Skip Headers
Oracle® Enterprise Manager Cloud Control Basic Installation Guide
12c Release 3 (12.1.0.3)
E22624-27
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
A Overview of the EM Prerequisite Kit
This appendix describes the Enterprise Manager Prerequisite Kit utility (EM Prerequisite Kit) that the installation wizard runs every time it installs or upgrades your Enterprise Manager. In particular, this appendix covers the following:
A.1 About EM Prerequisite Kit
The EM Prerequisite Kit is a command line utility that runs repository-related prerequisite checks in your environment to ensure that you meet all the repository requirements for installing or upgrading an Enterprise Manager system.
The kit not only runs the prerequisite checks but also takes corrective actions automatically, to the extent possible, when a prerequisite check fails. The kit also takes postrequisite steps automatically to revert the corrective actions taken and ensure that the system is back to how it was before installing or upgrading the Enterprise Manager system.
The EM Prerequisite Kit is run internally by the Enterprise Manager Installation Wizard while installing or upgrading an Enterprise Manager system. In addition, you can run the kit yourself beforehand to ensure that your environment meets all the repository-related requirements.
A.2 Running the EM Prerequisite Kit
This section describes the following ways of running the EM Prerequisite Kit:
A.2.1 Running the EM Prerequisite Kit from the Software Kit (for fresh install) or from the OMS Home (for upgrade)
Although the EM Prerequisite Kit is run internally by the Enterprise Manager Installation Wizard while installing or upgrading an Enterprise Manager system, you can choose to run the kit yourself beforehand to ensure that your environment meets all the repository-related requirements. This helps in detecting and fixing repository-related issues beforehand, thus enabling a much smoother installation or upgrade experience.
This section describes how you can run the EM Prerequisite Kit from the software Kit (DVD, downloaded location) for fresh installation, or from the OMS home for upgrade.
A.2.1.1 Running the EM Prerequisite Kit from the Software Kit (for fresh install)
The EM Prerequisite Kit is available in the following location of the software kit (DVD, downloaded software):
<DVD/SW_Download_Location>/install/requisites/bin/emprereqkit
Ensure that the user running the EM Prerequisite Kit has write permission to the central inventory.
On Microsoft Windows, run emprereqkit.bat.
To run the EM Prerequisite Kit, do one of the following:
  • To view a list of repository requirements to be met without taking any corrective actions, run the EM Prerequisite Kit from the software kit (DVD, downloaded software) as SYS user with the following arguments. To learn about the other arguments that can be passed with the kit, see Section A.2.1.3.
    <DVD/SW_Download_Location>/install/requisites/bin/emprereqkit -executionType <install/upgrade/postrequisite/plugindeploy> -prerequisiteXMLLoc <prereq_xml_location> -connectString <connect_string> -dbUser SYS -dbPassword <db_password> -dbRole sysdba -reposUser SYSMAN -showPrereqs
    For example,
    <DVD>/install/requisites/bin/emprereqkit -executionType install -prerequisiteXMLLoc $ORACLE_HOME/install/requisites/list/ -connectString "(DESCRIPTION=(ADDRESS_LIST=(ADDRESS=(PROTOCOL=TCP)(HOST=example.com)(PORT=15044)))(CONNECT_DATA=(SID=sv505)))" -dbUser SYS -dbPassword mypwd -dbRole sysdba -reposUser SYSMAN -showPrereqs
  • To run the prerequisite utility and also take corrective actions to meet the repository requirements, run the EM Prerequisite Kit from the software kit (DVD, downloaded software) as SYS user with the following additional arguments. To learn about the other arguments that can be passed with the kit, see Section A.2.1.3.
    <DVD/SW_Download_Location>/install/requisites/bin/emprereqkit -executionType <install/upgrade/postrequisite/plugindeploy> -prerequisiteXMLLoc <prereq_xml_location> -connectString <connect_string> -dbUser SYS -dbPassword <db_password> -dbRole sysdba -reposUser SYSMAN -runPrerequisites -runCorrectiveActions
    For example,
    <DVD>/install/requisites/bin/emprereqkit -executionType install -prerequisiteXMLLoc $ORACLE_HOME/install/requisites/list/ -connectString "(DESCRIPTION=(ADDRESS_LIST=(ADDRESS=(PROTOCOL=TCP)(HOST=example.com)(PORT=15044)))(CONNECT_DATA=(SID=sv505)))" -dbUser SYS -dbPassword mypwd -dbRole sysdba -reposUser SYSMAN -runPrerequisites -runCorrectiveActions
A.2.1.2 Running the EM Prerequisite Kit from the OMS Home (for upgrade)
Once the Enterprise Manager system is installed or upgraded, the EM Prerequisite Kit and all the other files and directories present in the install/requisites/ directory of the software kit (DVD, downloaded software) are copied to the following location in the OMS home.
$<OMS_HOME>/install/requisites/bin/emprereqkit
The default XML files related to the prerequisite checks, which are stored in the install/requisites/list directory on the software kit (DVD, downloaded software), are current at the time of the release of the product. However, after the release of the product, if a new prerequisite check is introduced or if an existing prerequisite check is updated, then you must do one of the following:
  • Enable the Self Update functionality within Enterprise Manager Cloud Control so that the new or updated prerequisite XML files are automatically downloaded to the $<OMS_HOME>/install/requisites/list directory. To set up Self Update, see Oracle Enterprise Manager Cloud Control Administrator's Guide. To download the updates, see Oracle Enterprise Manager Cloud Control Administrator's Guide.
  • Manually download the new or updated prerequisite XML files from Oracle store to the $<OMS_HOME>/install/requisites/list directory.
  • If you have XMLs for two higher versions (for example, for 12.1.0.4.0 and 12.1.0.5.0), then you can run the prerequisite checks for even one of them by passing the -upgradeVersion argument.
    For example,
    $<OMS_HOME>/install/requisites/bin/emprereqkit -executionType upgrade -prerequisiteXMLLoc $ORACLE_HOME/install/requisites/list/ -connectString "(DESCRIPTION=(ADDRESS_LIST=(ADDRESS=(PROTOCOL=TCP)(HOST=example.com)(PORT=15044)))(CONNECT_DATA=(SID=sv505)))" -dbUser SYS -dbPassword mypwd -dbRole sysdba -reposUser SYSMAN -runPrerequisites -runCorrectiveActions -upgradeVersion 12.1.0.4.0
A.2.1.3 Supported Additional Arguments for EM Prerequisite Kit
Table A-1 describes the additional arguments you can pass while invoking the EM Prerequisite Kit:
Table A-1 Arguments Supported by EM Prerequisite Kit
Option Optional or Mandatory Value Required? Description Example
-configurationType
Optional
Yes
Enables performing prerequisite checks for different repository configurations such as small, medium, and large. If you do not pass this option, then by default, the prerequisite checks are run for medium deployment size.
