Skip Headers
Oracle® Database Backup and Recovery Reference
11g Release 2 (11.2)
E10643-07
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
Troubleshooting the OSB Cloud Module
This section lists potential issues that may affect the installation or the operation of the OSB Cloud Module:
Symptoms Error Messages Resolution
The S3 Backup installation cannot create the license file on Amazon S3. Time-out waiting for license file to be created. The first time you run the S3 Backup installer for a set of AWS identifiers, the installer creates a license file on Amazon S3. If there are problems preventing its creation the time-out error message is displayed in the installation output.
Contact Oracle support to resolve the issue.
