Go to primary content
Oracle® Functional Testing OpenScript Programmer's Reference
Release 13.3.0.1
E37832-12
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
10 Applet Module
This chapter provides a complete listing and reference for the methods in the OpenScript AppletService Class of Applet Module Application Programming Interface (API).
10.1 AppletService API Reference
The following section provides an alphabetical listing of the methods in the OpenScript AppletService API.
10.1.1 Alphabetical Command Listing
The following table lists the AppletService API methods in alphabetical order.
Table 10-1 List of AppletService Methods
Method Description
applet.applet
Identifies an applet object by its path.
applet.appWindow
Identifies a top window object that doesn't have an owner, by its path.
applet.button
Identifies a button object by its path.
applet.checkBox
Identifies a check box object by its path.
applet.comboBox
Identifies a combo box object by its path.
applet.dialog
Identifies a dialog object by its path.
applet.dtree
Identifies a DTree object by its path.
applet.expansionTree
Identifies an expansion tracking tree by its path.
applet.grid
Identifies a grid object by its path.
applet.infiniteScrollBar
Identifies a infinite scroll bar object by its path.
applet.javaObject
Identifies a component object by its path if this component could not be recognized as a specific type of object.
applet.label
Identifies a label object by its path.
applet.list
Identifies a list object by its path.
applet.mdiChild
Identifies a mdiChild object by its path.
applet.menu
Identifies a menu object by its path.
applet.radioButton
Identifies a radio button object by its path.
applet.scrollBar
Identifies a scroll bar object by its path.
applet.tab
Identifies a tab bar object by its path.
applet.tabbedPage
Identifies a tabbed page object by its path.
applet.table
Identifies a table object by its path.
applet.textField
Identifies a text field object by its path.
applet.textView
Identifies a text view object by its path.
applet.timeBrowser
Identifies a time browser object by its path.
applet.timeline
Identifies a time line object by its path.
applet.toolBar
Identifies a tool bar object by its path.
applet.treeBrowser
Identifies a tree browser object by its path.
applet.treeView
Identifies a tree view object by its path.
applet.window
Identifies a Java window object by its path.
The following sections provide detailed reference information for each method and enum in the AppletService Class of Applet Module Application Programming Interface.
applet.applet
Format
The applet.applet method has the following command format(s):
applet.applet(recId, scriptId);
Command Parameters
recId
the ID of a previously recorded navigation, used for comparison purposes.
scriptId
a String specifying the path to identify the applet object.
Throws
Exception
on any error.
Returns
the applet object.
Example
applet.applet(399, "/applet:TApplet[@text='Oracle Applications' " +
 "or @posIndex='1']");
applet.appWindow
Format
The applet.appWindow method has the following command format(s):
applet.appWindow(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the window object.
Throws
Exception
on any error.
Returns
the window object.
Example
Performs an action on a window object specified by its path.
TJavaAppWindow window = applet.appWindow(399, "/applet:TJavaAppWindow[@text='Oracle Applications' " +
applet.button
Format
The applet.button method has the following command format(s):
applet.button(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the button object.
Throws
Exception
on any error.
Returns
the button object.
Example
Performs an action on a button object specified by its path.
applet.button(2967, "/applet:TJavaDialog[@posIndex='0']" +
 "/applet:TJavaButton[@text=' OK ' or @posIndex='0']")
 .click();
applet.checkBox
Format
The applet.checkBox method has the following command format(s):
applet.checkBox(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the check box object.
Throws
Exception
on any error.
Returns
Example
Performs an action on a check box object specified by its path.
applet.checkBox(8956, "/applet:TJavaDialog[@text='Source Questions - " +
  "Create Conditional Blocks' or @posIndex='0']" +
 "/applet:TJavaCheckbox[@text='AE_ANY1' or @posIndex='0']")
 .setCheck(true);
applet.comboBox
Format
The applet.comboBox method has the following command format(s):
applet.comboBox(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the combo box object.
Throws
Exception
on any error.
Returns
Example
Performs an action on a combo box object specified by its path.
applet.comboBox(8092, "/applet:TJavaDcmLayoutEditor[" +
  "@text='AE_IND SUBSET 1 LAYOUT 1 Adverse Events' or @posIndex='4']" +
 "/applet:TJavaToolbar[@posIndex='0']" +
 "/applet:TJavaCombobox[@posIndex='0']")
 .selectItem("200%");
applet.dialog
Format
The applet.dialog method has the following command format(s):
applet.dialog(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the dialog object.
Throws
Exception
on any error.
Returns
the dialog object.
Example
Performs an action on a dialog object specified by its path.
TJavaDialog dialog = applet.dialog(1097,"/applet:TJavaDcmLayoutEditor " +
  "[@text='AE_IND SUBSET 1 " +
  "LAYOUT 1 Adverse Events' or @posIndex='4']" +
 "/applet:TJavaDialog[@text='Validation' or @posIndex='-1']");
applet.dtree
Format
The applet.dtree method has the following command format(s):
applet.dtree(recId, xPath);
Command Parameters
recId
xPath
a String specifying the path to identify the DTree object.