$<OMS_HOME>/install/requisites/bin/emprereqkit -executionType install -prerequisiteXMLLoc <prereq_xml_location> -connectString <connect_string> -dbUser SYS -dbPassword <db_password> -dbRole sysdba -runPrerequisites -configurationType <configuration type ex: SMALL/MEDIUM/LARGE>
-executionType
Mandatory
Yes
Specify the type of execution, which can be one of the following:
  • install
  • upgrade
  • postrequisite
-prerequisiteXMLLoc
OR
-prerequisiteXMLRootDir
OR
-prerequisiteResourceLocs
Mandatory
Yes
Specify the absolute path to the location where the XML files related to the prerequisites are present. If you do not specify a location, the default location is ../list/.
If you use -prerequisiteResourceLocs, then pass a comma-separated list of prerequisite resource locations in the following format:
-prerequisiteResourceLocs "<plugin_id>=<prereq_location>, <plugin_id>=<prereq_location>, <platform>=<prereq_location>"
OR
-prerequisiteXMLRootDir $ORACLE_HOME/install/requisites/list
OR
-prerequisiteResourceLocs "oracle.sysman.db=/scratch/mwhps2/plugins/oracle.sysman.db.oms.plugin_12.1.0.4.0, platform=/scratch/mwhps2/oms"
  • -connectString <connectstring>
  • -dbHost <hostname> -dbPort <port> -dbSid <sid>
One of these options is mandatory
Yes
Specify the database details.
For example (connect string):
-connectString "(DESCRIPTION=(ADDRESS_LIST=(ADDRESS=(PROTOCOL=TCP)(HOST=example.com)(PORT=15044)))(CONNECT_DATA=(SID=dbview)))"
For example (database details):
-dbHost example.com -dbPort 15044 -dbSid dbview
-dbUser
Mandatory
Even if you do not pass this option, you will be prompted to provide a value
Yes
Specify SYS.
Also make sure you pass -reposUser SYSMAN.
-dbUser SYS
-dbUser SYS -reposUser SYSMAN
-dbPassword
Optional
Yes
Specify the password for the database user. If you do not pass this option, you will be prompted for a password.
-dbPassword welcome1
-dbRole
Mandatory
If -dbUser is SYS, then this option is mandatory. If -dbUser is any other user, then this option is optional.
Yes
Specify sysdba.
-dbRole sysdba
-prereqResultLoc
Optional
Yes
Create a directory where the results (in the form of XML files) of the prerequisite checks can be stored, and specify the path to that directory.
If you do not pass this option, the results are stored in a default location which is the current directory.
Note: If you specify details for a different database before completing all the actions, you will need to specify a different -prereqResultLoc.
-prereqResultLoc /scratch/results
-showPrereqs
Optional
No
Lists the prerequisite checks to be run.
Example using dhHost, dbPort, and dbSid is:
$ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade  -prerequisiteXMLLoc $ORACLE_HOME/install/requisites/list -dbHost  example.com -dbPort 15044 -dbSid sv902 -dbUser SYS  -dbPassword example_passwd -dbRole sysdba -showPrereqs
Example using connectString is:
$ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade  -prerequisiteXMLLoc $ORACLE_HOME/install/requisites/list -connectString  "(DESCRIPTION=(ADDRESS_LIST=(ADDRESS=(PROTOCOL=TCP)(HOST=example.com)(PORT=15044)))(CONNECT_DATA=(SID=sv902)))"  -dbUser SYS -dbPassword example_passwd -dbRole sysdba -showPrereqs
  • -showPrereqs
  • -runPrerequisites
  • -showCorrectiveActions
  • -runCorrectiveActions
  • -showPostCorrectiveActions
  • -runPostCorrectiveActions
(Important: These options must be passed in the sequence listed here. Do not change their order.)
One of these options is mandatory.
No
  • -showPrereqs lists the prerequisite checks to be run.
  • -runPrerequisites runs the prerequisite checks and lists the ones that passed and failed.
  • -showCorrectiveActions lists the corrective actions that will be taken for the failed prerequisite checks.
  • -runCorrectiveActions takes corrective actions for the failed prerequisite checks.
  • -showPostCorrectiveActions lists the post-corrective actions that will be taken for the prerequisite checks for which corrective actions were taken.
  • -runPostCorrectiveActions takes post-corrective actions for the prerequisite checks for which corrective actions were taken. In other words, reverts to values that existed before corrective actions were taken.
Important: If you passed -prereqResultLoc with -runPrerequisites, then pass -prereqResultLoc with the following options also, and specify the same custom location:
Note: Show actions must be independent, that is, they should not be combined with any other action.
  • An example for -showPrereqs:
  • An example for -runPrerequisites:
    $ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade  -prerequisiteXMLLoc $ORACLE_HOME/install/requisites/list -dbHost  example.com -dbPort 15044 -dbSid sv902 -dbUser SYS  -dbPassword example_passwd -dbRole sysdba -runPrerequisites
  • An example for -showCorrectiveActions:
    $ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade  -dbHost  example.com -dbPort 15044 -dbSid sv902 -dbUser SYS  -dbPassword example_passwd -dbRole sysdba -showCorrectiveActions
  • Example for -runCorrectiveActions:
    $ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade  -dbHost  example.com -dbPort 15044 -dbSid sv902 -dbUser SYS  -dbPassword example_passwd -dbRole sysdba -runCorrectiveActions
  • Example for -showPostCorrectiveActions:
    $ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade  -dbHost  example.com -dbPort 15044 -dbSid sv902 -dbUser SYS  -dbPassword example_passwd -dbRole sysdba -showPostCorrectiveActions
  • Example for -runPostCorrectiveActions
    $ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade  -dbHost  example.com -dbPort 15044 -dbSid sv902 -dbUser SYS  -dbPassword example_passwd -dbRole sysdba -runPostCorrectiveActions
-upgradeVersion
Optional
Yes
The default XML files related to the prerequisite checks are current at the time of the release of the product. However, after the release of the product, if a new prerequisite check is introduced or if an existing prerequisite check is updated, then you can download the new or updated XMLs either manually or using Self Update.
If you have XMLs for two higher versions (for example, for 12.1.0.4.0 and 12.1.0.5.0), then while upgrading, you can run the prerequisite checks for even one of them by passing the -upgradeVersion argument.
-logLoc
Optional
Yes
Specify the absolute path to a directory where the logs of the execution of the EM Prerequisite Kit utility can be stored. The default location is <prereqResultloc>/prerequisiteResults/log.
-logLoc /scratch/logs
-runOnlyFor
Optional
Yes
Specify the components that must be selected instead of the XML files for checking the prerequisites.
{comp1|<version1>, comp2|<version2>}]
If there are two prerequisite XML files with the same component name, then the <version*> is used to select the correct one. This option is particularly useful when running the prerequisites for installing plug-ins.
-runOnlyFor "repository|11.2.0.43"
-responseFile
Optional
Yes
Specify the absolute path to a location where the response file is available.
-responseFile /scratch/response.rsp
-contextName
Optional
Yes
Specify a unique name for this run. If you do not specify this, a default name with the format executionType_timestamp is created.
