Go to primary content
Oracle® Application Express Application Builder User's Guide
Release 5.0
E39147-04
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
12.3 Creating Charts
This section describes how to create charts in Oracle Application Express. Application Builder includes built-in wizards for generating Flash and HTML5 charts, and supports the editing of SVG and HTML charts. Oracle Application Express supports only these four types of graphical charts.
12.3.1 About Chart Types
This section describes the different types of charts you can create in Application Builder.
12.3.1.1 About HTML5 Charts
HTML5 chart support in Oracle Application Express is based on the AnyChart HTML5 Chart Component. AnyChart is a flexible Flash and JavaScript (HTML5) based solution that enables developers to create animated and compact interactive charts. HTML5 charts use a JavaScript chart engine, rendering the chart in SVG format. Flash cannot be rendered on most of the modern mobile devices, however you can now take advantage of our new HTML5 charting solution to incorporate charts in your mobile applications. HTML5 charts are compatible with popular browsers for the following mobile platforms:
  • Android: Versions 3.1, 3.2, 4.0, 4.0.3, and 4.1
  • IOS (iPhone, iPad, iPod Touch): Safari 3.2 and higher is required
To learn more see:
http://6.anychart.com/products/anychart/docs/
12.3.1.2 About Flash Charts
Flash chart support in Oracle Application Express is based on the AnyChart Flash Chart Component. AnyChart is a flexible Flash and JavaScript-based solution that enables developers to create animated, compact, interactive charts. Flash charts are rendered by a browser and require Flash player 9 or later. With AnyChart 6.0, Flash charts are rendered using the FLASH_PREFERRED rendering type. If Flash Player is not available on the device displaying the chart (for example, pages displayed on an iPhone), AnyChart automatically switches to the HTML5 chart engine and displays an SVG-based chart.
12.3.2 Creating SQL Queries for Charts
This section describes the supported syntax for creating charts in Application Builder.
12.3.2.1 Standard Chart Syntax
You define a chart in Application Builder using a wizard. For most chart wizards, you select a chart type and provide a SQL query using the following syntax:
SELECT link, label, value
FROM   ...
Where:
  • link is a URL.
  • label is the text that displays in the bar.
  • value is the numeric column that defines the bar size.
For example:
SELECT null, last_name, salary
FROM   employees
WHERE  DEPARTMENT_ID = :P101_DEPARTMENT_ID
12.3.2.2 Dial Chart Syntax (Flash and HTML5)
To create a dial chart, select a dial chart type and provide a SQL query using the following syntax:
SELECT value , maximum_value [ ,low_value [ ,high_value] ]
FROM   ...
Where:
  • value is the starting point on the dial.
  • maximum_value is the possible highest point on the dial.
  • low_value and high_value are the historical low and high values.
For example:
SELECT dbms_random.value(500, 1200), 1300, dbms_random.value(100, 200)
FROM DUAL
12.3.2.3 Multiple Series Syntax (Flash and HTML5)
For column charts and line charts, you can define multiple series in one SQL query. The series names for these chart types are derived from the corresponding column aliases in the query. To define a multiple series chart, use the following syntax:
SELECT link, label, series_1_value [, series_2_value [, ...]]
FROM   ...
12.3.2.4 Range Chart Syntax (Flash and HTML5)
Range charts require two values for each bar. To create a range chart, create a chart and provide a SQL query using the following syntax:
SELECT link, label, low_value, high_value
FROM   ...
12.3.2.5 Scatter Chart Syntax (Flash and HTML5)
Scatter charts require an x value and y value for each point. To create a range chart, create a chart and provide a SQL query using the following syntax:
SELECT link, label, x_value, y_value
FROM   ...
12.3.2.6 Candlestick Chart Syntax (Flash and HTML5)
Candlestick charts require open, low, high, and close values for each candlestick. To create a candlestick chart, create a chart and provide a SQL query using the following syntax:
SELECT link, label, open, low, high, close
FROM   ...
12.3.2.7 Gantt Chart Syntax (Flash Only)
Project Gantt charts require a task name, task id, parent task id, actual start date, actual_end_date, and progress value for each task. Two optional values for planned start date and planned end date can also be used. To create a Project Gantt chart, create a Flash chart and provide a SQL query using the following syntax:
SELECT link, task_name, task_id, parent_task_id, actual_start_date, actual_end_date, progress
FROM   ...
Resource Gantt charts require a resource id, resource name, parent resource id, actual start date, and actual end date value for each task. To create a Resource Gantt chart, create a Flash chart and provide a SQL query using the following syntax:
SELECT link, resource_id, resource_name, resource_parent_id, actual_start_date, actual_end_date
FROM   ...
