
What
is the meaning of a drug showing a positive alerting score with
a particular event sometimes being confounded by polytherapy?
If a drug is typically
co-prescribed with another
drug that causes a particular event, then the first drug is statistically
associated with the event as well. |
2. |
What
is the impact of cloaking, where a very strong association with
one drug masks your ability to see a moderately strong association
with another drug?
If a drug has a
very strong association with a given event, this may mean that
it accounts for a relatively large proportion of the reports for
that event in the database. This would tend to raise the expected
value for this event for all drugs and, thus, mask the signal
(lower observed / expected) for another drug. |
3. |
If
a potential signal of interest may be spread across multiple MedDRA
Primary Terms (different reporters may choose to use slightly
different terminology to describe essentially the same effect),
will this reduce the ability to see the signal of interest?
Yes, this is possible,
although significant associations for several of the possible
PTs are a good indication of something real. If you suspect that
this spreading is happening, then it is possible in the Empirica
Signal application to map the suspect PTs into a new pseudo PT,
called a custom term, to look at the combined score. Alternatively,
data mining analysis can be based on MedDRA HLT or HLGT, rather
than PT. |
4. |
MGPS
essentially compares the safety profile (relative frequency of
different AEs) of each drug against
a background comparator of all drugs. Would it be better
to choose a more narrowly defined background? For example, to
understand the profile of Cerivastatin,
why not limit the background to all other statins?
Given that noise
is a surrogate for exposure, the bigger the denominator, the better.
Oracle performed an experiment to look into this; the results
showed more noise with smaller databases. To compare a drug against
others in its class to see differences, look at the EB05 scores
for each of the drugs run against the entire background. Looking
at a drug against its own class also means that it is unlikely
that you would find a previously unknown class effect. |
5. |
Are
data mining results skewed by publicity effects?
This can occur,
and it is one of the possible causes to consider when doing case
evaluation of the potential signals. |
Comparing EBGM values |
1. |
When
comparing different EBGM values, if a given drug D has an EBGM
signal score of 4.0 for event E1 and 8.0 for event E2, is it correct
to say that the risk of E2 appears to be twice as high?
No. At most, you
could say (if the confidence interval was very narrow) that the
drug had 4 times as many reports for E1 as expected and 8 times
as many reports for E2 as expected. To estimate risks you have
to know about reporting rates and exposure rates, neither of which
are estimable from spontaneous reporting data alone. |
2. |
What
about comparing EBGM values across two drugs? Suppose, for event
E, drug D1 has an EBGM score of 10 and drug D2 has an EBGM score
of 20. Is the risk of the event twice as high with drug D2 as
with drug D1?
Confidence intervals
can be used for comparisons, provided they do not overlap. In
this example, the interpretation is that the association between
D2 and the event is twice as high as the association between D1
and the event. But associations can differ for reasons unrelated
to causation. |
3. |
What
do EBGM scores < 1 signify?
A score of EBGM
< 1 indicates that the product-event combination is occurring
less frequently than expected statistically. If EBGM were <
1 and N were high, this might indicate a possible therapeutic
effect. |