-contextName 11.2.0.1
-componentVariables
Optional
Yes
Specify the name and value of the component variable in the following format:
component_name:variable_name:variable_value
For example:
global:EM_REPOS_USER:sysman
You can pass as many component variables as you want, but ensure that you separate them by a comma.
For example:
global:EM_REPOS_USER:sysman,repository:DB_VERSION:10.2.0.5.0
-componentVariables global:EM_REPOS_USER:sysman
-logInDB
Optional
Yes
Defaults to true and stores the result XMLs in the database. If you do not want to store them in the database, pass this option and specify false.
-logInDB false
-stopExecOnFirstError
Optional
No
Stops the utility the first time it encounters an error, and does not run the remaining prerequisites.
Note: This action must be executed in combination with runPrerequisites.
$ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade -prerequisiteXMLLoc $ORACLE_HOME/install/requisites/list -dbHost example.com -dbPort 15044 -dbSid sv902 -dbUser SYS -dbPassword example_passwd -dbRole sysdba -runPrerequisites -stopExecOnFirstError
-list
Optional
Must be passed as independent options; do not combine it any other option
No
Organizes and lists the prerequisite check results (stored in the database) based on when it was run and the context.
$ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade -dbHost example.com -dbPort 15044 -dbSid sv902 -dbUser SYS -dbPassword example_passwd -dbRole sysdba -list
-export
Optional
No
Copies the prerequisite check results (XML files) from the database to an external file system.
$ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade -dbHost example.com -dbPort 15044 -dbSid sv902 -dbUser SYS -dbPassword example_passwd -dbRole sysdba -export
-purge
Optional
No
Defaults to false and retains the result XMLs in the database. If you want to delete them from the database, pass this option.
$ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade -dbHost example.com -dbPort 15044 -dbSid sv902 -dbUser SYS -dbPassword example_passwd -dbRole sysdba -purge
-help
Optional
No
This option gives details of various parameters which can be passed to EM Prerequisite Kit.
emprereqkit -help
A.2.2 Running the EM Prerequisite Kit Using EM CLI for Upgrade
This section describes how you can run the EM Prerequisite Kit using Enterprise Manager Command Line Interface (EM CLI). However, at the moment, using EM CLI you can only view the list prerequisites and run the prerequisite checks for upgrade. In particular, this section covers the following:
A.2.2.1 Viewing Prerequisite Checks Using EM CLI
To view a list of prerequisites, follow these steps:
  1. Log in to EM CLI:
    emcli login -username=sysman
  2. Synchronize EM CLI:
    emcli sync
  3. List the prerequisites:
     $<OMS_HOME>/bin/emcli list_prerequisites
    -db_user=<database_user>
    -db_password=<database_password>
    -db_role=<database_role> (needed only when dbUser is SYS)
    -repos_user=<repository_user> (needed only when dbUser is SYS)
    -prerequisite_xml_root_dir=<absolute_path_to_all_prerequisite_XMLs>
    [-prerequisite_resource_locs=<prereq_xml_location>]
    [-log_loc=<absolute_path_to_log_file_location>]
    [-upgrade_version=<EM_version_to_which_upgrade_is_being_done_eg_12.1.0.3>]
    [-configuration_type=<configuration/deployment_type_eg_MINI/SMALL/MEDIUM/LARGE>]
    For example,
    u01/software/oracle/middleware/oms/bin/emcli list_prerequisites
    -db_user=SYS
    -db_password=mypwd
    -db_role=sysdba
    -repos_user=SYSMAN
    -prerequisite_xml_root_dir=$ORACLE_HOME/install/requisites/list
    -upgrade_version=12.1.0.3.0
    -configuration_type=MEDIUM
    For any additional information, use emcli help <verb_name>.
A.2.2.2 Running Prerequisite Checks Using EM CLI
To run the prerequisite checks, follow these steps:
    emcli sync
  3. Run the prerequisites:
    $<OMS_HOME>/bin/emcli run_prerequisites
    For example,
    u01/software/oracle/middleware/oms/bin/emcli run_prerequisites
    -db_user=SYS
    -db_password=mypwd
    -db_role=sysdba
    -repos_user=SYSMAN
A.2.2.3 Description of Parameters Passed While Running the EM Prereqisite Kit Using EM CLI
  • db_user
    Enter SYS. The connection to the database is established using this user account.
  • db_password
    Enter the password for the SYS database user account.
  • db_role
    Enter sysdba.
  • repos_user
    Enter SYSMAN. The prerequisite checks will be run using this user account.
  • prerequisite_xml_root_dir
    Enter the absolute path to the requisites/list directory where the XML files are available. The XML files may be in a subdirectory within the requisites/list directory, but make sure the path you enter leads only up to the list directory. The following is the location:
  • prerequisite_resource_locs
    Enter the absolute path to the directory where the plug-in .opar files or the platform binaries, which contain the XML files for the prerequisite checks, are present. If you are entering the path to the plug-in .opar files, then make sure the you follow the format plugin_id=<plugin_home>.
  • log_loc
    Ener the absolute path to a directory where the logs of the execution of the EM Prerequisite Kit can be stored.
  • upgrade_version
    Enter the version of Enterprise Manager to which you are upgrading. For example, 12.1.0.3.0.
  • configuration_type
    Enter the deployment size—MINI, SMALL, MEDIUM, LARGE. For information on these deployment sizes, see Oracle Enterprise Manager Cloud Control Advanced Installation and Configuration Guide.
  • (Only for Upgrade to Next Enterprise Manager Cloud Control Software Release) You can download the latest version of EM Prerequisite Kit from the Self Update framework as follows:
    1. In Cloud Control, from the Setup menu, select Extensibility, and then select Self Update.
    2. On the Self Update page, download the new version of XMLs under the entity EM Deployment Prerequisite Resources Updates, if there are any available.
  • Once you download and apply these updates, you cannot rollback to the previous version of XMLs.
  • If you have XMLs for two higher versions (for example, for 12.1.0.4.0 and 12.1.0.5.0), then while upgrading, you can run the prerequisite checks for even one of them by passing the -upgrade_version argument.
    For example,
    -db_user=SYS
    -db_password=mypwd
    -db_role=sysdba
    -repos_user=SYSMAN
    -prerequisite_xml_root_dir=<OMS_HOME>/install/requisites/list/
    -upgrade_version=12.1.0.4.0
  • When you run the prerequisite checks using these revised XMLs for your next deployment, the revised XMLs are copied to the Management Repository automatically. If the downloaded revised XMLs are more recent than the ones available on the DVD of next Enterprise Manager Cloud Control software release, then the Enterprise Manager Installation Wizard uses these revised XMLs directly from the Management Repository instead of the ones available on the DVD.
  • Do not run multiple emcli run_prerequisites commands in parallel (from different EM CLI clients) to run the prerequisite checks with the downloaded revised XMLs and copy the XMLs to the Management Repository.
A.3 Viewing the Prerequisite Check Results
Every time the EM Prerequisite Kit is run, the results of the prerequisite checks run for a particular component are stored in an instance XML file. The instance XML file has the file name <component>.xml. The results are in the same format as the information stored in the prerequisite XML files. The only difference is the new column that indicates the actual result of the prerequisite check.
