Skip Headers
Oracle® Enterprise Manager Cloud Control Basic Installation Guide
12c Release 3 (12.1.0.3)
E22624-27
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
8 Installing an Enterprise Manager System
This chapter describes how you can install a new Enterprise Manager system while utilizing an existing, certified Oracle Database to store Oracle Management Repository (Management Repository).
In particular, this chapter covers the following:
This chapter is only for installing a complete Enterprise Manager system (with a Management Repository). If you want to install an additional Oracle Management Service (OMS), then see Chapter 10.
WARNING:
Do not install Enterprise Manager Cloud Control 12c on servers of SPARC series: T1000, T2000, T5xx0, and T3-*. For more information, see My Oracle Support note 1590556.1.
8.1 Introduction
This section covers the following:
For information on the releases Enterprise Manager Cloud Control has had so far, refer to Oracle Enterprise Manager Cloud Control Advanced Installation and Configuration Guide.
8.1.1 Overview of the Installation Types
You can install Enterprise Manager Cloud Control with either simple or advanced configuration. Table 8-1 describes the basic differences between the two installation types.
If you want to install Enterprise Manager Cloud Control for evaluation or demo purposes, then use the Simple installation type.
Table 8-1 Differences Between Simple and Advanced Installation
Simple Installation Advanced Installation
Meant for demo or evaluation purposes, and small deployments, and when you do not want to worry about the granular control of the installer and want to install the Enterprise Manager system quickly, with less memory, and for monitoring fewer targets in their environment
Meant for small, medium, and large deployments, and when you want to customize your installation with custom locations, directory names, and passwords.
Installs with minimal, default configuration settings and preferences that you need for a complete Enterprise Manager system. Does not offer too many options to customize your installation.
Offers custom or advanced configuration options that you can select to suit your environment and customize your installation.
Configures with less memory to monitor up to 30 targets, with 2 Oracle Management Agents (Management Agent) and 2 concurrent user sessions for handling about 10 jobs per day.
Offers an option to select the deployment size (small, medium, or large) of your choice, and depending on the deployment size you select, configures with the required memory.
The deployment size essentially indicates the number of targets you plan to monitor, the number of Management Agents you plan to have, and the number of concurrent user sessions you plan to have. The prerequisite checks are run regardless of the selection you make, but the values to be set for the various parameters checked depend on the selection you make
For more information on deployment sizes, the prerequisite checks that are run, the database parameters that are set, and how you can modify the deployment size after installation, refer to Oracle Enterprise Manager Cloud Control Advanced Installation and Configuration Guide.
Sets lower values for database parameters.
For information about the database parameters that are set, refer to Section A.5.1
Sets higher values for database parameters.
For information about the database parameters set for different deployment sizes, refer to the Oracle Enterprise Manager Cloud Control Advanced Installation and Configuration Guide.
Allows you to use a database where the Management Repository is preconfigured using the database templates offered by Oracle.
Installs four mandatory plug-ins such as Oracle Database plug-in, Oracle Fusion Middleware plug-in, Oracle My Oracle Support plug-in, and Oracle Exadata plug-in.
  • Installs four mandatory plug-ins such as Oracle Database plug-in, Oracle Fusion Middleware plug-in, Oracle My Oracle Support plug-in, and Oracle Exadata plug-in.
  • Installs any other plug-in you select in the installation wizard.
Creates a default user account weblogic for the WebLogic domain GCDomain.
Allows you to change the name of the default user account weblogic for the WebLogic domain GCDomain.
Prompts for a common password for WebLogic Server administration, Node Manager, SYSMAN user account, and Management Agent registration.
Prompts for separate, distinct passwords for WebLogic Server administration, Node Manager, SYSMAN user account, and Management Agent registration.
Creates a default OMS instance base directory (gc_inst) outside the Middleware home.
Allows you to change the name of the default OMS instance base directory (gc_inst) to a name of your choice, and creates that directory outside the Middleware home.
Creates tablespaces for management, configuration data, and JVM diagnostics data in default locations.
Allows you to change the locations of the tablespaces for management, configuration data, and JVM diagnostics data.
Installs with default ports.
Allows you to customize the ports according to your environment.
Has only a few interview screens to fill in the Enterprise Manager Cloud Control Installation Wizard.
Has many interview screens to fill in the Enterprise Manager Cloud Control Installation Wizard
8.1.2 Overview of the Installed and Configured Components
As part of a new Enterprise Manager system, the installation wizard does the following:
  • Installs the following components in the Middleware home you enter in the installation wizard:
    • Java Development Kit (JDK) 1.6.0.43.0
    • Oracle WebLogic Server 11g Release 1 (10.3.6)
    • Oracle Management Service 12c Release 3 (12.1.0.3)
    • Oracle JRF 11g Release (11.1.1.6.0), which includes oracle_common directory
    • Oracle Web Tier 11g Release (11.1.1.6.0), which includes Oracle_WT directory
    • Oracle Plug-Ins
      • Oracle Database Plug-In
      • Oracle Fusion Middleware Plug-In
      • Oracle My Oracle Support Plug-In
      • Oracle Exadata Plug-In
        • Java Development Kit (JDK) 1.6.0.43.0 and Oracle WebLogic Server 11g Release 1 (10.3.6) are installed only if you do not specify the use of existing installations. Oracle strongly recommends using the 12c installation process to install the JDK and Oracle WebLogic Server for use with Enterprise Manager 12c.
        • If you want to manually install Oracle WebLogic Server 11g Release 1 (10.3.6), then follow the guidelines outlined in Section 8.2.
        • For advanced installation, in addition to the mandatory plug-ins listed above, you can optionally install other plug-ins available in the software kit (DVD, downloaded software). The installer offers a screen where you can select the optional plug-ins and install them. However, if you want to install some plug-ins that are not available in the software kit (DVD, downloaded software), then refer to Section 8.4.2.1.
  • Installs Oracle Management Agent 12c Release 3 (12.1.0.3) in the agent base directory you specify (outside the Middleware home).
    For example, if the middleware home is /u01/app/Oracle/Middleware/, then you can specify the agent base directory as /u01/app/Oracle/agent12c.
  • Creates an Oracle WebLogic domain called GCDomain. For this WebLogic Domain, a default user account, weblogic, is used as the administrative user. In advanced installation, you can choose to change this if you want.
  • Creates a Node Manager user account called nodemanager. A Node Manager enables you to start, shut down, or restart an Oracle WebLogic Server instance remotely, and is recommended for applications with high availability requirements.
    On Microsoft Windows, a Node Manager service is NOT created. This is an expected behavior.
  • Configures an Oracle Management Service Instance Base location (gc_inst) outside the Oracle Middleware home (Middleware home), for storing all configuration details related to Oracle Management Service 12c. In advanced installation, you can choose to change this location if you want.
    For example, if the Middleware home is /u01/app/Oracle/Middleware/, then the instance base location is /u01/app/Oracle/gc_inst. You can choose to change this, if you want, in the installer. However, you can change it for only advanced installation and not for simple installation.
  • Configures Oracle Management Repository in the existing, certified Oracle Database. If the database instance is created using the database template offered by Oracle, then this step is skipped.
    The existing, certified Oracle Database must be one of the certified databases listed in the Enterprise Manager certification matrix available on My Oracle Support, or a database instance created with a preconfigured Oracle Management Repository (Management Repository) using the database templates offered by Oracle.
    To access the Enterprise Manager certification matrix, follow the steps outlined in Appendix E.
    For information about creating a database instance with a preconfigured Management Repository using the database templates offered by Oracle, refer to Appendix D.
    The database can be on a local or remote host, and if it is on a remote host, it must be monitored by Oracle Management Agent. However, Oracle Real Application Clusters (Oracle RAC) databases must only be on a shared disk.
  • Runs the following configuration assistants to configure the installed components for simple as well as advanced installation:
    • Plugins Prerequisites Check
    • Repository Configuration
      If you use a database instance that was created with a preconfigured Management Repository using the database templates offered by Oracle, then Repository Out-of-Box Configuration is run instead of Repository Configuration.
    • MDS Schema Configuration
      If you use a database instance that was created with a preconfigured Management Repository using the database templates offered by Oracle, then MDA Schema Configuration is not run.
