Skip Headers
Oracle® Application Development Framework Developer's Guide For Forms/4GL Developers
10g Release 3 (10.1.3.0)
B25947-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
34.10 Deploying to Tomcat
This section describes deployment details that are specific to Tomcat.
34.10.1 Tomcat Versions Supported
Table 34-7 shows the supported versions of Tomcat:
Table 34-7 Support Matrix for Tomcat
Tomcat version JDK version J2EE version
5.5.9
1.5
1.4
34.10.2 Tomcat Deployment Notes
  • Before deploying applications that use ADF to Tomcat, you need to install the ADF runtime libraries on Tomcat. See Section 34.12, "Installing ADF Runtime Library on Third-Party Application Servers" for details.
  • After you install the ADF runtime libraries, rename the file TOMCAT_HOME/common/jlib/bc4jdomgnrc to bc4jdomgnrc.jar (that is, add the .jar extension to the filename). This file is required for users who are using the Java type mappings.
  • You can deploy applications to Tomcat from JDeveloper (if you have set up a connection to your Tomcat server), or you can also deploy applications using the Tomcat console.