Table A-2 lists the instance file locations depending on how the EM Prerequisite Kit was invoked.
Table A-2 EM Prerequisite Kit Result File Location (Instance XML File)
invocation Type Instance File LocationFoot 1  Latest Instance File LocationFoot 2
Manually Invoked
<prereqResultLoc>/resultXMLs/<time-stamp>
Note: When you provide prereqResultLoc value, the result xml location is as mentioned above. Else, the result xml location is <Current Directory>/ prerequisiteResults/resultXMLs/<time-stamp>
<prereqResultLoc>/resultXMLs/LATEST/
Note: When you provide prereqResultLoc value, the result xml location is as mentioned above. Else, the result xml location is <Current Directory>/ prerequisiteResults/resultXMLs/LATEST
Automatically Invoked by the Enterprise Manager Cloud Control Installation Wizard
<MW_HOME>/.gcinstall_temp/resultXMLs/<time-stamp>
Note: When you proceed through the installation wizard pages, EM Prerequisite Kit result XMLs are created in /tmp/OraInstall<timestamp>/emprereqkit/resultXMLs/<time-stamp>.
When install begins, the /tmp/OraInstall<timestamp>/emprereqkit/resultXMLs/<time-stamp> result xmls are copied to <MWHOME>/.gcinstall_temp/resultXMLs/<time-stamp>.
<MW_HOME>/.gcinstall_temp/resultXMLs/LATEST
Note: When you proceed through the installation wizard pages, EM Prerequisite Kit result xmls are created in /tmp/OraInstall<timestamp>/ emprereqkit/p; resultXMLs/LATEST.
When install begins, the /tmp/OraInstall<timestamp>/ emprereqkit/ resultXMLs/LATEST result xmls are copied to <MW_HOME>/.gcinstall_temp/resultXMLs/LATEST
Footnote 1 Instance File Location refers to the <time-stamp> directory that is created dynamically by the utility every time the EM Prerequisite Kit is run. The instance file created here is retained until you decide to delete it.
Footnote 2 Latest Instance File Location refers to a single, standard location maintained for the latest instance file created when the EM Prerequisite Kit was last run. The instance file created here is overwritten every time the utility is run.
The <prereqResultLoc> location refers to the location you enter for the -prereqResultLoc option while invoking the utility. If this option is not passed, then by default, the directory from where you invoke the utility is considered as the base directory, and a directory titled prerequisiteResults is dynamically created in it, and then the instance file is stored in it.
A.4 Viewing Log Files
Table A-3 lists all the log files that are created every time the EM Prerequisite Kit is run.
Table A-3 EM Prerequisite Kit Log Files
Log File Name Description
emprereqkit.log
Contains information about every step taken or action performed by the kit
emprereqkit.err.log
Contains only the error and stacktrace of the exceptions occurred
emprereqkit.output
Contains information about the status (pass or fail) of all the prerequisite checks that are run. It also contains detailed information regarding each prerequisite check.For example, prerequisite name, execution status, detailed recommendation (what queries are to be executed to correct the failed prerequisite), and so on.
<functional_area>.log
Contains information about the function area-specific prerequisite checks that are run. For example, repository.log that contains repository-specific performance-related prerequisite checks that are run.
Table A-4 lists the log file locations depending on how the EM Prerequisite Kit was invoked. This table lists the locations for all the log files except for the emprereqkit.output file. For emprereqkit.output file, see the note after the table.
Table A-4 EM Prerequisite Kit Log File Locations
invocation Type Latest Log File LocationFoot 1  Log File LocationFoot 2
Manually Invoked
<logLoc>/LATEST
Note: When you provide logLoc as the value, the log location is as mentioned above. Else, it is <Current Directory>/prerequisiteResults/log/LATEST
<logLoc>/<time-stamp>
Note: When you provide logLoc as the value, the log location is as mentioned above. Else, it is <Current Directory>/ prerequisiteResults/log/<time-stamp>
<MW_HOME>/.gcinstall_temp/LATEST
Note: When you proceed through the installation wizard pages, EM Prerequisite Kit logs are created in either $OraInventory/logs/emdbprereqs/LATEST or /tmp/OraInstall<timestamp>/ emdbprereqs/LATEST
When install begins, the /tmp/OraInstall<timestamp>/emprereqkit logs are copied to <MW_HOME>/.gcinstall_temp/emprereq/LATEST
<MW_HOME>/.gcinstall_temp/<time-stamp>
Note: When you proceed through the installation wizard pages, EM Prerequisite Kit logs are created in either $OraInventory/logs/emdbprereqs/<timestamp> or /tmp/OraInstall<timestamp>/ emdbprereqs/<timestamp>
When install begins, the /tmp/OraInstall<timestamp>/ emdbprereqs/<time-stamp> logs are copied to <MW_HOME>/.gcinstall_temp/emprereq/<time-stamp>
Footnote 1 Latest Log File location refers to a single, standard location maintained for the latest log files created when the EM Prerequisite Kit was last run. The log files created here are overwritten every time the utility is run.
Footnote 2 Log File Location refers to the <time-stamp> directory that is created dynamically by the utility every time the EM Prerequisite Kit is run. The log file created here are retained until you decide to delete them.
When the EM Prerequisite Kit is run manually, the log file emprereqkit.output is stored in <prereqResultLoc>/log/<time-stamp>. The latest log file is stored in <prereqResultLoc>/log/LATEST/.
When the EM Prerequisite Kit is run internally by the Enterprise Manager Cloud Control Installation Wizard, the log file emprereqkit.output is stored in <MW_HOME>/.gcinstall_temp/log/<time-stamp>. And the latest log file is stored in <MW_HOME>/.gcinstall_temp/log/<LATEST>.
A.5 Repository Prerequisites
This section describes all the repository prerequisites that the EM Prerequisites Kit checks. This section also describes how to manually check these prerequisites.
Table A-5 Repository Prerequisites
Prerequisite Applies to Install/Upgrade Automatic Description
Basic Policy Requirements
Upgrade
No
Ensures that valid policy exists for MGMT_TARGETS.
To manually verify this, run the following query:
select 'EM_TARGET_POLICY' from dual where not exists (select policy_name from dba_policies where object_owner=SYSMAN' and pf_owner='SYSMAN' and object_name='MGMT_TARGETS') )
The query must not return any rows.
Active Jobs Requirements
Upgrade
No
Ensures that there are no background DBMS jobs currently running in the Repository Database.
select count(*) FROM dba_jobs_running run_job,gv$session sess WHERE sess.sid=run_job.sid AND sess.schemaname='SYSMAN'
If the result of the query is 0 then there are no active DBMS jobs, if result is not 0 then wait for the active jobs to complete.
Checks if GVM Performance collection job is running
Upgrade
Yes
Ensures that the GVM Performance Metric Collection job is stopped and deleted.