    • OMS Configuration
    • Plugins Deployment and Configuration
    • Start Oracle Management Service
    • Oracle Configuration Manager Repeater Configuration
    • Agent Configuration Assistant
8.1.3 Overview of the Directory Structures
This section describes the following:
8.1.3.1 Overview of the Directory Structure for OMS Installation
By default, the following are the contents of the Middleware home for this type of installation:
<middleware_home>
    |_____wlserver_10.3
    |_____jdk16
    |_____oms
    |_____plugins
    |_____Oracle_WT
    |_____oracle_common
    |_____utils
    |_____logs
    |_____modules
    |_____user_projects
    |_____ocm.rsp
    |_____registry.dat
    |_____domain-registry.xml
    |_____patch_wls1036
    |_____registry.xml
8.1.3.2 Overview of the Directory Structure for Management Agent Installation (Central Agent)
By default, the following are the contents of the agent base directory for the central agent (Management Agent installed with the OMS):
<agent_base_directory>
    |_____core
         |_____12.1.0.3.0
    |_____plugins
    |_____agent_inst
    |_____sbin
    |_____agentimage.properties
8.2 Before You Begin
Before you begin, keep these points in mind:
  • You must ensure that you have the latest Enterprise Manager Cloud Control software.
    For information about downloading the latest software, refer to the Oracle Enterprise Manager Cloud Control Advanced Installation and Configuration Guide.
  • Ensure that there are no white spaces in the name of the directory where you download and run the Enterprise Manager Cloud Control software from. For example, do not download and run the software from a directory titled EM Software because there is a white space between the two words of the directory name.
  • You can install Enterprise Manager Cloud Control using the installation wizard only on a single host, that is, locally on the server where the wizard is invoked. You cannot install on multiple or remote hosts.
  • Oracle Management Service 12c can communicate only with the following versions of Oracle Management Agent 12c:
    Table 8-2 Compatibility Between OMS and Management Agents Across 12c Releases
    Oracle Management Agent 12c Release 1 (12.1.0.1) + Bundle Patch 1
    (Refers to agents and their plug-ins patched or upgraded to, or installed with Bundle Patch 1)
    Oracle Management Agent 12c Release 2 (12.1.0.2)
    Oracle Management Service 12c Release 1 (12.1.0.1) + Bundle Patch 1
    Yes
    (includes Management Agents with and without Bundle Patch 1)
    No
    No
    Oracle Management Service 12c Release 2 (12.1.0.2)
    Yes
    Yes
    No
    Yes
    (Only Management Agents released in January 2012 [with Bundle Patch 1])
    Yes
    Yes
  • Do not install on a symlink. Installing in such a location may impact life cycle operations such as patching and scaling out.
  • You must not set the ORACLE_HOME and ORACLE_SID environment variables. You must ensure that the Oracle directories do NOT appear in the PATH.
  • You must set the DISPLAY environment variable.
    • In bash terminal, run the following command:
      export DISPLAY=<hostname>:<vnc port>.0
      For example, export DISPLAY=example.com:1.0
    • In other terminals, run the following command:
      setenv DISPLAY <hostname>:1.0
      For example, setenv DISPLAY example.com:1.0
  • The Enterprise Manager Cloud Control Installation Wizard installs Java Development Kit (JDK) 1.6.0.43.0 and Oracle WebLogic Server 11g Release 1 (10.3.6) only if you do not specify the use of existing installations. Oracle strongly recommends using the 12c installation process to install the JDK and Oracle WebLogic Server for use with Enterprise Manager 12c.
  • If Oracle WebLogic Server 11g Release 1 (10.3.6) does not exist and if you want to manually install it, then ensure that you install it using JDK 1.6.0.43.0 (64-bit version for 64-bit platforms and 32-bit version for 32-bit platforms).
    • Download JDK 1.6.0.43.0 for your platform from the platform vendor's Web site.
      For example, download SUN JDK 1.6.0.43.0 for Linux platforms from the following Oracle Web site URL:
      http://www.oracle.com/technetwork/java/javase/downloads/index.html
      Similarly, download the JDK for other platforms from other vendors' trusted Web sites.
    • If you already have JDK, then verify its version by navigating to the <JDK_Location>/bin directory and running the following command:
      "./java -fullversion"
      To verify whether it is a 32-bit or a 64-bit JDK, run the following command:
      "file *"
    • JROCKIT is not supported.
    • If you want to manually install Oracle WebLogic Server 11g Release 1 (10.3.6) on Linux 64-bit platforms, first install the 64-bit JDK for that platform, and then download and use the wls1036_generic.jar file to install Oracle WebLogic Server.
      For example,
      <JDK home>/bin/java -d64 -jar <absolute_path _to_wls1036_generic.jar>
    • If you want to manually install Oracle WebLogic Server 11g Release 1 (10.3.6) on Linux 32-bit platforms, then download and use either the wls1036_linux32.bin file or the wls1036_generic.jar file.
      For example,
      <JDK home>/bin/java -jar <absolute_path _to_wls1036_generic.jar>
    • You must procure the Oracle WebLogic Server 11g Release 1 (10.3.6) software and install it following the instructions outlined in the Oracle® Fusion Middleware Installation Guide for Oracle WebLogic Server. Ensure that it is a default installation. The guide is available in the Fusion Middleware documentation library available at:
      http://www.oracle.com/technetwork/middleware/weblogic/documentation/index.html
    • You must ensure that the Oracle WebLogic Server installation is a typical installation, and even if you choose to perform a custom installation, ensure that components chosen for custom installation are the same as the ones associated with a typical installation.
    • You must ensure that the user installing the Oracle WebLogic Server is the same as the one installing Enterprise Manager Cloud Control.
    • After installing Oracle WebLogic Server, make sure you apply patch 14482558 and patch 13349651 on it. For instructions, access the following URL:
      http://docs.oracle.com/cd/E14759_01/doc.32/e14143/intro.htm#CHDCAJFC
      For more information on Oracle WebLogic Server downloads and demos, access the following URL:
      http://www.oracle.com/technology/products/weblogic/index.html
  • You must ensure that the Oracle WebLogic Server 11g Release 1 (10.3.6) installed by the Enterprise Manager Cloud Control Installation Wizard or by you is dedicated for Enterprise Manager Cloud Control. You must not have any other Oracle Fusion Middleware product installed in that Middleware home.
    Enterprise Manager Cloud Control cannot coexist with any Oracle Fusion Middleware product in the same Middleware home because the ORACLE_COMMON property is used by both the products.
  • You can optionally use the database templates offered by Oracle to create a database instance with a preconfigured Management Repository. To do so, refer to Appendix D. You can use such a database instance for simple as well as advanced installation.
    However, note that the database templates are essentially designed for simple installation, although they can be used for advanced installation. Therefore, while performing an advanced installation (possibly with small, medium, or large deployment size selection), when you provide the details of such a database, you will be prompted that the database parameters need to be modified to suit the deployment size you selected. You can confirm the message to proceed further. The installation wizard will automatically set the database parameters to the required values.
  • If you are creating the OMS instance base directory (gc_inst) on an NFS-mounted drive, then after you install, move the lock files from the NFS-mounted drive to a local file system location. Modify the lock file location in the httpd.conf file to map to a location on a local file system. For instructions, refer to Section 8.5.
  • Enterprise Manager is not affected when you enable or disable features such as XML DB on the Oracle Database in which you plan to configure the Management Repository. Therefore, you can enable or disable any feature in the database because Enterprise Manager does not rely on them.
  • If you want to optionally follow the configuration guidelines for deploying the Management Repository so that your management data is secure, reliable, and always available, refer to the Oracle Enterprise Manager Cloud Control Administrator's Guide.
  • In addition to the mandatory plug-ins, you can optionally install other plug-ins available in the software kit (DVD, downloaded software). The installer offers a screen where you can select the optional plug-ins and install them. However, if you want to install some plug-ins that are not available in the software kit (DVD, downloaded software), then refer to Section 8.4.2.1.
  • Oracle offers bug fixes for a product based on the Oracle Lifetime Support Policy. When the license period expires for a particular product, the support for bug fixes offered by Oracle also ends. For more information, see the Oracle Lifetime Support Policy available at:
    http://www.oracle.com/support/library/brochure/lifetime-support-technology.pdf
    When determining supportability and certification combinations for an Enterprise Manager Cloud Control installation, you must consider Enterprise Manager Cloud Control's framework components as well as the targets monitored by Enterprise Manager Cloud Control. Oracle recommends keeping your Cloud Control components and targets updated to the latest certified versions in order to receive code fixes without having to purchase an Extended Support license.