To represent parent-child hierarchical data on a Resource Gantt chart, provide a SQL query using START WITH..CONNECT BY syntax:
SELECT link,
           resource_id,
           resource_name,
           resource_parent_id,
           actual_start_date,
           actual_end_date,
FROM ...
START WITH resource_parent_id IS NULL
CONNECT BY PRIOR resource_id = resource_parent_id
ORDER SIBLINGS BY resource_name
12.3.3 Adding a Chart to a New Page
To add a chart on a new page:
  1. On the Workspace home page, click the Application Builder icon.
  2. Select an application.
  3. Click Create Page.
  4. For Create a Page:
    1. User Interface - Select a user interface for the page.
    2. Select a page type - Select Chart.
    3. Click Next.
  5. For Chart Type:
    1. Chart Rendering - Select a chart type. See "About Chart Types."
    2. Chart Type - Specify a chart type. Depending upon the chart type, you may be prompted to make additional selections.
    3. Click Next.
  6. For Page and Region Attributes:
    1. Page Number - Select a page in which the chart object is to appear.
    2. Page Name - If creating a new page, enter a page name.
    3. Page Mode - Select a page mode.
      To learn more, see field-level Help. See "Viewing Field-Level Help."
    4. Page Group - Identify the name of the page group you would like to associate with this page.
    5. Region Template - Select a region template for the region in which this chart is to appear.
    6. Region Name - Enter a name for the region.
    7. Navigation List - New pages can be added to an existing navigation list, either as top level entries, or as links in the navigation list hierarchy. Click Configure to add your page to the navigation list.
    8. Breadcrumb - Select whether you want to use a breadcrumb navigation control on your page.
    9. Click Next.
  7. For Navigation Preference, specify the type of navigation to include on this page and click Next. The navigation options (for example, navigation menu or tabs) depends upon the current application theme.
  8. For Chart Attributes, specify the appropriate attributes and click Next.
    To learn more about an attribute, see field-level Help. See "Viewing Field-Level Help."
  9. For Query:
    1. Specify a query by either:
      • Entering a SQL query in the field provided. See "Creating SQL Queries for Charts."
      • Clicking the Build Query button. When the Build Chart Query Wizard appears, follow the on-screen instructions.
    2. Specify relevant chart attributes.
    3. Click Next.
  10. Click Create.
12.3.4 Managing Charts in Page Designer
This section describes how to create and edit charts in Page Designer.
12.3.4.1 Adding a Chart in Page Designer
To add a chart to an existing page in Page Designer:
  1. View the page to contain the item in Page Designer. See "Viewing a Page in Page Designer."
  2. From the Gallery select the Chart region and drag it to the appropriate location in Grid Layout.
    Tip:
    You also right-click Tree region, select Add To, and select the appropriate location.
    Page Designer indicates what actions are required next.
    The Messages tab displays a red or yellow badge indicating messages you need to address. The Message tab displays two types of messages:
    • Errors - Error messages display in red. Selecting an error message displays the associated attribute in red in the Property Editor. You must address errors before a page can be saved.
    • Warnings - Warning messages display in yellow. Selecting a warning message displays the associated attribute in yellow in the Property Editor. You must address errors before a page can be saved. Note you can save a page without addressing warning messages.
  3. View all attributes in the Property Editor. Select Show All from the Property Editor Menu.
  4. In Property Editor - Region, edit the required attributes.
    Required attributes display a red triangle in the upper left corner next above attribute label.
    Tip:
    To learn more about an attribute, select the attribute in the Property Editor and click the Help tab in the center pane.
  5. Edit the chart attributes:
    1. In the Rendering tree, select the Attributes node.
      Property Editor - Attributes appears.
    2. Edit the required chart attributes.
    3. Click Next.
  6. Edit the series:
    1. In the Rendering tree, select the Series node.
      Property Editor - Series appears.
    3. Click Next.
  7. Click Save.
12.3.4.2 Editing Chart Attributes in Page Designer
Once you have created a chart, you can alter its display by editing chart attributes on the Chart Attributes page.
The deprecated chart type SVG cannot be edited using Page Designer.
To access the Chart Attributes page:
  1. View the page to contain the chart in Page Designer. See "Viewing a Page in Page Designer."
  2. In the Rendering tree, select the Attributes node.
  4. Edit the chart attributes.
  5. Click Save.
12.3.4.3 Switching an HTML5 Chart to a Flash Chart
Once you create an HTML5 chart, you can switch its rendering to Flash by editing chart attributes on the Chart Attributes page.