To manually verify if a job named GVMPERFMETRICCOLL exists, run the following query:
select count(*) from mgmt_job where job_name = 'GVMPERFMETRICCOLL' and job_type = 'UpdateGVMPerfMetric'
If it exists, then stop and delete.
Valid Reference Requirements
Upgrade
No
Ensures that all entries for execution_id in MGMT_JOB_EXECUTION either point to a valid entry in MGMT_JOB_EXEC_SUMMARY, or are NULL.
To manually verify this, run the following query. The query must not return any rows.
SELECT COUNT(1) FROM MGMT_JOB_EXECUTION e WHERE NOT EXISTS (SELECT 1 FROM MGMT_JOB_EXEC_SUMMARY s WHERE s.execution_id = e.execution_id) AND execution_id IS NOT NULL
Job Type Uniqueness Requirements
Upgrade
No
Ensures that there are no duplicate entries in MGMT_JOB_TYPE_INFO for the following set of columns: job_type, job_type_owner, major_version, minor_version1, minor_version2.
SELECT job_type FROM MGMT_JOB_TYPE_INFO GROUP BY job_type, job_type_owner, major_version, minor_version1, minor_version2 HAVING COUNT(1) > 1
SQL Plan Baseline Capture Parameter Requirements
Install, Upgrade
No
Ensures that the parameter optimizer_capture_sql_plan_baselines is set to FALSE (or default).
The SQL plan baseline capture must never be turned on for the Management Repository. Enterprise Manager heavily depends on updated CBO statistics. If stale CBO statistics exist, the SQL plan baseline capture could cause bad execution plans to be used for critical functionality.
Current Availability Index Requirements
Install, Upgrade
No
Ensures that the current availability index is renamed to the following:
  • If you are running the kit before upgrading to 12c release, then rename it to MGMT_CURRENT_AVAILABILITY_PK.
  • If you are running the kit after upgrading to 12c release, then rename it to EM_CURRENT_AVAILABILITY_PK.
My Oracle Support User Name Size Requirements
Upgrade
No
Ensures that the My Oracle Support user name is not longer than 239 characters. If it is, then you cannot upgrade.
ARU User Name Size Requirements
Upgrade
No
Ensures that the ARU user name is not longer than 239 characters. If it is, you cannot upgrade.
DBMS Package Requirements
Install, Upgrade
No
Ensures that you compile the required DBMS packages.
To manually compile the packages, log in to the database, where the Management Repository is configured, as SYS user, and run the following query to retrieve the list of invalid DBMS packages:
SELECT object_name, object_type FROM all_objects WHERE status = 'INVALID' AND object_name LIKE 'DBMS%'
If the package is invalid, run the following query:
  • For package:
    ALTER PACKAGE <PACKAGE_NAME> COMPILE
  • For package body:
    ALTER PACKAGE <PACKAGE_NAME> COMPILE BODY
If the packages do not compile successfully, contact Oracle Support.
Snapshot Log Requirements
Upgrade
No
Ensures that the snapshot logs are deleted from the tables.
Connector Configuration Table Requirements
Upgrade
No
Ensures that there is no bad data in the connector configuration table. If there is any, then run the following query to clean the table.
delete from mgmt_cntr_config where connector_guid is null or connector_type_guid is null;
commit;
Compatible Instance Parameter Requirements
Install, Upgrade
No
Ensures that the compatible instance parameter is set to the same version value as the database instance of the Management Repository. Any other value might result in unexpected problems, poor performance, or both.
Primary Key and Foreign Key Requirements
Upgrade
No
Ensures that Primary Key and Foreign keys are not disabled.
select count(*) from (select constraint_name, table_name from DBA_CONSTRAINTS where owner = 'SYSMAN' and (constraint_type = 'P' or constraint_type = 'R') and status = 'DISABLED')
If the result is not 0, then use the following query to enable the constraint:
alter table SYSMAN.<TABLE_NAME> modify constraint <CONSTRAINT_NAME> enable
If the constraints cannot be enabled for any reason, contact Oracle Support.
Enable Queue Requirements
Upgrade
No
Ensures that queues are enabled in the Repository Database.
select count(*) from dba_queues where owner = 'SYSMAN' and queue_type like '%NORMAL_QUEUE%' and (enqueue_enabled like '%NO%' OR dequeue_enabled like '%NO%')
If result is not 0, use the following query to retrieve the list of disabled queue names:
select name, queue_table from dba_queues where owner = 'SYSMAN' and upper(queue_type) not like 'EXCEPTION_QUEUE' and (upper(enqueue_enabled) NOT LIKE '%YES%' OR upper(dequeue_enabled) NOT LIKE '%YES%'))
Execute the following SQL statement to enable the queue:
begin
dbms_aqadm.start_queue('<disabled_queue_name>');
end;
If the queue cannot be started, contact Oracle Support.
Trigger Requirements
Upgrade
No
Ensures that all the triggers in the Repository Database are not disabled.
select count(*) from (select trigger_name, trigger_type, table_name from DBA_TRIGGERS where table_owner = 'SYSMAN' and status = 'DISABLED')
If result is not 0, then enable the trigger.
SYSTEM tablespace requirement
Install and Upgrade
No
Ensures that the SYSTEM tablespace has at least one datafile set to autoextensible.
select count(*) from dba_data_files where tablespace_name = 'SYSTEM' and autoextensible = 'YES'
If the result is 0, then add a new datafile with the autoextend attribute to the SYSTEM tablespace so it has at least one listed in the DBA_DATA_FILES view with autoextensible equal to 'YES'. Contact Oracle Support if there are any errors
emkey requirement
Upgrade
No
Ensures that the emkey is copied to the repository.
select COUNT(*) from sysman.mgmt_repos_time_coefficient
If the result of the query is not 1, then copy the emkey.ora file from another OMS or backup machine to the ORACLE_HOME/sysman/config directory.
Configure the emkey.ora file by running emctl config emkey -copy_to_repos -sysman_pwd <sysman_pwd>.
EM_USER_CONTEXT requirements
Upgrade
No
Ensures that EM_USER_CONTEXT is present in the repository.
select count(*) from dba_context where schema='SYSMAN' and upper(namespace)='EM_USER_CONTEXT'
If the query result is 0, check that the procedure SETEMUSERCONTEXT is valid by executing the following query:
select status from all_objects
where object_name='SETEMUSERCONTEXT' and owner='SYSMAN'
The above query must return 'VALID'. Then run:
alter session set current_schema='SYSMAN';
Create or replace context EM_USER_CONTEXT using SETEMUSERCONTEXT;
If the context cannot be created for any reason, contact Oracle Support.
Audit Master table requirement
Upgrade
No
Ensures that there are no abnormal conditions stored in the Audit Master Table.
select count(*) from sysman.mgmt_audit_master
If the query result is not 1 then, contact Oracle Support to analyze the Enterprise Manager repository before attempting to perform the patch/upgrade.