  • You can find the OMS and Management Agent entries in the /etc/oragchomelist file for all UNIX platforms except HPUNIX, HPia64, Solaris Sparc.
    On HPUNIX, HPia64, Solaris Sparc platforms, the entries are present in /var/opt/oracle/oragchomelist.
  • As a prerequisite, you must have an existing Oracle Database to configure the Management Repository. This database can also have the Automatic Memory Management (AMM) feature enabled.
  • The locale-specific data is stored in the <OMS_Oracle_Home>/nls/data directory. Oracle strongly recommends that you either set the environment variable ORA_NLS10 to <OMS_Oracle_Home>/nls/data or do not set at all.
  • If you install the OMS and the Oracle Database, which houses the Management Repository, on the same host, then when you reboot the host, the OMS and the Management Agent installed with it will not automatically start up. You will have to manually start them.
  • Enforcing option is supported for Security-Enhanced Linux (SELinux).
8.3 Prerequisites
Table 8-3 lists the prerequisites you must meet before installing Enterprise Manager Cloud Control.
Table 8-3 Prerequisites for Installing Enterprise Manager Cloud Control
Requirement Description
Hardware Requirements
Ensure that you meet the hard disk space and physical memory requirements as described in Chapter 4.
Operating System Requirements
Ensure that you install Enterprise Manager Cloud Control only on certified operating systems as mentioned in the Enterprise Manager certification matrix available on My Oracle Support. To access the Enterprise Manager certification matrix, follow the steps outlined in Appendix E.
For information about platforms receiving future support, refer to My Oracle Support note 793512.1.
  • If you want to install on Microsoft Windows 2012, then make sure you apply the patches described in My Oracle Support note 1590965.1.
  • If you use Oracle Solaris 10, then ensure that you have update 9 or higher installed. To verify whether it is installed, run the following command:
    cat /etc/release
    You should see the output similar to the following. Here, s10s_u6 indicates that update 6 is already installed.
    Solaris 10 10/08 s10s_u6wos_07b SPARC
Package Requirements
Ensure that you install all the operating system-specific packages as described in Chapter 5.
Operating System Groups and Users Requirements
Ensure that you create the required operating system groups and users as described in Chapter 6.
NFS Mount Point Location Requirements
  • If you are planning to install on an NFS-shared location, then make sure that the Access Control List processing is disabled for the NFS mount point. In other words, the mount point must be defined with the noacl option in the /etc/fstab file. Otherwise, the installation can fail.
    To verify this, run the following command as the install user to check the contents of the /etc/fstab file. Verify if the mount point on which you plan to install Enterprise Manager has the noacl option set.
    cat /etc/fstab
    For example, in the following output, the mount point /oracle/mw/oem_01 has the noacl option set. In this case, you are ready to proceed with the installation.
    10.0.0.0:/export/nonproduction/abc001_mw-oem01 /oracle/mw/oem_01 nfs rw,bg,hard,nointr,tcp,vers=3,noacl,timeo=300,rsize=131072,wsize=131072 0 0
    If you do not have the noacl option set, then contact your System Administrator to make the required changes in the /etc/fstab file.
  • If you are planning to insall on an NFS-shared middleware location, and if that location is mounted with the option concurrent I/O (CIO), which allows multiple reads and writes to a file at the same time, then the installation will fail reporting linking errors.
    If you verify the mounted file system, you will see the following CIO option enabled.
    node mounted mounted over vfs date options
    /dev/host1 /host1/oracle jfs2 Feb 14 18:20 rw,cio,log=/dev/xd891loglv
    If you do not have the CIO option enabled, then re-remount the file system with out the CIO enabled.
Middleware Home Path Requirements
Ensure that the number of characters in the middleware home path does not exceed 70 characters for Unix platforms and 25 characters for Microsoft Windows platforms.
For example, the middleware home path C:\Oracle\MW\EM containing only 15 characters is acceptable. However, C:\OracleSoftware\OracleMiddleware\OracleEnterpriseManager\OMS\newrelease\oms containing more than 25 characters is not acceptable on Microsoft Windows platforms.
Agent Base Directory Path Requirements
(Only for Microsoft Windows) Ensure that the number of characters in the agent base directory path does not exceed 25 characters.
For example, the agent base directory path C:\Oracle\Agent\ containing only 16 characters is acceptable. However, C:\Oracle\ManagementAgent\12c\new containing more than 25 characters is not acceptable.
Unique Host Name and Static IP Address Requirements
Ensure that you check the network configuration to verify that the host on which you are installing resolves to a unique host name and a static IP address that are visible to other hosts in the network.
Note: Oracle recommends that you use static IP address. If you use dynamic IP address, and if the host is rebooted, then the host might receive a new IP, and as a result, the OMS startup will fail.
Temporary Directory Space Requirements
Ensure that you allocate 400 MB of space for a temporary directory where the executables can be copied.
By default, the temporary directory location set to the environment variable TMP or TEMP is honored. If both are set, then TEMP is honored. If none of them are set, then the following default values are honored: /tmp on UNIX hosts and c:\Temp on Microsoft Windows hosts.
Central Inventory Requirements
Ensure that you allocate 100 MB of space for the central inventory directory.
Ensure that the Central Inventory (oraInventory) is not on a shared location that is shared and updated by multiple hosts. One inventory file is meant only for one host, so it must not be edited by multiple hosts. When you use the /etc/oraInst.loc file, ensure that the inventory location specified there is not pointing to such a locaiton. Alternatively, change it to a non-shared location.
UMASK Value Requirements
Ensure that you set the default file mode creation mask (umask) to 022 in the shell startup file.
For example:
  • Bash Shell
    $ . ./.bash_profile
  • Bourne or Korn Shell
    $ . ./.profile
  • C Shell
    % source ./.login
CLASSPATH Environment Variable Requirements
Unset the CLASSPATH environment variable. You can always reset the variable to the original value after the installation is complete.
File Descriptor Requirements
Ensure that you set the soft limit of file descriptor to a minimum of 4096 and hard limit less then or equal to 16384.
To verify the current value set to the file descriptors, run the following commands:
For Soft Limit:
/bin/sh -c "ulimit -n"
For Hard Limit:
/bin/sh -c "ulimit -Hn"
If the current value is not 4096 or greater, then as a root user, update the /etc/security/limits.conf file with the following entries:
<UID> soft nofile 4096
<UID> hard nofile 16384
Existing Database Version Requirements
Ensure that the existing database is a certified database as mentioned in the Enterprise Manager certification matrix available on My Oracle Support. Alternatively, the database can be a database instance created with a preconfigured Management Repository using the database templates offered by Oracle.
To access the Enterprise Manager certification matrix and identify whether your database is a certified database, follow these steps in Appendix E.
Important:
  • Ensure that the database is patched with all the Patch Set Updates (PSU) or Critical Patch Updates (CPU) released for that release. Also ensure that you apply the patches.
  • If you use Oracle Database 11g Release 2 (11.2.0.1), then ensure that you apply the patches for bugs 10014178 and 8799099.
  • If you use Oracle Database 11g Release 1 (11.1.0.7), then ensure that you apply Patch Set Update 2 and the patches for bugs 8644757 and 7525072.
  • The database can also have the Automatic Memory Management (AMM) feature enabled.
  • Ensure that this database is dedicated to Enterprise Manager.
Host File Requirements
Ensure that the host name specified in the /etc/hosts file is unique, and ensure that it maps to the correct host name or IP address of that host. Otherwise, the installation can fail on the product-specific prerequisite check page.
In some platforms, the installer does not validate the host name mentioned in the /etc/hosts file, therefore make sure the host names or IP addresses are correct.
Ensure that localhost is pingable and resolves to 127.0.0.1 (or resolves to ::1 for IPv6 hosts).
The following is the recommended format of the /etc/hosts file:
<ip> <fully_qualified_host_name> <short_host_name>
For example,
127.0.0.1 localhost.localdomain localhost
172.16.0.0 myhost.example.com myhost
According to RFC 952, the following are the assumptions: A name (Net, Host, Gateway, or Domain name) is a text string up to 24 characters drawn from the alphabet (A-Z), digits (0-9), minus sign (-), and period (.). Note that periods are only allowed when they serve to delimit components of domain style names. No blank or space characters are permitted as part of a name. No distinction is made between upper and lower case. The first character must be an alpha character.
Also, if DNS server is configured in your environment, then you should be able to use DNS to resolve the name of the host on which you want to install the OMS.
