Oracle® Application Development Framework Developer's Guide For Forms/4GL Developers
10g Release 3 (10.1.3.0) B25947-01 |
![]() Previous |
![]() Next |
This section describes deployment details that are specific to JBoss.
Table 34-4 shows the supported versions of JBoss:
Before deploying applications that use ADF to JBoss, you need to install the ADF runtime libraries on JBoss. See Section 34.12, "Installing ADF Runtime Library on Third-Party Application Servers" for details.
If you are running JBoss version 4.0.3, you need to delete the following directories from the JBoss home. This is to facilitate running JSP and ADF Faces components.
deploy/jbossweb-tomcat55.sar/jsf-lib/
tmp, log, and data directories (located at the same level as the deploy directory)
After removing the directories, restart JBoss.
If you do not remove these directories, you may get the following exception during runtime:
org.apache.jasper.JasperException org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:370) org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:314) org.apache.jasper.servlet.JspServlet.service(JspServlet.java:264) javax.servlet.http.HttpServlet.service(HttpServlet.java:810) com.sun.faces.context.ExternalContextImpl.dispatch(ExternalContextImpl.java:322) com.sun.faces.application.ViewHandlerImpl.renderView(ViewHandlerImpl.java:130) com.sun.faces.lifecycle.RenderResponsePhase.execute(RenderResponsePhase.java:87) com.sun.faces.lifecycle.LifecycleImpl.phase(LifecycleImpl.java:200) com.sun.faces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:117) javax.faces.webapp.FacesServlet.service(FacesServlet.java:198) org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:81) root cause java.lang.NullPointerException javax.faces.webapp.UIComponentTag.setupResponseWriter(UIComponentTag.java:615) javax.faces.webapp.UIComponentTag.doStartTag(UIComponentTag.java:217) org.apache.myfaces.taglib.core.ViewTag.doStartTag(ViewTag.java:71) org.apache.jsp.untitled1_jsp._jspx_meth_f_view_0(org.apache.jsp.untitled1_jsp:84) org.apache.jsp.untitled1_jsp._jspService(org.apache.jsp.untitled1_jsp:60) org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:97) javax.servlet.http.HttpServlet.service(HttpServlet.java:810) org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:322) org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:314) org.apache.jasper.servlet.JspServlet.service(JspServlet.java:264) javax.servlet.http.HttpServlet.service(HttpServlet.java:810) com.sun.faces.context.ExternalContextImpl.dispatch(ExternalContextImpl.java:322) com.sun.faces.application.ViewHandlerImpl.renderView(ViewHandlerImpl.java:130) com.sun.faces.lifecycle.RenderResponsePhase.execute(RenderResponsePhase.java:87) com.sun.faces.lifecycle.LifecycleImpl.phase(LifecycleImpl.java:200) com.sun.faces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:117) javax.faces.webapp.FacesServlet.service(FacesServlet.java:198) org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:81)
To deploy applications directly from JDeveloper to JBoss, the directory where the target JBoss application server is installed must be accessible from JDeveloper. This means you need to run JDeveloper and JBoss on the same machine, or you need to map a network drive on the JDeveloper machine to the JBoss machine.
This is required because JDeveloper needs to copy the EAR file to the JBOSS_HOME\server\default\deploy directory in the JBoss installation directory.
In the Business Components Project Wizard, set the SQL Flavor to SQL92, and the Type Map to Java. This is necessary because ADF uses the emulated XA datasource implementation when the Business Components application is deployed as an EJB session bean.
For business components JSP applications, choose Deploy to EAR file from the context menu to deploy it as an EAR file. You must deploy this application to an EAR file and not a WAR file because JBoss does not add EJB references under the java:comp/env/ JNDI namespace for a WAR file. If you have set up a connection in JDeveloper to your JBoss server, you can deploy the EAR file directly to the server.
You can deploy to JBoss directly if you have set up a connection in JDeveloper to your JBoss server. When you deploy from JDeveloper, it copies the EAR file to the JBOSS_HOME\server\default\deploy directory. JBoss deploys the EAR files that it finds in that directory. You do not have to restart JBoss in order to access the application.
