A graphic that displays a flowchart that is used to determine the correct method for partitioning and indexing. There are two primary branches that are based on the answer to the query "When you upgrade to OC 4.5 do you want to partition the response table.
For the Yes response, the following descisions proceed:
when? later=>switch to other branch; now=>proceed on this branch
complete pre-upgrade steps
Partition the Responses table
upgrade indexes on Responsest
upgrade indexes on RDCMs and RDCIs
Need old index? Yes=>next step; No=>skip next step
Recreate as global indexes
Regenerate existing procedures and DX views
Release for production use