For example, all these commands must return the same output:
nslookup myhost
nslookup myhost.example.com
nslookup 172.16.0.0
Installing User Requirements
Ensure that you meet the following requirements:
  • (For UNIX only) The installation must NOT be run by a root user.
  • (For Microsoft Windows only) User must be part of the ORA-DBA group and have administrator permissions.
  • (For Microsoft Windows only) User must belong to the DBA group, and have permissions to perform the following: Act as part of the operating system, Create a token object, Log on as a batch job, and Adjust memory quotas for a process.
    To verify whether the install user has these rights, from the Start menu, click Settings and then select Control Panel. From the Control Panel window, select Administrative Tools, and from the Administrative Tools window, select Local Security Policy. In the Local Security Settings window, from the tree structure, expand Local Policies, and then expand User Rights Assignment.
Permission Requirements
  • Ensure that you have write permission in the Middleware home and the Oracle Management Service Instance Base location.
  • Ensure that you have write permission in the temporary directory where the executables will be copied. For example, /tmp or c:\Temp.
  • Ensure that you have write permission in the location where you want to create the Central Inventory (oraInventory) if it does not already exist. If the Central Inventory already exists, then ensure that you have write permission in the inventory directory.
  • Ensure that the user who installed the existing Oracle Database has write permission in the data file locations where the data files for the new tablespaces will be copied.
    These tablespaces and data files are created while configuring Enterprise Manager Cloud Control. While installing with simple configuration (Section 8.4.1), the installer automatically honors the default locations so you are not prompted for them. However, while installing with custom configuration (Section 8.4.2), the installer prompts you to validate or enter the locations explicitly.
Proximity Requirements
Ensure that the host on which the OMS is being installed and the host on which the Management Repository is being configured are located in close proximity to each other. Ideally, the round trip network latency between the two should be less than 1 millisecond.
Port Requirements
Ensure that the ports you assign (within the given range) to the following components are free and available:
  • Admin Server HTTP SSL Port = 7101 - 7200
  • Enterprise Manager Upload HTTP Port = 4889 - 4898
  • Enterprise Manager Upload HTTP SSL Port = 1159, 4899 - 4908
  • Enterprise Manager Central Console HTTP Port = 7788 - 7798
  • Enterprise Manager Central Console HTTP SSL Port = 7799 - 7809
  • Oracle Management Agent Port = 3872, 1830 - 1849
  • Node Manager = 7101 - 7200
  • Managed Server HTTP Port = 7201 - 7300
  • Managed Server HTTPS Port = 7301 - 7400
To verify if a port is free, run the following command:
  • On Unix:
    netstat -an | grep <port no>
  • On Microsoft Windows:
    netstat -an|findstr <port_no>
Internet Connection Requirements
Oracle recommends that the host from where you are running the installer have a connection to the Internet so that the configuration information can be automatically collected and uploaded to My Oracle Support.
Using the Internet connection, you can also search and download software updates from My Oracle Support using the installer. For installations that do not have access to the Internet, see the instructions on how to manually obtain Software Updates for offline installation in Oracle Enterprise Manager Cloud Control Advanced Installation and Configuration Guide.
These updates should be obtained before starting the 12c installation so they can be available to the installer at the proper time.
8.4 Installation Procedure
8.4.1 Installing with Simple Configuration
The Simple installation type installs with default configuration settings and preferences that you need for a complete Enterprise Manager system. It does not offer too many options to customize your installation. This installation type is meant for demo or evaluation purposes, and small deployments, and when you do not want to worry about the granular control of the installer and want to install the Enterprise Manager system quickly, with less memory, and for monitoring fewer targets in their environment.
To install Enterprise Manager Cloud Control with simple configuration, follow these steps:
Oracle recommends you to run the EM Prerequisite Kit before invoking the installer to ensure that you meet all the repository requirements beforehand. Even if you do not run it manually, the installer anyway runs it in the background while installing the product. However, running it manually beforehand sets up your Management Repository even before you can start the installation or upgrade process. For information on the kit, to understand how to run it, and to know about the prerequisite checks it runs, see Appendix A.
  1. Invoke the Enterprise Manager Cloud Control Installation Wizard.
    Invoke the installation wizard as a user who belongs to the oinstall group you created following the instructions in Chapter 6.
    <Software_Location>/runInstaller
    In this command, <Software_Location> is either the DVD location or the location where you have downloaded the software kit.
    • To invoke the installation wizard on UNIX platforms, run runInstaller. To invoke on Microsoft Windows platforms, run setup.exe.
    • When you invoke runInstaller or setup.exe, if the Enterprise Manager Cloud Control Installation Wizard does not appear, then it is possible that you do not have read and write access to /stage, which a subdirectory in the Disk1 directory of the Enterprise Manager software.
      There is a classpath variable that the installation wizard computes for OPatch as ../stage/Components/, and when the TEMP variable is set to /tmp, the installation wizard tries to look for the opatch JAR file in the /tmp/../stage directory, which is equivalent to /stage. However, if you do not have read and write permission on /stage, then the installation wizard can hang. Under such circumstances, verify if you have read and write access to the /stage directory. If you do not have, then set the TEMP variable to a location where the install user has access to, and then relaunch the installation wizard.
  2. (Optional) Enter My Oracle Support Details.
    My Oracle Support Details Screen
    (Optional) On the My Oracle Support Details screen, enter your My Oracle Support credentials to enable Oracle Configuration Manager. If you do not want to enable Oracle Configuration Manager now, go to Step (3).
    If the host from where you are running the installation wizard does not have a connection to the Internet, then enter only the e-mail address and leave the other fields blank. After you complete the installation, manually collect the configuration information and upload it to My Oracle Support.
    Beginning with Enterprise Manager Cloud Control 12c Release 3 (12.1.0.3), My Oracle Suppot accesses support.oracle.com directly. This means that you must provide network access to this URL, or grant proxy access to it from any client that will access My Oracle Support.
  3. Click Next.
  4. (Recommended) Install Software Updates.
    On the Software Updates screen, select a either Search for Updates or My Oracle Support, and apply the latest software updates.
    You can download the software updates in offline mode (if you do not have Internet connectivity) or online mode (if you have Internet connectivity). For more information on these options, and for instructions to download and apply the software updates using these options, see Oracle Enterprise Manager Cloud Control Advanced Installation and Configuration Guide.
    The Software Updates screen uses the built-in feature Auto Update to automatically download and deploy the latest recommended patches while installing or upgrading Enterprise Manager Cloud Control. This way, you do not have to keep a manual check on the patches released by Oracle. All patches required by the installer for successful installation and upgrade are automatically detected and downloaded from My Oracle Support, and applied during the installation or upgrade, thus reducing the known issues and potential failures. Oracle strongly recommends using this feature, and applying the software updates while the installation is in progress. For more information, see Oracle Enterprise Manager Cloud Control Advanced Installation and Configuration Guide.
    Despite providing the My Oracle Support credentials, if you are unable to download the software updates, then exit the installer, and invoke the installer again passing the -showProxy parameter in the following way:
    <Software_Location>/runInstaller -showProxy
  5. Click Next.
    If Enterprise Manager Cloud Control is the first Oracle product you are installing on the host that is running on UNIX operating system, then the Oracle Inventory screen appears. For details, see step (6). Otherwise, the Check Prerequisites screen appears. For details, see step (8).
    If Enterprise Manager Cloud Control is the first Oracle product you are installing on the host that is running on Microsoft Windows operating system, then the Oracle Inventory screen does not appear. On Microsoft Windows, the following is the default inventory directory:
    <system drive>\Program Files\Oracle\Inventory
  6. Enter Oracle Inventory Details.
    On the Oracle Inventory screen, do the following. You will see this screen only if this turns out to be your first ever installation of an Oracle product on the host.
    1. Enter the full path to a directory where the inventory files and directories can be placed.
      If this is the first Oracle product on the host, then the default central inventory location is <home directory>/oraInventory. However, if you already have some Oracle products on the host, then the central inventory location can be found in the oraInst.loc file. The oraInst.loc file is located in the /etc directory for Linux and AIX, and in the /var/opt/oracle directory for Solaris, HP-UX, and Tru64.
    2. Select the appropriate operating system group name that will own the Oracle inventory directories. The group that you select must have write permissions on the Oracle Inventory directories.
