Skip Headers
Oracle® Application Development Framework Developer's Guide For Forms/4GL Developers
10g Release 3 (10.1.3.0)
B25947-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
31.1 Introduction to the Simple CSV Data Control Adapter
This chapter shows a simple CSV data control adapter as an example of a custom data control adapter. This adapter is a simplified version of the CSV data control adapter that ships with JDeveloper.
The chapter describes what the simple CSV data control adapter does and the classes that make up the adapter.
The simple CSV data control adapter retrieves comma-separated values from a file and displays them on a page. To use the adapter in JDeveloper, you can do one of the following:
In either case, the node must map to a CSV text file, and the name of the file must have a .csv extension. You do not have to enter any metadata because the simple CSV data control adapter extracts the metadata from the node.
After you create a data control using the simple CSV adapter, the data control appears in the Data Control Palette. You can then drag and drop it onto a view page.
To simplify some details, the simple CSV adapter hardcodes the following items:
(The CSV adapter that ships with JDeveloper enables you to set these values.)
When you create a data control adapter, you create it so that it represents a source type, not a source instance. In the case of the CSV adapter, the source type is CSV files. To specify a specific data instance, for example, a particular CSV file, the user creates a data control with the help of the data control adapter and associates the instance with metadata. The metadata specifies the data for the instance. In the case of the simple CSV adapter, the metadata includes the path to a specific CSV file.
The responsibilities of a data control adapter include:
Data control adapters run within the adapter framework. The adapter framework takes care of storing the metadata, integrating the data control adapter with the ADF lifecycle, and integrating with JDeveloper during design time.
