The Empirica Signal Online Help system provides information about pages, procedures for performing Empirica Signal activities, and conceptual and instructional topics. The Help system is context-sensitive; that is, if you click the Help link on an Empirica Signal page, information about that page appears.
· Help topics include underlined links that you can click to display more information.
· Help topics remain open until you close them. You can leave the Help open in the background while you are using the application.
1. In the
left navigation pane, click the Help icon
or click Help on an Empirica Signal page.
Help for the page that you are viewing appears in a new browser window.
2. To view the main help page, click Show Table of Contents at the top of the help page. The main help window includes a toolbar with the following buttons:
Button |
Description |
Contents |
Display the table of contents for the Help system. 1. In the table of contents, expand a top-level
entry in the table of contents by clicking either its name or
the closed book icon 2. Click a topic name or the topic icon |
Glossary |
Display a list of Empirica Signal terms. Click a glossary term to display a definition in the bottom left corner of the window. |
Search |
To find help topics containing a particular
word or phrase, type in the word or phrase and click the Submit
button |
Index |
Display an alphabetized list of index entries for the Help system. Select a keyword from the list, or type a keyword in the field above the index entries. To go to the first occurrence of an index entry starting with particular characters, type the characters. When you click an index entry, if only one help topic is associated with the index entry, that topic is appears. If multiple topics are associated with the entry, a popup window shows the topics and you can select one. |
Back |
Display the previous help topic. |