  7. Click Next.
  8. Check Prerequisites.
    Check Prerequisites
    On the Prerequisite Checks screen, check the status of the prerequisite checks run by the installation wizard, and verify whether your environment meets all the minimum requirements for a successful installation.
    The installation wizard runs the prerequisite checks automatically when you come to this screen. It checks for the required operating system patches, operating system packages, and so on.
    The status of the prerequisite check can be either Warning, Failed, or Succeeded.
    • If some checks result in Warning or Failed status, then investigate and correct the problems before you proceed with the installation. The screen provides details on why the prerequisites failed and how you can resolve them. After you correct the problems, return to this screen and click Rerun to check the prerequisites again.
    • However, all package requirements must be met or fixed before proceeding any further. Otherwise, the installation might fail.
  9. Click Next.
    If a prerequisite check fails reporting a missing package, then make sure you install the required package, and click Rerun. The installation wizard validates the package name as well as the version, so make sure you install the packages of the minimum versions mentioned in Chapter 5. To understand the logic the installation wizard uses to verify these packages, see Section 5.1.1.
  10. Select Installation Type.
    On the Installation Types screen, select Create a New Enterprise Manager System, then select Simple.
  11. Click Next.
  12. Enter Installation Details.
    Installation Details Screen for Simple Installation
    On the Installation Details screen, do the following:
    1. Enter or validate the Middleware home where you want to install the OMS and other core components.
      • If you have Oracle WebLogic Server and Java Development Kit already installed, then ensure that they are of the supported releases—Oracle WebLogic Server 11g Release 1 (10.3.6) and JDK 1.6.0.43.0. If you have the supported releases, the installer automatically detects them and displays the absolute path to the Middleware home where they are installed. In this case, validate the Middleware home. If the location is incorrect, then enter the path to the correct location. Ensure that the Middleware home you select or enter is a Middleware home that does not have any Oracle homes.
        Also make sure you have applied patch 14482558 and patch 13349651 on the Oracle WebLogic Server. For instructions, see the following URL:
      • If you do not have Oracle WebLogic Server 11g Release 1 (10.3.6) and JDK 1.6.0.43.0, then the installer automatically installs them for you while installing the Enterprise Manager system. In this case, enter the absolute path to a directory where you want to have them installed. For example, /oracle/software/. Ensure that the directory you enter does not contain any files or subdirectories.
      • If you want to manually install Oracle WebLogic Server 11g Release 1 (10.3.6), then follow the guidelines outlined in Section 8.2. After installing Oracle WebLogic Server, make sure you apply patch 14482558 and patch 13349651 on it.
      • (Only for Microsoft Windows) Ensure that the number of characters in the middleware home path does not exceed 25 characters.
        For example, the middleware home path C:\Oracle\MW\EM containing only 15 characters is acceptable. However, C:\Oracle\MW\new\EM\dir\a123 containing more than 25 characters is not acceptable.
        For example, the middleware home path C:\Oracle\MW\EM containing only 15 characters is acceptable. However, C:\OracleSoftware\OracleMiddleware\OracleEnterpriseManager\OMS\newrelease\oms containing more than 25 characters is not acceptable for Microsoft Windows platforms.
      • By default, the OMS instance base directory (gc_inst) is created outside the middleware home, and at the same, parent level as the middleware home. For example, if you enter u01/software/oracle/middleware as the middleware home, then the instance base directory is created as u01/software/oracle/gc_inst. If this parent location is an NFS-mounted location, then after you finish the installation, you must move the lock files from the NFS-mounted drive to a local file system location. Modify the lock file location in the httpd.conf file to map to a location on a local file system. For instructions, refer to Section 8.5
    2. Enter the absolute path to the agent base directory, a location outside the Oracle Middleware home where the Management Agent can be installed. For example, if the middleware home is /u01/app/Oracle/Middleware/, then you can specify the agent base directory as /u01/app/Oracle/agent12c.
      Ensure that this location is empty and has write permission. Also ensure that it is always maintained outside the Oracle Middleware home.
    3. Validate the name of the host where you want to configure the OMS.
      The host name appears as a fully qualified name, or as a virtual host name if your host is configured with virtual machine. If the installation wizard was invoked with a value for ORACLE_HOSTNAME, then this field is prepopulated with that name.
      Accept the default host name, or enter a fully qualified domain name that is registered in DNS and is accessible from other network hosts. Oracle recommends that you use a fully qualified domain name.
      The host name must resolve to the local host because the host name is used for the local Oracle WebLogic Server as well as the Oracle Management Service. Do not provide a remote host or a load balancer virtual host in this field. Do not enter an IP address. Do not use underscores in the name. Short names are allowed, but you will see a warning, so Oracle recommends that you enter a fully qualified domain name instead.
  13. Click Next.
  14. Enter Configuration Details.
    On the Configuration Details screen, do the following:
    1. Enter an administrator password, which can be used as a common password for configuring the Enterprise Manager Cloud Control.
      Ensure that your password contains at least 8 characters without any spaces, begins with a letter, and includes at least one numeric value.
      Table 8-4 describes what the administrator password is used for.
      Table 8-4 Usage of Administrator Password
      Purpose Description
      Creates SYSMAN User Account
      The user account is used as the super administrator for configuring the SYSMAN schema in the Management Repository.
      Creates Default WebLogic User Account weblogic
      The user account is used as the administrator for creating the default WebLogic domain GCDomain.
      Creates Default Node Manager User Account nodemanager
      The user account is automatically created during the configuration of Enterprise Manager Cloud Control.
      Authenticates New Management Agents
      The agent registration password is used for authenticating new Management Agents that join Enterprise Manager system, where the communication between the OMS and the Management Agent is secure.
    2. Provide details of the existing, certified database where the Management Repository needs to be created. If you have already created a database instance with a preconfigured Management Repository using the database templates offered by Oracle, then provide details about that database instance.
      The installer uses this information to connect to the existing database for creating the SYSMAN schema and plug-in schemas. If you provide details of a database that already has a preconfigured Management Repository, then the installer only creates plug-in schemas.
      • For information about creating a database instance with a preconfigured Management Repository using the database templates offered by Oracle, refer to Appendix D.
      • If you connect to a database instance that was created using the database template offered by Oracle, then the password assigned to user accounts SYSMAN, SYSMAN_MDS, SYSMAN_APM, and SYSMAN_OPSS, which were created while preconfiguring the Management Repository, are automatically reset with the administrator password you enter here on this screen. We also unlock all these user accounts.
      • To identify whether your database is a certified database listed in the certification matrix, follow the steps outlined in Appendix E.
      • Oracle Real Application Cluster (Oracle RAC) nodes are referred to by their virtual IP (vip) names. The service_name parameter is used instead of the system identifier (SID) in connect_data mode, and failover is turned on. For more information, refer to Oracle Database Net Services Administrator's Guide.
      • For information on all the database initialization parameters that are set, and all the prerequisite checks that are run, and for instructions to run the prerequisite checks manually if they fail, see Appendix A.
      • If you see a warning stating that the database you have provided already has Enterprise Manager schemas configured, then make sure you drop those schemas first, then deinstall the Enterprise Manager software that had created those schemas, and then return to the installer to proceed with the new installation. For instructions to drop the schemas and deinstall the software, see Oracle Enterprise Manager Cloud Control Advanced Installation and Configuration Guide.
    3. If you want to configure Oracle Software Library (Software Library), select Configure Oracle Software Library. Enter the absolute path leading up to a unique directory name on the OMS host where the Software Library can be configured.
      By default, an OMS Shared File System storage location is configured, so ensure that the location you enter is a mounted location on the OMS host, and is placed outside the Middleware Home. Also ensure that the OMS process owner has read/write access to that location. This helps when you install additional OMS instances as they will require read/write access to the same OMS Shared File System storage location.
      • Oracle recommends that you maintain the Software Library outside the Middleware Home. For example, if the middleware home is /u01/software/oracle/middleware, then you can maintain the Software Library in /u01/software/oracle.
      • Oracle strongly recommends that you enter a mounted location on the OMS host so that the same location can be used when you install additional OMS instances. However, if you are unable to provide a mounted location or if you are testing the installation in a test environment and do not want to provide a mounted location, then you can provide a local file system location. In this case, after the installation, make sure you migrate to a mounted location.
        For information about the Software Library storage locations, see Oracle Enterprise Manager Cloud Control Administrator's Guide. For instructions to migrate to an OMS Agent File System storage location, see Oracle Enterprise Manager Cloud Control Administrator's Guide.