Throws
Exception
on any error.
Returns
the DTree object.
Example
Performs an action on a DTree object specified by its path.
applet.dtree(110, "/applet:TJavaWindow[@text='Edit Schedule' " +
 "/applet:TJavaDTree[@posIndex='0']")
 .selectNode("49010");
Format
The applet.expansionTree method has the following command format(s):
applet.expansionTree(recId, xPath);
Command Parameters
recId
xPath
a String specifying the path to identify the expansion tracking tree object.
Throws
Exception
on any error.
Returns
Example
Performs an action on an expansion tracking tree object specified by its path.
applet.expansionTree(3284,"/applet:TJavaWindow[@text='Flow Workstation  (M1)' " +
  "or @posIndex='3']" +
 "/applet:TJavaExpansionTree[@posIndex='0']")
 .expandNode("Vision Pad:CASE|Assemblies");
applet.grid
Format
The applet.grid method has the following command format(s):
applet.grid(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the grid object.
Throws
Exception
on any error.
Returns
the grid object.
Example
Performs an action on a grid object specified by its path.
applet.grid(3490, "/applet:TJavaWindow[@text='Edit Schedule' " +
  "or @posIndex='5']" +
 "/applet:TJavaGrid[@posIndex='0']")
 .editCell(3, 1);
Identifies a infiniteScrollBar object by its path.
Format
The applet.infiniteScrollBar method has the following command format(s):
applet.infiniteScrollBar(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the infiniteScrollBar object.
Throws
Exception
on any error.
Returns
Example
Performs an action on a infiniteScrollBar object specified by its path.
applet.infiniteScrollBar(152, "/applet:TJavaWindow[@text='Job Scheduling Workbench' " +
  or @posIndex='3']
 "/applet:TJavaInfiniteScrollBar[@posIndex='0']")
 .scroll(-349);
applet.javaObject
Identifies a component object by its path if this component could not be recognized as a specific type of object. Gives a default representation to the component object.
Format
The applet.javaObject method has the following command format(s):
applet.javaObject(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the Java object.
Throws
Exception
on any error.
Returns
Example
Performs an action on a component object specified by its path.
applet.javaObject(6315, "/applet:TJavaObject[@posIndex='4']")
 .click();
applet.label
Format
The applet.label method has the following command format(s):
applet.label(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the label object.
Throws
Exception
on any error.
Returns
the label object.
Example
Identifies a label object specified by its path.
TJavaLabel label = applet.label(533, "/applet:TJavaWindow[@text='Filter' " +
  "or @posIndex='4']" +
 "/applet:TJavaLabel[@text='Date' or @posIndex='8']");
applet.list
Format
The applet.list method has the following command format(s):
applet.list(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the list object.
Throws
Exception
on any error.
Returns
the list object.
Example
Performs an action on a Java list object specified by its path.
String selected = applet.list(533, "/applet:TJavaWindow[@text='Filter' " +
 "/applet:TJavaList[@text='Names' or @posIndex='8']")
 .getSelected();
applet.mdiChild
Format
The applet.mdiChild method has the following command format(s):
applet.mdiChild(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the mdiChild object.
Throws
Exception
on any error.
Returns
Example
Performs an action on a mdiChild object specified by its path.
applet.mdiChild(533, "/applet:TJavaWindow[@text='Filter' " +
 "/applet:TJavamdiChild[@text='Names' or @posIndex='8']")
 .setActive();
applet.menu
Format
The applet.menu method has the following command format(s):
applet.menu(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the menu object.
Throws
Exception
on any error.
Returns
the menu object.
Example
Performs an action on a menu object specified by its path.
applet.menu(53, "/applet:TJavaWindow[@text='Filter' " +
 "/applet:TJavaMenu[@text='Edit' or @posIndex='2']")
 .menuClick();
applet.radioButton
Format
The applet.radioButton method has the following command format(s):
applet.radioButton(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the radio button object.
Throws
Exception
on any error.
Returns
Example
Performs an action on a radio button object specified by its path.
applet.radioButton(533, "/applet:TJavaWindow[@text='Filter' " +
 "/applet:TJavaRadioButton[@text='Date' or @posIndex='8']")
 .select();
applet.scrollBar
Format
The applet.scrollBar method has the following command format(s):
applet.scrollBar(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the scroll bar object.
Throws
Exception
on any error.
Returns
Example
Performs an action on a scroll bar object specified by its path.
applet.scrollBar(6658, "/applet:TJavaDcmLayoutEditor[@text='AE_IND SUBSET 1 " +
 "/applet:TJavaScrollbar[@posIndex='0']")
 .setPosition(0);
applet.slider
Identifies a slider object by its path.
Format
The applet.slider method has the following command format(s):
applet.slider(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the slider object.
Throws
Exception
on any error.
Returns
the slider object.
Example
Performs an action on a slider object specified by its path.
applet.slider(725,"/applet:TJavaWindow[@text='Flow Workstation  (M1)' " +
 "/applet:TJavaSlider[posIndex=0 and tClass='TJavaSlider']")
 .setPosition(3);
applet.tab
Format
The applet.tab method has the following command format(s):
applet.tab(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the tab bar object.
