Oracle® Application Development Framework Developer's Guide For Forms/4GL Developers
10g Release 3 (10.1.3.0) B25947-01 |
![]() Previous |
![]() Next |
The most common way of using web services in an application developed using Oracle ADF is to create a data control for an external web service, and a usual reason for this is to add functionality that is readily available as a web service but which would be time consuming to develop with the application, or to access an application that runs on a different architecture.
Also, you can re-use components created by Oracle ADF to make them available as web services for other applications to access.
JDeveloper allows you to create a data control for an existing web service using just the WSDL for the service. You can browse to a WSDL on the local file system, locate one in a UDDI registry, or enter the WSDL URL directly.
Note: If you are working behind a firewall and you want to use a web service that is outside the firewall, you must configure the Web/Browser Proxy settings in JDeveloper. Refer to the JDeveloper online help for more information. |
To create a web service data control:
In the Application Navigator, right-click an application and choose New.
In the New Gallery, expand Business Tier in the Categories tree, and select Web Services.
In the Items list, double-click Web Service Data Control.
Follow the wizard instructions to complete creating the data control.
Alternatively, you can right-click on the WSDL node in the navigator and select the Create Data Control from the context menu.