      • On Microsoft Windows, if you are unable to provide a mounted location, then enter a local file system location at the time of installing the product, and migrate to an OMS Agent File System storage location later. The OMS Agent File System storage location is the recommend storage type on Microsoft Windows.
      • Configuring the Software Library at the time of installation is optional. Even if you do not select this option and configure it now, your installation will succeed. You always have the option of configuring the Software Library later from the Enterprise Manager Cloud Control Console. However, Oracle strongly recommends that you select this option and configure it at the time of installation so that the installer can automatically configure it for you, thus saving your time and effort.
      • Once the Software Library is configured, you can view the location details in the Software Library Console. To access the Software Library Console, in Cloud Control, from the Setup menu, select Provisioning and Patching, then select Software Library.
  15. Click Next.
    • If you are connecting to an Oracle RAC database, and if you have specified the virtual IP address of one of its nodes, then the installation wizard prompts you with a Connection String dialog and requests you to update the connection string with information about the other nodes that are part of the cluster. Update the connection string and click OK. If you want to test the connection, click Test Connection.
    • If your Oracle RAC database 11.2 or higher is configured with Single Client Access Name (SCAN) listener, then you can enter a connection string using the SCAN listener.
    • If you see an error stating that the connection to the database failed with ORA-01017 invalid user name/password, then follow these steps to resolve the issue:
      (1) Verify that SYS password provided is valid.
      (2) Verify that the database initialization parameter REMOTE_LOGIN_PASSWORDFILE is set to Shared or Exclusive.
      (3) Verify that password file with the file name orapw<SID> exists in the <ORACLE_HOME>/dbs directory of the database home. If it does not, create a password file using the ORAPWD command.
    • If you are connecting to an Oracle Database that already has a Database Control configured, then you will see an error message with instructions to deconfigure it. Ensure that you follow the instructions outlined in the message to deconfigure the Database Control.
  16. Review and Install
    On the Review screen, review the details you provided for the selected installation type.
    • If you want to change the details, click Back repeatedly until you reach the screen where you want to make the changes.
    • After you verify the details, if you are satisfied, click Install to begin the installation process.
  17. Track the Progress
    On the Install Progress screen, view the overall progress (in percentage) of the installation and the status of each of the configuration assistants. Configuration assistants are run for configuring the installed components of Enterprise Manager Cloud Control.
    • If a configuration assistant fails, the installer stops and none of the subsequent configuration assistants are run. Resolve the issue and retry the configuration assistant.
      For more information, see the appendix on troubleshooting tips in the Oracle Enterprise Manager Cloud Control Advanced Installation and Configuration Guide.
    • If you accidently exit the installer before clicking Retry, then do NOT restart the installer to reach the same screen; instead, invoke the runConfig.sh script from the OMS home to rerun the Configuration Assistant in silent mode. For Microsoft Windows platforms, invoke runConfig.bat script.
      $<OMS_HOME>/oui/bin/runConfig.sh ORACLE_HOME=<absolute_path_to_OMS_home> MODE=perform ACTION=configure COMPONENT_XML={encap_oms.1_0_0_0_0.xml}
      If the runConfig.sh script fails, then clean up your environment and redo the installation.
  18. Run Scripts
    Once the software binaries are copied and configured, you are prompted to run the allroot.sh script, and the oraInstRoot.sh script if this is the first Oracle product installation on the host. Open another window, log in as root, and manually run the scripts.
    If you are installing on Microsoft Windows operating system, then you will NOT be prompted to run this script.
  19. End the Installation
    On the Finish screen, you should see information pertaining to the installation of Enterprise Manager. Review the information and click Close to exit the installation wizard.
    For more information about this installation, refer to the following file in the OMS home:
    $<OMS_HOME>/install/setupinfo.txt
If the installation fails for some reason, review the log files listed in Oracle Enterprise Manager Cloud Control Advanced Installation and Configuration Guide.
If you have run the installation wizard and let the installation wizard take corrective actions to correct the repository settings, and if you have exited the wizard without completing the installation process, then remember that the repository settings might not reset to their original values because you abruptly ended the installation. In this case, before invoking the installation wizard again, run the following command to manually reset the values.
<Software_Location>/install/requisites/bin/emprereqkit -executionType install -prerequisiteXMLLoc <prereq_xml_location> -connectString <connect_string> -dbUser SYS -dbPassword <db_password> -reposUser sysman -dbRole sysdba -runPrerequisites -runPostCorrectiveActions
8.4.2 Installing with Advanced Configuration
To install Enterprise Manager Cloud Control with advanced configuration, follow these steps:
    My Oracle Support Screen
  3. Click Next.
  5. Click Next.
  7. Click Next.
    Check Prerequisites
    You can choose to ignore the checks with Warning status by clicking Ignore. However, all package requirements must be met or fixed before proceeding any further.
  9. Click Next.
    On the Installation Types screen, select Create a New Enterprise Manager System, then select Advanced.
  11. Click Next.
    Installation Details Screen for Advanced Installation
        Also make sure you apply patch 14482558 and patch 13349651 on the Oracle WebLogic Server. For instructions, see the following URL:
      • If you manually install Oracle WebLogic Server 11g Release 1 (10.3.6), then follow the guidelines outlined in Section 8.2. After installing Oracle WebLogic Server, make sure you apply patch 14482558 and patch 13349651 on it.
  13. Click Next.
  14. Deploy Plug-Ins.
    Plug-In Deployment Screen
    On the Plug-In Deployment screen, select the optional plug-ins you want to install from the software kit (DVD, downloaded software) while installing the Enterprise Manager system.
    The pre-selected rows are mandatory plug-ins that will be installed by default. Select the optional ones you want to install.
    During installation, if you want to install a plug-in that is not available in the software kit, then refer to Section 8.4.2.1 for the point that describes how you can install additional plug-ins.
  15. Click Next.
  16. Enter WebLogic Server Configuration Details.
    WebLogic Server Configuration Details screen
    On the WebLogic Server Configuration Details screen, enter the credentials for the WebLogic Server user account and the Node Manager user account, and validate the path to the Oracle Management Service instance base location. Ensure that the Oracle Management Service instance base location is outside the middleware home.
    • Ensure that the Oracle Management Service instance base location is outside the middleware home.
    By default, the WebLogic Domain name is GCDomain, and the Node Manager name is nodemanager. These are non-editable fields. The installer uses this information for creating Oracle WebLogic Domain and other associated components such as the admin server, the managed server, and the node manager. A Node Manager enables you to start, shut down, or restart an Oracle WebLogic Server instance remotely, and is recommended for applications with high availability requirements.
  17. Click Next.
  18. Enter Database Connection Details.
    Database Connection Details Screen
    On the Database Connection Details screen, do the following:
    1. Provide details of the existing, certified database where the Management Repository needs to be created. If you have already created a database instance with a preconfigured Management Repository using the database templates offered by Oracle, then provide details about that database instance.
      • If you connect to a database instance that was created using the database template offered by Oracle, then note that the password assigned to the user accounts SYSMAN_MDS, SYSMAN_APM, and SYSMAN_OPSS, which were created while preconfiguring the Management Repository, are automatically reset with the SYSMAN password you enter on the Enterprise Manager Configuration Details screen (as described in Step (20)).
    2. Select the deployment size from the Deployment Size list to indicate the number of targets you plan to monitor, the number of Management Agents you plan to have, and the number of concurrent user sessions you plan to have.
      Table 8-5 describes each deployment size.
      Table 8-5 Deployment Size
      Deployment Size Targets Count Management Agents Count Concurrent User Session Count
      Small
      Up to 999
      Up to 99
      Up to 10
      Medium
      Between 1000 and 9999
      Between 100 and 999
      Between 10 and 24
      Large
      10,000 or more
      1000 or more
      Between 25 and 50
      If the database you are connecting to is a database instance created with a preconfigured Management Repository using the database templates offered by Oracle (as described in Appendix D), then make sure the deployment size you select on this screen matches with the deployment size you selected on the Step 2 of 12: Database Templates screen of Oracle Database Configuration Assistant (DBCA) while creating the database instance.
      If you want to select a deployment size different from the deployment size you had selected while creating the database instance using DBCA, then do one of the following:
      • Select the deployment size of your choice on this screen, and click Next. When you see errors, fix the parameters in the database, then return to this screen to continue with the installation. To automatically fix the parameters using Oracle-supplied SQL scripts, see Section 8.4.2.3.