Exempt Access Policy requirement
Upgrade
No
Ensures that EXEMPT ACCESS POLICY is not granted directly to SYSMAN or indirectly grants to a role that is granted to SYSMAN.
select count(*) from dba_sys_privs where upper(privilege)='EXEMPT ACCESS POLICY' and (grantee = 'sysman' or grantee in (select distinct granted_role from dba_role_privs start with grantee='SYSMAN' connect by prior granted_role=grantee) or grantee = 'sysman')
If the result of the query is not 0, then revoke EXEMPT ACCESS POLICY from SYSMAN and the roles.
For example:
revoke exempt access policy from SYSMAN
max_enabled_roles init parameter requirement
Install and Upgrade
No
Ensures that the max_enabled_roles parameter value is set such that it contains at least 3 more than the flattened roles granted to SYS.
select 1 from DUAL where (select count(*) from v$instance where version like '9.%') = 0 or (select value from v$parameter where name like 'max_enabled_roles') > (select count(*) from dba_role_privs start with grantee='SYS' connect by prior granted_role=grantee)+2;
If the result of the query is not 1 then, increase the max_enabled_roles parameter to ensure it contains at least 3 more than the flattened roles granted to SYS.
To modify max_enabled_roles, perform the following steps:
  1. Bring down all the OMS instances.
  2. Bring down the database cleanly.
  3. Modify the max_enabled_roles parameter in the init.ora or whichever is used by the database's initialization process.
  4. Bring up the database cleanly.
  5. Verify with v$parameter to ensure the parameter value is indeed increased.
PAF execution requirements
Upgrade
No
Ensures that no PAF executions are scheduled or running.
To manually verify this, run the following query, and note down the GUID of the running or scheduled deployment procedures.
SELECT i.instance_guid FROM SYSMAN.MGMT_PAF_STATES s, SYSMAN.MGMT_PAF_INSTANCES i, SYSMAN.MGMT_PAF_PROCEDURES p WHERE p.procedure_guid = i.procedure_guid AND s.instance_guid = i.instance_guid AND s.state_type = 0 AND s.status in (0,1)
To manually stop the running or scheduled deployment procedures, run the following query, and pass the GUID you noted down from the output of the preceding command:
emcli stop_instance -instance=<instance id from sql query>
Secured Agent requirements
Upgrade
No
Ensures that all the agents are secured with latest CA.
To know the list of agents to be secured, run the following command:
emcli get_ca_info -details
Pre-upgrade console patch requirements
Upgrade
No
Ensures that pre-upgrade patch is applied.
select count(*) from all_objects where object_name ='PRE_UPGC_MASTER_INFO' and object_type='TABLE' and owner='SYSMAN'
If the result of the query is not 1, then apply pre-upgrade Console patch before upgrading.
Global Stale percentage requirements
Install and Upgrade
No
Ensures that global stale percentage is in between 5 and 25.
select count(*) from dual where dbms_stats.get_prefs('STALE_PERCENT') between 5 and 25
The query result must be 1.
Account status requirements
Upgrade
No
Ensures that SYSMAN, MGMT_VIEW and ORACLE_OCM accounts are not locked or expired.
To manually verify this, run the following queries:
select account_status from dba_users where username='SYSMAN';
select account_status from dba_users where username='MGMT_VIEW';
select account_status from dba_users where username='ORACLE_OCM';
The query result must be OPEN.
SYSMAN schema requirements
Upgrade
No
Ensures that SYSMAN schema is present for upgrade.
SELECT COUNT(*) FROM ALL_USERS WHERE USERNAME='SYSMAN'
Redo Log size requirement
Install and Upgrade
No
Ensures that the size of the log file is equal or greater than following the values defined for different installation types and deployment options:
  • Simple Installation: 300 MB or greater.
  • Advanced Installation:
    - Small: 300 MB or greater
    - Medium: 600 MB or greater
    - Large: 1000 MB or greater
select min(bytes) from v$log
Existing Database Not to Be in QUIESCE Mode
Install and Upgrade
No
Ensures that existing, certified Oracle Database is not in QUIESCE mode.
To manually verify this, run the following SQL in the database in the SYS role:
select active_state from v$instance;
The result returned must be NORMAL.
Existing Database Not to Have Database Control (only for fresh install)
Fresh Install
No
Ensures that your existing, certified Oracle Database does NOT have Database Control SYSMAN schema. If it has, that is, if your existing database is configured with Database Control, then deconfigure it.
To manually deconfigure the Database Control SYSMAN schema, follow these steps:
  1. Verify whether your database has Database Control SYSMAN schema.
    To do so, log in to the database as SYS user and run the following query:
    If the result of this query is 1, then the database has this schema, so deconfigure it.
  2. Before deconfiguring the Database Control, set the environment variable ORACLE_HOME to the Oracle home of the database, and ORACLE_SID to the SID of the database.
    For example, in bash shell, you can set them in the following way:
    export ORACLE_HOME=/u01/app/oracle/product/11.2.0/dbhome_1
    export ORACLE_SID=orcl
  3. Deconfigure the Database Control.
    To deconfigure Database Control for a standalone database, run the following command from the Oracle home of the database as the user who installed the database. If the command hangs, then restart the database and rerun the command.
    $<ORACLE_HOME>/bin/emca -deconfig dbcontrol db -repos drop -SYS_PWD <sys pasword> -SYSMAN_PWD <sysman password>
    To deconfigure Database Control for a Real Application Cluster (Oracle RAC) database, run the following command from the Oracle home of the database as the user who installed the database. If the command hangs, then restart the database and rerun the command.
    $<ORACLE_HOME>/bin/emca -deconfig dbcontrol db -repos drop -cluster -SYS_PWD <sys pasword> -SYSMAN_PWD <sysman password>
Note: If the deconfigure operation hangs, then refer to My Oracle Support note 375946.1
Existing Database Not to Have SYSMAN and SYSMAN_MDS Schema
Fresh Install
No
Ensures that your existing, certified Oracle Database does NOT have the Enterprise Manager SYSMAN schema and the Metadata (MDS) schema already configured. These schemas can exist if you had configured the database for another Enterprise Manager installation in the past, and if you are now trying to reuse the same database for a new installation.
To manually verify if the schemas are present and to drop them, run the following query:
SELECT COUNT(*) FROM ALL_USERS WHERE USERNAME IN ('SYSMAN','SYSMAN_MDS');
If the result of this query is 1, then the database has these schemas. In this case, drop the schemas and deinstall the Enterprise Manager software that had created these schemas. For instructions, see Oracle Enterprise Manager Cloud Control Advanced Installation and Configuration Guide.
Database Initialization Parameters Requirements
Install and Upgrade except db_block_size which applies only to install.
No
Ensures that you have correctly set the database initialization parameters.
For information about the database initialization parameters to be set, refer to Section A.5.1.
Fine-Grained Access Control Requirements
Upgrade
No
Ensures that the fine-grained access control option is set to TRUE in the existing, certified Oracle Database so that the Management Repository can be created.
To manually verify this, run the following command:
select value from v$option where parameter = 'Fine-grained access control';
UNDO Tablespace Size Requirements
Install and Upgrade
No
Ensures that the UNDO tablespace has a minimum space of 200 MB.
SELECT SUM(DECODE(autoextensible,'YES',200*1024*1024+1,bytes)) total
FROM dba_data_files f, dba_tablespaces s
WHERE s.contents = 'UNDO'
AND s.tablespace_name = f.tablespace_name;
Note: The result of this query is in bytes.
If the minimum space is less than 200 MB, then set it to 200 MB by running the following command:
alter database datafile <location datafile> resize 200M;
UNDO Tablespace and Temporary Tablespace Settings Requirements
Install and Upgrade
No
Ensures that the UNDO tablespace and the TEMP tablespace are autoextensible in the existing, certified Oracle Database.
select count(*) from  dba_temp_files where tablespace_name='TEMP' and AUTOEXTENSIBLE  <> 'YES';
select count(*) from dba_data_files where tablespace_name='UNDOTBS' and AUTOEXTENSIBLE <> 'YES';
If the result of the query is 0, then the tablespace is autoextensible. If the result it not 0, then refer to Oracle Database Administrator's Guide available at the following location to make the tablespace autoextensible.
http://www.oracle.com/technology/documentation/database.html
Archive Logging Settings Requirements
Install and Upgrade
No
(Recommended) Ensures that you turn on archive logging in the existing, certified Oracle Database for any environment where continuity of data is important.
To manually verify this, run the following command in the SYS role:
select log_mode from v$database;
The result returned must be ARCHIVELOG.
Tablespace-Related Hard Disk Space Requirements
Install
No
Ensures that you allocate a minimum of 200 MB hard disk space for the following tablespaces:
- Management Tablespace (mgmt.dbf)
- Configuration Data Tablespace (mgmt_ecm_depot1.dbf)
- JVM Diagnostics Data Tablespace (mgmt_deepdive.dbf)
Oracle also recommends that you keep the auto-extend feature enabled for the tablespace data files.
Note that the space requirement increases as the number of monitored targets increase, along with the input/output performance demands on the storage devices.
Existing Management Repository
Upgrade
No
Ensures that the existing, certified Oracle Database, which houses the Management Repository, already has a Management Repository configured, and that the Management Repository is compatible with Oracle Management Service 11g Release 1 (11.1).
Database Partitioning Requirements
Install and Upgrade
No
Ensures that the existing, certified Oracle Database has the Partitioning Option enabled (therefore, ensure that you install it into Oracle Database Enterprise Edition.) Installing and using the partitioning option in the Enterprise Manager repository does not add costs to customers when used solely by Enterprise Manager.
To manually verify this, connect to the database as SYSDBA and run the following query:
select value from v$option where parameter = 'Partitioning';
The result of this query should be VALUE=TRUE. No additional partitioning license is required for the database that houses the Management Repository.
Database Partition Maintenance Requirements
Upgrade
No
Checks if the partitions have been created in the database.
If the Enterprise Manager system that you are about to upgrade was shut down for a long period of time, then you will not have partitions created in the existing, certified Oracle Database, which houses the Management Repository, to load new data. Therefore, under such circumstances, to manually create the partitions, follow these steps:
  1. Log in to the database as SYSMAN and run the following command:
    execute emd_maintenance.analyze_emd_schema('SYSMAN');
    commit;
  2. Restart the OMS from its Oracle home:
    $<ORACLE_HOME>/bin/emctl start oms
Database and Listener Status Requirements
Install
No
Ensures that the existing, certified Oracle Database and its listener are running.
Valid Objects Requirements
Install, Upgrade, and Post requisite
No
Ensures that you do have only valid SYSMAN and SYS objects in the existing, certified Oracle Database.
  • To manually verify whether there are only valid SYSMAN objects, log in to the database as SYS and run the following command:
    select object_name, object_type from all_objects where owner='SYSMAN' and status <> 'VALID';
    The command must return 0 rows. However, if it returns one or more rows, then you have some invalid objects, and to turn them valid, run the following command as SYSMAN:
    @admin_recompile_invalid.sql SYSMAN
    Run this command again to ensure that all SYSMAN objects are valid. If you still have invalid SYSMAN objects, then contact Oracle Support.
    Note: The admin_recompile_invalid.sql script is in the following location of the Oracle home of the OMS:
    <ORACLE_HOME>/sysman/admin/emdrep/sql/core/latest/admin
  • To manually verify whether there are only valid SYS objects, log in to the database as SYS and run the following command:
    select object_name, object_type from all_objects where status<>'VALID' and object_name like 'DBMS%';
    The command must return 0 rows. However, if it returns one or more rows, then you have some invalid objects, and to turn them valid, recompile them by running the following command:
    alter <object type> <object name> compile;
    For example, if the object_type is mypackage and the object_name is foo, then run the following command:
    alter mypackage foo compile;
    Run this command again to ensure that all the packages are valid. If you still have invalid packages, then contact Oracle Support.
DBMS Jobs and DBMS Scheduler Status Requirements
Install and Upgrade
Yes
Ensures that you stop the DBMS Jobs and the DBMS Scheduler in the existing, certified Oracle Database.
To manually stop the jobs and the scheduler, log in to the database as SYS:
  1. Write down the value of job_queue_processes by running the following command:
    select a.instance_name as sid, b.value as jobqueue from gv$instance a, gv$parameter b where a.inst_id = b.inst_id and b.name='job_queue_processes';
  2. Stop the DBMS JOBS and DBMS scheduler by running the following command:
    execute emd_maintenance.remove_em_dbms_jobs;
    alter system set job_queue_processes=0 SID='*';
    commit;
    Note: This will allow the currently running jobs to finish, but will not allow any new jobs to be started.
  3. Ensure that there are no active jobs by running the following:
    select l.id2 job, l.sid, to_char(last_date, 'DD-MON-YYYY:HH24.MI.SS') last_date, to_char(this_date, 'DD-MON-YYYY:HH24.MI.SS') this_date, l.inst_id instance from sys.job$ j, gv$lock l where l.type = 'JQ' and j.job (+) = l.id2 order by 5, 4;
Gather Statistics Job Status Requirements
Install and Upgrade
Yes
Ensures that you stop the Gather Statistics job that is running in the existing, certified Oracle Database.
To manually stop the job, log in to the database as SYS and run the following commands:
For Oracle Database 10g (10.2.0.4) or higher:
execute dbms_scheduler.disable('GATHER_STATS_JOB',TRUE);
execute dbms_scheduler.stop_job('GATHER_STATS_JOB',TRUE);
For Oracle Database 11g (11.1.0.7) or higher:
execute dbms_auto_task_admin.disable('auto optimizer stats collection',null,null);
User Privilege Requirements
Upgrade
No
Ensures that SYSMAN and DBSNMP users have EXECUTE privileges to access the DBMS_RANDOM package in the existing, certified Oracle Database.
To manually verify whether the users have EXECUTE privileges, run the following query. When you run this query for the SYSMAN user, the <user_account_name> must be SYSMAN, and when you run it for the DBSNMP user, the <user_account_name> must be DBSNMP.
