Skip Headers
Oracle® Application Development Framework Developer's Guide For Forms/4GL Developers
10g Release 3 (10.1.3.0)
B25947-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
34.1 Introduction to Deploying ADF Applications
Deployment is the process through which application files are packaged as an archive file and transferred to the target application server. Deploying ADF applications is only slightly different from deploying standard J2EE applications.
JDeveloper supports the following deployment options:
Connection to Data Source
You need to configure in JDeveloper a data source that refers to the data source (such as a database) used in your application.
ADF Runtime Library
If you are deploying to third-party application servers (such as JBoss, WebLogic, and WebSphere), you have to install the ADF runtime library on the servers. See Section 34.12, "Installing ADF Runtime Library on Third-Party Application Servers" for details.
For Oracle Application Server, the ADF runtime libraries are already installed.
Standard Packaging
After you have all the necessary files, you package the files for the application for deployment in the standard manner. This gives you an EAR file, a WAR file, or a JAR file.
When you are ready to deploy your application, you can deploy using a variety of tools. You can deploy to most application servers from JDeveloper. You can also use tools provided by the application server vendor. Tools are described in the specific application server sections later in the chapter.