      • Minimize the installer, create another database instance with a template for the desired deployment size, then return to this screen and select the matching deployment size. For instructions, see Appendix D.
  19. Click Next.
  20. Enter Enterprise Manager Configuration Details
    Repository Configuration Details Screen
    On the Enterprise Manager Configuration Details screen, do the following:
    1. For SYSMAN Password, enter a password for creating the SYSMAN user account. The SYSMAN user account is used for creating the SYSMAN schema, which holds most of the relational data used in managing Enterprise Manager Cloud Control. SYSMAN is also the super administrator for Enterprise Manager Cloud Control.
      • Ensure that your password contains at least 8 characters without any spaces, begins with a letter, and includes at least one numeric value.
      • If you connect to a database instance that was created using the database template offered by Oracle, then note that the password assigned to the user accounts SYSMAN_MDS, SYSMAN_APM, and SYSMAN_OPSS, which were created while preconfiguring the Management Repository, are automatically reset with the SYSMAN password you enter on this screen.
    2. For Registration Password, enter a password for registering the new Management Agents that join the Enterprise Manager system.
    3. For Management Tablespace, enter the full path to the location where the data file for management tablespace (mgmt.dbf) can be stored. The installer uses this information for storing data about the monitored targets, their metrics, and so on. Ensure that the specified path leads up to the file name.
      For example, /u01/oracle/prod/oradata/mgmt.dbf
    4. For Configuration Data Tablespace, enter the full path to the location where the data file for configuration data tablespace (mgmt_ecm_depot1.dbf) can be stored. This is required for storing configuration information collected from the monitored targets. Ensure that the specified path leads up to the file name.
      For example, /u01/oracle/prod/oradata/mgmt_ecm_depot1.dbf
    5. For JVM Diagnostics Data Tablespace, enter the full path to a location where the data file for JVM Diagnostics data tablespace (mgmt_deepdive.dbf) can be stored. Ensure that the specified path leads up to the file name. Enterprise Manager Cloud Control requires this data file to store monitoring data related to JVM Diagnostics and Application Dependency Performance (ADP).
      For example, /u01/oracle/prod/oradata/mgmt_deepdive.dbf
      If you are configuring the Management Repository on a database that uses Oracle Automatic Storage Management (Oracle ASM) for storage, then when you enter the data file location, only the disk group is used for creating the tablespaces. For example, if you specify +DATA/a.dbf, then only +DATA is used for creating the tablespaces on Oracle ASM, and the exact location of the data file on the disk group is decided by Oracle Managed Files.
    6. If you want to configure Oracle Software Library (Software Library), select Configure Oracle Software Library. Enter the absolute path leading up to a unique directory name on the OMS host where the Software Library can be configured.
  21. Click Next.
  22. Customize Ports
    Port Configuration Details Screen
    On the Port Configuration Details screen, customize the ports to be used for various components.
    If all the ports on this screen appear as -1, then it indicates that the installer is unable to bind the ports on the host. To resolve this issue, exit the installer, verify the host name and the IP configuration of this host (ensure that the IP address of the host is not being used by another host), restart the installer, and try again.
    You can enter a free custom port that is either within or outside the port range recommended by Oracle.
    • On Unix:
    However, the custom port must be greater than 1024 and lesser than 65535. Alternatively, if you already have the ports predefined in a staticports.ini file and if you want to use those ports, then click Import staticports.ini File and select the file.
    If the staticports.ini file is passed during installation, then by default, the ports defined in the staticports.ini file are displayed. Otherwise, the first available port from the recommended range is displayed.
    The staticports.ini file is available in the following location:
    <Software_Extracted_Location>/response
  23. Click Next.
  24. Review and Install
  25. Track the Progress
    On the Install Progress screen, view the overall progress (in percentage) of the installation and the status of each of the Configuration Assistants. Configuration Assistants are run for configuring the installed components of Enterprise Manager Cloud Control.
  26. Run Scripts
    If you are installing on Microsoft Windows operating system, then you will NOT be prompted to run this script. You will directly reach the Finish screen as described in Step (27).
  27. End the Installation
    For more information about this installation, refer to the following file available in the OMS home:
8.4.2.1 Advanced Installer Options
The following are some additional, advanced options you can pass while invoking the installer:
  • By default, GCDomain is the default name used for creating the WebLogic Domain. To override this and use a custom WebLogic Domain name, invoke the installer with the WLS_DOMAIN_NAME option, and enter a unique custom name.
    For example, if you want to use the custom name EMDomain, then run the following command:
    ./runInstaller WLS_DOMAIN_NAME=EMDomain
  • By default, a Provisioning Advisor Framework (PAF) staging directory is created for copying the Software Library entities related to the deployment procedures. By default, this location is the scratch path location (/tmp). The location is used only for provisioning activities—entities are copied for a deployment procedure, and then, deleted once the deployment procedure ends.
    If you want to override this location with a custom location, then invoke the installer with the EM_STAGE_DIR option, and enter a unique custom location.
    For example,
    ./runInstaller EM_STAGE_DIR=/home/john/software/oracle/pafdir
  • During installation, if you want to install some plug-ins that are not in the software kit (DVD, downloaded software), then follow these steps:
    1. Manually download the plug-ins from the Enterprise Manager download page on OTN, and store them in an accessible location:
      http://www.oracle.com/technetwork/oem/grid-control/downloads/oem-upgrade-console-502238.html
    2. Invoke the installer with the following option, and pass the location where the plug-ins you want to install are available:
      ./runInstaller -pluginLocation <absolute_path_to_plugin_software_location>
      This displays a list of plug-ins available in the software kit (DVD, downloaded software) as well as the plug-ins available in this custom location. You can choose the ones you want to install.
  • After the installation ends successfully, the OMS and the Management Agent start automatically. If you do not want them to start automatically, then invoke the installer with START_OMS and b_startAgent options, and set them to true or false depending on what you want to control.
    For example, if you do not want the Management Agent to start automatically, then run the following command:
    ./runInstaller START_OMS=true b_startAgent=false
    To understand the limitations involved with this advanced option, see Section 8.4.2.2.
8.4.2.2 Limitations
When you use START_OMS and b_startAgent as advanced options to control the way the OMS and the Management Agent start up automatically, sometimes the Management Agent and the host on which it was installed do not appear as targets in the Cloud Control console.
Table 8-6 lists the different combinations of these advanced options, and describes the workaround to be followed for each combination:
Table 8-6 Advanced Options and Workarounds
Advanced Option Workaround
START_OMS=false
b_startAgent=false
  1. Start the OMS:
    $<OMS_HOME>/bin/emctl start oms
  2. Secure the Management Agent:
    $<AGENT_HOME>/bin/emctl secure agent
  3. Start the Management Agent:
    $<AGENT_HOME>/bin/emctl start agent
  4. Add the targets:
    $<AGENT_HOME>/bin/emctl config agent addinternaltargets
  5. Upload the targets:
    $<AGENT_HOME>/bin/emctl upload agent
START_OMS=true
b_startAgent=false
START_OMS=false
b_startAgent=true
  1. Start the OMS:
  3. Add the targets:
  4. Upload the targets:
8.4.2.3 Automatically Setting Database Parameters and Converting the Management Repository to Support a Deployment Size (Large, Medium, or Small)
If the database you are connecting to is a database instance created with a preconfigured Management Repository using the database templates offered by Oracle (as described in Appendix D), then you should make sure the deployment size you select on the Database Connection Details screen of the installer matches with the deployment size you selected on the Step 2 of 12: Database Templates screen of Oracle Database Configuration Assistant (DBCA) while creating the database instance.
If you want to select a deployment size different from the deployment size you had selected while creating the database instance using DBCA, then you must first fix the parameters in the database, then return to the Database Connection Details screen of the installer to continue with the installation. To automatically set the parameters using the Oracle-supplied SQL scripts, follow these steps:
  1. Log in to SQL Plus as SYSMAN.
  2. Depending on the deployment size for which you want to install Enterprise Manager, run one of the following scripts. To download these scripts, follow Step (2) and Step (3) outlined in Appendix D.