To switch an HTML5 chart to a Flash Chart:
  3. Expand the Appearance section.
  4. For Appearance, Rendering, select Flash Chart.
  5. Click Save.
12.3.4.4 Enabling Asynchronous Updates
SVG, Flash, and HTML5 charts can monitor information by enabling the Asynchronous Update attribute on the Chart attributes page or using a dynamic action with the Refresh action.
12.3.4.4.1 Enabling the Asynchronous Update Attribute
Enabling the Asynchronous Update attribute updates the chart to reflect changes in the underlying data within a specified time interval.
To enable asynchronous updates:
  4. For Automatic Refresh, select Yes.
  5. Click Save.
12.3.4.4.2 Creating a Refresh Dynamic Action in Page Designer
To create a Refresh dynamic action:
  2. Click the Dynamic Actions accordion on the left side of the page, beneath the Rendering tree.
  3. Under Dynamic Actions, right-click Events and select Create Dynamic Action.
    Attributes for the dynamic action display in the Property Editor.
    Tip:
    The Messages tab displays a red or yellow badge to identify messages you need to address. Selecting a message displays the associated attribute in the Property Editor. You must address red error message before you can save.
  4. View all attributes in the Property Editor. Select Show All from the Property Editor Menu.
  5. Under Property Editor - Dynamic Actions, edit the following attributes:
    Tip:
    1. Identification, Name - Enter a name of the dynamic action.
    2. Execution Options, Sequence - Specify the sequence for this component. The sequence determines the order of evaluation.
    3. When, Event - Specify the event that causes the dynamic action to fire.
    4. When, Selection Type - Select the type of page element or construct to be used to trigger the event. For examples, select the attribute in the Property Editor and click the Help tab in the center pane.
    5. Click Next.
    Next, define the action that to be performed if the event evaluates to True.
  6. In the Rendering tree, select the first action under True:
    1. Action - Select Refresh.
    2. Selection Type - Select Region.
    3. Region - Select the region containing the chart.
  7. Click Save.
12.3.5 Managing Charts in Component View
This section describes how to create and manage charts in Component View.
12.3.5.1 Adding an Chart in Component View
To add a chart to an existing page in Component View:
  1. Navigate to the page. See "Viewing a Page in Component View".
  2. Create a new region. Under Region, click the Create icon.
    The Create Region Wizard appears.
  3. On Create Region, select Chart and click Next.
  4. For Chart Type:
    3. Click Next.
  5. For Display Attributes:
    1. Title - Enter a title for the region. This title displays if the region template you choose displays the region title.
    2. Region Template - Enter a title for the region. This title displays if the region template you choose displays the region title.
    3. Parent Region - Defines the parent region to which the new region belongs to.
    4. Display Point - Identify a display point for this region. To learn more, see field-level Help.
    5. Click Next.
  6. For Chart Attributes, specify the appropriate attributes and click Next.
  7. For Source:
  8. For Conditional Display:
    1. Condition Type - Select a condition type from the list that must be met in order for this component to be rendered processed. See "Understanding Conditional Rendering and Processing."
    2. Authorization Scheme - Optionally select an authorization scheme which must evaluate to TRUE in order for this component to be rendered or otherwise processed. See "Providing Security Through Authorization."
    3. Click Create Region.
12.3.5.2 Switching an HTML5 Chart to a Flash Chart
  2. Access the Chart Attributes page:
    1. Under Region, select the region name.
      The Region Definition appears.
    2. Click Chart Attributes.
  3. For Chart Type:
    1. Chart Rendering - Select Flash Chart.
    2. Chart Type - Specify a chart type. Note that 3D chart types are only supported for Flash charts, so you may want to change the chart type to use one of the 3D options.
  4. Click Apply Changes.
12.3.5.3 Editing Chart Attributes in Component View
  1. Navigate to the page. See "Viewing a Page in Component View."
  2. Access the Chart Attributes page. Under Region, select the region name.
  3. Edit the appropriate attributes.
  4. To learn more about an attribute, see field-level Help. See "Viewing Field-Level Help."
  5. Click Apply Changes.
12.3.5.4 Enabling Asynchronous Updates
12.3.5.4.1 Enabling the Asynchronous Update Attribute
  1. Navigate to the Chart Attributes page. See "Editing Chart Attributes in Component View."
    The Chart Attributes page appears.
  2. Scroll down to Refresh.
  3. From Asynchronous Update, select Yes.
  4. In Update Interval (Seconds), enter the interval in seconds between chart updates. For optimal performance, select an interval that is greater than 2 seconds.
