The Products page is organized into three panels for easy access to a variety of functions and comprehensive alert tracking statistics. You don't have to drill down through assorted menus and pages to get to the function you want to perform.
· Products By drop-down and cards: Using the Products By drop-down list, you can display the products you are tracking by product group, category, complexity, organization, or assigned reviewer. The grouping is reflected in the cards displayed below the Products By drop-down. For each grouping, a card aggregates all products in that group and displays elements of the group. You can move back and forth through the pages of cards by clicking the dots or page numbers below them. You can also scroll the cards using the left and right arrows. Selecting a card updates the right graphic details panel and filters the Products table.
· Products table: Below the cards is a table with the individual products filtered by the Products By card selection. If you select the All card, all monitored products appear. If you select a group card, only the products in that group appear. The right graphic details update to match the selection.
· Graphic details panel: To
the right of the Products By panel and the Products table is a summary
panel of the selected Products By card or the selected product. The panel
contains sections that can be expanded or collapsed. The available sections
depend on the selected item and the signal configuration. The Tracked
Alerts and Informational Alerts sections are always available. The Open
Topics section is available if your signal configuration is integrated
with Topics. The Notes section is available when you select a product.
You can show (
) or hide (
) the
sections in the graphic details panel.