    Deployment Size Scripts
    Small <DB_HOME>/assistance/dbca/template/set_repo_param_11.2.0.3_Database_SQL_for_EM12c_Small_deployment.sql
    Medium <DB_HOME>/assistance/dbca/template/set_repo_param_11.2.0.3_Database_SQL_for_EM12c_Medium_deployment.sql
    Large <DB_HOME>/assistance/dbca/template/set_repo_param_11.2.0.3_Database_SQL_for_EM12c_Large_deployment.sql
  3. Restart the database.
For information on deployment sizes, the prerequisite checks that are run, the database parameters that are set, and how you can modify the deployment size after installation, refer to Oracle Enterprise Manager Cloud Control Advanced Installation and Configuration Guide.
8.5 After You Install
After you install, do the following:
  1. (Only for UNIX Operating Systems) If you did not run the allroot.sh script when the installer prompted you to do so, then run it manually now:
    • If this is the first Oracle product you just installed on the host, then run the oraInstroot.sh script from the inventory location specified in the oraInst.loc file that is available in the Management Agent home.
      For example, if the inventory location specified in the oraInst.loc file is $HOME/oraInventory, then run the following command:
      $HOME/oraInventory/oraInstRoot.sh
      If you are not a root user, then use SUDO to change to a root user. For example, run the following command:
      /usr/local/bin/sudo $HOME/oraInventory/oraInstRoot.sh
    • Run the allroot.sh script from the OMS home:
      $<OMS_HOME>/allroot.sh
      /usr/local/bin/sudo $<OMS_HOME>/allroot.sh
  2. Verify the installation:
    1. Navigate to the OMS home and run the following command to see a message that confirms that OMS is up and running.
      $<OMS_HOME>/bin/emctl status oms
      For example,
      /u01/middleware/oms/bin/emctl status oms
    2. Navigate to the Management Agent home and run the following command to see a message that confirms that the Management Agent is up and running.
      $<AGENT_HOME>/bin/emctl status agent
      For example,
      /u01/agent/core/12.1.0.3.0/bin/emctl status agent
    3. Navigate to the Management Agent home and run the following command to see a message that confirms that EMD upload completed successfully.
      For example,
      /u01/agent/core/12.1.0.3.0/bin/emctl upload agent
    By default, you can access Enterprise Manager Cloud Control only using the HTTPS protocol. If you want to use the HTTP protocol, then unlock it by running the following command from the OMS home:
    emctl secure unlock -console
  3. Verify if all the plug-ins were installed successfully. To do so, access the following log file from the Management Agent home, and search for the sentence WARN:Plugin configuration has failed.
    $<AGENT_HOME>/cfgtoollogs/cfgfw/CfmLogger-<timestamp>.log
    For example,
    $/u01/agent/core/12.1.0.3.0/cfgtoollogs/cfgfw/CfmLogger-<timestamp>.log
    If you find the sentence, resolve the issue by running the AgentPluginDeploy.pl script from the Management Agent home.
    $<AGENT_BASE_DIR>/agent/core/12.1.0.3.0/perl/bin/perl <AGENT_BASE_DIR>/agent/core/12.1.0.3.0/bin/AgentPluginDeploy.pl -oracleHome <AGENT_BASE_DIR>/agent/core/12.1.0.3.0 -agentDir <AGENT_BASE_DIR> -pluginIdsInfoFile <AGENT_BASE_DIR>/plugins.txt -action configure -emStateDir <AGENT_INSTANCE_HOME>
    For example,
    /u01/agent/core/12.1.0.3.0/perl/bin/perl /u01/agent/core/12.1.0.3.0/bin/AgentPluginDeploy.pl -oracleHome /u01/agent/core/12.1.0.3.0/ -agentDir /u01/agent -pluginIdsInfoFile /u01/agent/plugins.txt -action configure -emStateDir /u01/agent/agent_inst
  4. (Optional) If the repository prerequisites had failed, and if you had manually run the EM Prerequisite Kit and taken corrective actions to meet the repository requirements, then run the utility again to reset the repository settings to what it had originally:
    If you had run the installation wizard and let the installation wizard take corrective actions to correct the repository settings, and if you had exited the wizard without completing the installation process, then remember that the repository settings might not reset to their original values because you abruptly ended the installation. In this case, before invoking the installation wizard again, run this command to manually reset the values.
  5. If you installed using a virtual host name for any of the following reasons, particularly for a high-availability configuration, then manually update the configuration files to replace the physical host name with the virtual host name that you used for installation.
    • If you installed in a cold failover cluster (CFC).
    • If you installed using a storage replication disaster recovery solution and chose the virtual host name option.
    To manually update the configuration files to replace the physical host name with the virtual host name that you used for installation, follow these steps:
    1. For each OMS in the domain, access the following file from the OMS home, and change the SERVERNAME parameter value from physical host name to virtual host name that you used for installation.
      <OMS_HOME>/Middleware/gc_inst/WebTierIH1/config/OHS/ohsx/httpd.conf
    2. For the primary OMS, access the following file from the OMS home, and change the host from physical to virtual host (there will be an entry for each host in the domain).
      <OMS_HOME>/gc_inst/user_projects/domains/GCDomain/opmn/topology.xml
  6. By default, the following targets get automatically discovered and monitored in the Enterprise Manager Cloud Control console:
    • Oracle WebLogic Domain (for example, GCDomain)
    • Oracle WebLogic AdminServer
    • Oracle WebLogic Server
    • Oracle Web Tier
    • Application deployments, one for the Enterprise Manager Cloud Control console and one for the platform background services.
    • Oracle Management Service
    • Oracle Management Repository
    • The host on which you installed Enterprise Manager Cloud Control
    However, the other targets running on that host and other hosts do not get automatically discovered and monitored. To monitor the other targets, you need to add them to Enterprise Manager Cloud Control either using the Auto Discovery Results page, the Add Targets Manually page, or the discovery wizards offered for the targets you want to monitor.
    For information about discovering targets in Enterprise Manager Cloud Control, refer to the chapter on adding targets in the Oracle Enterprise Manager Cloud Control Administrator's Guide.
  7. If you created the OMS instance base directory on an NFS-mounted drive, then ensure that you maintain the lock files in a local file system and not in that NFS-mounted location. To do so, modify the lock files location in the httpd.conf file to map to a location on a local file system.
    1. Stop the OMS:
      <OMS_HOME>/bin/emctl stop oms -all
    2. Open the following file:
      Oracle recommends you to take a backup of this file before editing it.
      <WEBTIER_INSTANCE_HOME>/config/OHS/ohs1/httpd.conf
    3. Search for sections related to the modules mpm_prefork_module and mpm_worker_module. In both these sections, modify the value for the LockFile parameter so that the path leads to a location on the local file system.
      <IfModule mpm_prefork_module>
      StartServers 5
      MinSpareServers 5
      MaxSpareServers 10
      MaxClients 150
      MaxRequestsPerChild 0
      AcceptMutex fcntl
      LockFile "${ORACLE_INSTANCE}/diagnostics/logs/${COMPONENT_TYPE}/${COMPONENT_NAME}/http_lock"
      </IfModule>
      <IfModule mpm_worker_module>
      StartServers 2
      MaxClients 150
      MinSpareThreads 25
      MaxSpareThreads 75
      ThreadsPerChild 25
      AcceptMutex fcntl
      </IfModule>
    4. Save the changes.
    5. Restart the OMS:
  8. Configure your proxy server as described in Appendix C.
  9. (Optional) If you want to change the passwords of SYSMAN and all other internal user accounts such as SYSMAN_MDS, SYSMAN_OPSS, and SYSMAN_APM, then shut down the OMS, run the following command from the OMS home, and then restart the OMS. You will be prompted to enter the old and the new password.
    <OMS_HOME>/bin/emctl config oms -change_repos_pwd
    This command concurrently changes the passwords in both the OMS configuration and the database for these affected user accounts. Therefore, it is sufficient to run this command just once.
  10. An encryption key is generated to encrypt sensitive data in the Management Repository. If this key is lost, all encrypted data in the Management Repository become unusable. Therefore, back up the Management Service configuration including the emkey, and maintain the backup on another host.
    To back up the Management Service configuration including the emkey, run the following command:
    <OMS_HOME>/bin/emctl exportconfig oms -dir <path_to_backup_location>
  11. Before accessing the Enterprise Manager Cloud Control Console in a browser, install a security certificate from a trusted certification authority on the browser.
    This it to ensure that the Enterprise Manager Cloud Control Console that you are accessing over HTTPS protocol is recognized as a genuine and secure Web site.
    For instructions to install a security certificate on your browser and avoid security certificate alerts, refer to Oracle Enterprise Manager Cloud Control Administrator's Guide.
