Skip Headers
Oracle® Application Development Framework Developer's Guide For Forms/4GL Developers
10g Release 3 (10.1.3.0)
B25947-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
22.1 Introduction to Changing ADF Faces Components
ADF Faces components delegate the functionality of the component to a component class, and the display of the component to a renderer. Renderers determine the different ways a component can be displayed on a client, or how to display the component on different clients. The component's tag used on a page determines the unique combination of a component class and a renderer. By default, all tags for ADF Faces combine the associated component class with an HTML renderer, and are part of the HTML render kit. For example, the command button and the command link components are both UICommand components; however, they use different renderers. You can create your own custom renderers; it is beyond the scope of this document to explain how to create JSF renderers or custom components.
You cannot customize the ADF Faces renderers. However, you can customize how components display using skins. By default, applications created using ADF Faces components use the Oracle skin. However, the SRDemo sample application uses a custom skin. Skins are an easy way to globally style an application. You can create your own skin to change the colors, fonts, and even the location of portions of ADF Faces components, by setting styles for components in one CSS file. You then configure the application to use the skin when displaying the application. Included with ADF Faces are HTML render kits for display on both desktop and PDA.
If you don't wish to change the entire look of an application, you can choose to change the inline styles for a component on a page. You can also programatically set styles conditionally. For example, you may want to display text red, only under certain conditions.
In addition to changing the appearance of your application, you can also internationalize your application, allowing users in different locales to view text strings in the language to which their browser is set. Many ADF Faces components include text strings, and the components handle the translation of those strings for you automatically. Any text that is part of the component displays in the language of the user's browser.
You need to translate only the text you add to the application. You can also change other locale-specific properties, such as text direction and currency code.
Read this chapter to understand:
