Oracle® Application Development Framework Developer's Guide For Forms/4GL Developers
10g Release 3 (10.1.3.0) B25947-01 |
![]() Previous |
![]() Next |
Table 34-1 describes some common deployment techniques that you can use during the application development and deployment cycle. The table lists the deployment techniques in order from deploying on development environments to deploying on production environments. It is likely that in the production environment, the system administrators deploy applications using scripting tools.
Table 34-1 Deployment Techniques
