1. In the left navigation pane, click the Settings icon (
2. From the Configure System menu, select Manage Signal Configurations.
3. Select the signal configuration and, from its Row Action menu (
), select Edit Product Fields.
4. From the Row Action menu (
) of the selected product field, click Define values.
5. In the top left, click Modify Display Order.
6. To change the order in which field’s defined values display in the Define Product Field Values table and in the Add/Edit Product window, click a field and:
· Click
to move the defined value up in the list.
· Click
to move the defined value down in the list.
6. When the defined values are in the correct order, click OK.