Throws
Exception
on any error.
Returns
the tab bar object.
Example
Performs an action on a tab bar object specified by its path.
applet.tab(725,"/applet:TJavaWindow[@text='Flow Workstation  (M1)' " +
 "/applet:TJavaTabBar[posIndex=0 and tClass='TJavaTabBar']")
 .select("Properties");
applet.tabbedPage
Identifies a tabbedPage object by its path.
Format
The applet.tabbedPage method has the following command format(s):
applet.tabbedPage(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the tabbed page object.
Throws
Exception
on any error.
Returns
the tabbedPage object.
Example
Performs an action on a tabbedPage object specified by its path.
applet.tabbedPage(725,"/applet:TJavaWindow[@text='Flow Workstation  (M1)' " +
 "/applet:TJavaTabbedPage[posIndex=0 and tClass='TJavaTabbedPage']")
 .selectByIndex(2);
applet.table
Format
The applet.table method has the following command format(s):
applet.table(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the table object.
Throws
Exception
on any error.
Returns
the table object.
Example
Performs an action on a table object specified by its path.
applet.table(725,"/applet:TJavaWindow[@text='Flow Workstation  (M1)' " +
 "/applet:TJavaTable[posIndex=0 and tClass='TJavaTable']")
 .selectCell(1, 1, "");
applet.textField
Format
The applet.textField method has the following command format(s):
applet.textField(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the text field object.
Throws
Exception
on any error.
Returns
Example
Performs an action on a text field object specified by its path.
applet.textField(7945, "/applet:TJavaDcmLayoutEditor[@text='AE_IND SUBSET 1 " +
 "/applet:TJavaTextfield[@posIndex='31']")
 .setText("Owner");
applet.textView
Identifies a textView object by its path.
Format
The applet.textView method has the following command format(s):
applet.textView(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the textView object.
Throws
Exception
on any error.
Returns
Example
Performs an action on a textView object specified by its path.
applet.textView(7945, "/applet:TJavaDcmLayoutEditor[@text='AE_IND SUBSET 1 " +
 "/applet:TJavaTextView[@posIndex='31']")
 .getSelectedText();
applet.timeBrowser
Format
The applet.timeBrowser method has the following command format(s):
applet.timeBrowser(recId, xPath);
Command Parameters
recId
xPath
a String specifying the path to identify the time browser object.
Throws
Exception
on any error.
Returns
Example
Performs an action on a time browser object specified by its path.
applet.timeBrowser(145, "/applet:TJavaWindow[@text='Job Scheduling Workbench' " +
 "/applet:TJavaTimeBrowser[@posIndex='0']")
 .move("243645 : XA1000", "07-DEC-2006 17:03:00", "05-DEC-2006 15:45:55");
applet.timeline
Format
The applet.timeline method has the following command format(s):
applet.timeline(recId, xPath);
Command Parameters
recId
xPath
a String specifying the path to identify the time line object.
Throws
Exception
on any error.
Returns
Example
Performs an action on a time line object specified by its path.
applet.timeline(186, "/applet:TJavaWindow[@text='Job Scheduling Workbench' " +
 "/applet:TJavaTimeline[@posIndex='0']")
 .selectPopupMenu("Months");
applet.toolBar
Format
The applet.toolBar method has the following command format(s):
applet.toolBar(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the tool bar object.
Throws
Exception
on any error.
Returns
Example
Performs an action on a tool bar object specified by its path.
applet.toolBar(7086, "/applet:TJavaDcmLayoutEditor[@text='AE_IND SUBSET 1 " +
 "/applet:TJavaToolbar[@posIndex='0']")
 .clickItemByLabel("Center items horizontally");
applet.treeBrowser
Identifies a treeBrowser object by its path.
Format
The applet.treeBrowser method has the following command format(s):
applet.treeBrowser(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the treeBrowser object.
Throws
Exception
on any error.
Returns
Example
Performs an action on a tree browser object specified by its path.
applet.treeBrowser(145, "/applet:TJavaWindow[@text='Job Scheduling Workbench' " +
 "/applet:TJavaTreeBrowser[@posIndex='0']")
 .click();
applet.treeView
Identifies a treeView object by its path.
Format
The applet.treeView method has the following command format(s):
applet.treeView(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the treeView object.
Throws
Exception
on any error.
Returns
Example
Performs an action on a treeView object specified by its path.
in count = applet.treeView(145, "/applet:TJavaWindow " +
 "[@text='Job Scheduling Workbench' " +
 "/applet:TJavaTreeView[@posIndex='0']")
 .itemCount();
applet.window
Format
The applet.window method has the following command format(s):
applet.window(recId, scriptId);
Command Parameters
recId
scriptId
a String specifying the path to identify the Java window object.
Throws
Exception
on any error.
Returns
Example
applet.window(145, "/applet:TJavaWindow " +
 "/applet:TJavaWindow[@posIndex='0']")
 .close();