SQL> CONNECT AS SYS;
SQL> SELECT grantee, grantor, owner, table_name
FROM DBA_TAB_PRIVS
WHERE table_name = 'DBMS_RANDOM'
AND privilege = 'EXECUTE'
AND grantee IN
SELECT DISTINCT granted_role
FROM DBA_ROLE_PRIVS
START WITH grantee = '<user_account_name>'
CONNECT BY PRIOR granted_role=grantee
UNION ALL
SELECT '<user_account_name>'
FROM dual
WHERE ROWNUM = 1
UNION ALL
SELECT 'PUBLIC'
FROM dual
WHERE ROWNUM = 1
If these users do not have EXECUTE privileges, then grant them the privileges by running the following command. When you run this command for granting the privileges for the SYSMAN user, the <user_account_name> must be SYSMAN, and when you run it for the DBSNMP user, the <user_account_name> must be DBSNMP.
SQL> GRANT EXECUTE ON DBMS_RANDOM TO <user_account_name>;
Environment Variable Setting Requirements
Install
No
Ensures that the environment variable ORACLE_HOME is set to the Oracle home of the OMS.
For example, in Cshell, set it in the following way:
setenv ORACLE_HOME /home/OraHomes/oms10g
For example, in bash shell, set it in the following way:
export ORACLE_HOME= /home/OraHomes/oms10g
SUDO Configuration Requirements
Install
No
Ensures that you configure SUDO in your environment. If you are unable to do so or if you have already upgraded any of the core components (OMS or Management Agent) without configuring SUDO, then follow the workaround described in My Oracle Support note 789363.1.
User-Defined Metric Script Definition Requirement
Upgrade
No
If you have any user-defined metric scripts in the Oracle home of a Management Agent that you are upgrading, then checks if you have manually copied all those scripts to another directory outside any Oracle home, and then updated the user-defined metric definitions to reflect the new script location.
This is because, after the Management Agent is upgraded, the user-defined metric scripts are not automatically copied to the new Oracle home.
TEMP Tablespace Group requirement
Upgrade/Install
No
Ensures that there is no tablespace group name called TEMP already existing. If it does, then ensure that you rename it to a different name before installing or upgrade Enterprise Manager. You can always revert to the original name after you finish installing or upgrading.
To manually verify this, log in to the database as SYS user, and run the following query:
select count(*) group_name from DBA_TABLESPACE_GROUPS where UPPER(group_name)='TEMP'
The result of the above query should not be 0.
SYSMAN_OPSS account status requirement
Upgrade
No
Ensures that SYSMAN_OPSS account is not locked.
To manually verify this, log in to the database as SYS user and run the following query:
select account_status from dba_users where username='SYSMAN_OPSS'
SYSMAN_OPSS account status should be unlocked and unexpired
Global Name requirement
Upgrade(2-system upgrade only)
No
Ensures that Global names of old and new database are not same.
select count(1) from global_name where global_name=(select property_value from SYSMAN.pre_upgc_master_info where upper(property_name)=upper('oldReposGlobalName') and rownum=1) and exists (select 1 from ${EM_REPOS_USER}.pre_upgc_master_info where upper(property_name)=upper('upgrade_type') and upper(property_value) =upper('TWO_SYSTEM')) and exists (select 1 from SYSMAN.pre_upgc_master_info where upper(property_name)=upper('oldReposGlobalNames') and rownum=1 and upper(property_value)='TRUE')
The result of the above query should be 0, if not then change global-names in old repository to a temporary name as this repository/Enterprise Manager would cease to exist after upgrade; or change GLOBAL_NAME of new repository.
Database Edition Requirements
Install
No
Ensures that you are using Oracle Enterprise Database edition to install Enterprise Manager.
select count(1) from PRODUCT_COMPONENT_VERSION where PRODUCT like '%Oracle Database%' and instr(PRODUCT,'Enterprise Edition')>0
Existing database not to have previous Enterprise Manager's details in schema_version_registry table
Install
No
Ensures that existing database does not have previous Enterprise Manager's details in schema_version_registry table.
select count(1) from SCHEMA_VERSION_REGISTRY where comp_name in ('Authorization Policy Manager','Metadata Services','Oracle Platform Security Services')
If the result of the above query is not 0 then delete the entries from SCHEMA_VERSION_REGISTRY using the following query:
Delete from SCHEMA_VERSION_REGISTRY where comp_name in ('Authorization Policy Manager','Metadata Services','Oracle Platform Security Services');
commit;
Existing database Not to have tablespaces of previous Enterprise Manager
Install
No
Ensures that your existing, certified Oracle Database does not have tablespaces of previous Enterprise Manager.
To manually verify if the database contains such table spaces, run the following query:
select count(1) from dba_tablespaces where TABLESPACE_NAME in ('MGMT_ECM_DEPOT_TS','MGMT_TABLESPACE','MGMT_AD4J_TS')
If the result of the above query is not 0, then you can drop these table spaces otherwise new Enterprise Manager will reuse it.
Existing database not to have public synonym on the tables owned by any of the following Enterprise Manager Repository schemas: SYSMAN', SYSMAN_MDS,MGMT_VIEW,'SYSMAN_BIP,'SYSMAN_APM,BIP,SYSMAN_OPSS and SYSMAN_RO
Install
No
Ensures that your existing, certified Oracle Database does NOT have any public synonyms on the tables owned by any of the following schemas:
To manually verify whether your database has the public synonyms owned by Enterprise Manager database schemas, log in to the database as SYS user and run the following query:
select count(1) from dba_synonyms where table_owner in ('SYSMAN','SYSMAN_MDS','MGMT_VIEW','SYSMAN_BIP','SYSMAN_APM','BIP','SYSMAN_OPSS','SYSMAN_RO')
If the result of this query is not 0, then the database has these public synonyms, so drop them and deinstall the Enterprise Manager software that had created these schemas. For instructions, see Oracle Enterprise Manager Cloud Control Advanced Installation and Configuration Guide.
A.5.1 Setting Database Initialization Parameters
This section describes the following:
A.5.1.1 Setting Database Initialization Parameters for Advanced Installation
For an advanced installation, the database initialization parameters to be set for different deployment sizes (small, medium, large) are described in Oracle Enterprise Manager Cloud Control Advanced Installation and Configuration Guide.
A.5.1.2 Setting Database Initialization Parameters for Simple Installation
For a simple installation, the following are the database initialization parameters to be set:
Table A-6 Database Initialization Parameters Set for Simple Installation
Parameter Value
db_block_size
8192
processes
300
pga_aggregate_target
200000000
session_cached_cursors
200 to 500
job_queue_processes
20 for new installation, 0 for upgrade
open_cursors
300 to 400
sga_target
800000000
log_buffer
1000000
shared_pool_size
300000000
db_cache_size
TRUE
large_pool_size
TRUE
java_pool_size
TRUE
streams_pool_size
TRUE
timed_statistics
TRUE or value = TRUE
statistics_level
TRUE or value != BASIC