12.3.5.4.2 Creating a Refresh Dynamic Action
  1. Navigate to the page containing the chart. See "Viewing a Page in Component View."
  2. Locate the Dynamic Action section and click Create.
  3. For Identification:
    1. Name - Enter a name of the dynamic action.
    2. Sequence - Specify the sequence for this component. The sequence determines the order of evaluation.
    3. Click Next.
  4. For When:
    1. Event - Specify the event to trigger the firing of the dynamic action.
    2. Selection Type - Specify the selection type of the page elements that define when the dynamic action fires. See field-level Help to view examples for specific page items.
    3. Click Next.
  5. For True Action:
    2. Click Next.
  6. For Affected Elements:
    1. Selection Type - Select Region.
    2. Region - Select the region containing the chart.
    3. Click Next.
  7. Click Create Dynamic Action.
12.3.6 Understanding SVG Chart Support
Previous releases of Oracle Application Express supported the creation of SVG charts. Although existing SVG charts are still supported, Oracle Application Express no longer supports the creation of new SVG charts.
Tip:
You can only edit SVG charts in Component View.
12.3.6.1 Upgrading SVG Charts to HTML5
This section describes restrictions that apply when upgrading SVG charts to HTML5 and also describes the instructions for upgrading.
You can automatically upgrade single or multiple SVG charts to HTML5.
12.3.6.1.1 About SVG Chart Upgrade Restrictions
SVG charts can be upgraded with the following restrictions:
  • Only number formats defined in axis format strings are migrated. Date and time formats are ignored.
  • Number format elements containing the following are migrated:
    0,9,D,G,, (comma),. (period),$,C,L,FM
  • The label for each series in the HTML5 chart is derived from each series' column alias. This differs from SVG charts, where the label for each series is derived from the Series Name attribute.
  • In SVG charts, only the labels for the first series are used for the x-axis. In HTML5 charts, this has been enhanced so that all data appears, even if the data's label does not occur in the first series.
12.3.6.1.2 Upgrading an SVG Chart to HTML5
To upgrade an SVG chart to HTML5:
  3. From the Tasks list, click Upgrade to New HTML5 Chart.
  4. Click Upgrade.
12.3.6.1.3 Upgrading all SVG Charts in an Application to HTML5
To upgrade all SVG Charts to HTML5 charts:
    The Application Builder home page appears.
    The Application home page appears.
  3. Click Utilities and click Upgrade Application.
    The Upgrade Application Summary report appears.
  4. For Upgrade SVG Charts to HTML5 Charts, click the number of candidate objects.
  5. Select the objects to upgrade and click Upgrade.
12.3.6.2 Understanding SVG Chart Cascading Style Sheet Classes
When you create a SVG chart, Oracle Application Express renders it based on cascading style sheet (CSS) classes associated with the current theme. You can change the appearance of a chart by referencing another CSS or by overriding individual classes in the CSS section of the Edit Attributes page
The following sample contains the CSS classes for the dial chart in Sample Application. This example contains all the available CSS classes. Class names appear in boldface.
text{font-family:Verdana, Geneva, Arial, Helvetica, sans-serif;fill:#000000;}
tspan{font-family:Verdana, Geneva, Arial, Helvetica, sans-serif;fill:#000000;}
text.title{font-weight:bold;font-size:14;fill:#000000;}
text.moredatafound{font-size:12;}
rect.legend{fill:#EEEEEE;stroke:#000000;stroke-width:1;}
text.legend{font-size:10;}
#background{fill:#FFFFFF;stroke:none;}
rect.chartholderbackground{fill:#ffffff;stroke:#000000;stroke-width:1;}
#timestamp{text-anchor:start;font-size:9;}
text.tic{stroke:none;fill:#000000;font-size:12}
line.tic{stroke:#000000;stroke-width:1px;fill:none;}
#dial{stroke:#336699;stroke-width:2px;fill:#336699;fill-opacity:.5;}
#dial.alert{fill:#FF0000;fill-opacity:.5;}
#dialbackground{stroke:#000000;stroke-width:none;fill:none;filter:url(#MyFilter);}
#dialcenter{stroke:none;fill:#111111;filter:url(#MyFilter);}
#dialbackground-border{stroke:#DDDDDD;stroke-width:2px;fill:none;filter:url
(#MyFilter);}#low{stroke-width:3;stroke:#336699;}
#high{stroke-width:3;stroke:#FF0000;}
#XAxisTitle{letter-spacing:2;kerning:auto;font-size:14;fill:#000000;text-anchor:middle;}
#YAxisTitle{letter-spacing:2;kerning:auto;font-size:14;fill:#000000;text-anchor:middle;writing-mode:tb;}
.XAxisValue{font-size:8;fill:#000000;}
.YAxisValue{font-size:8;fill:#000000;text-anchor:end;}
.nodatafound{stroke:#000000;stroke-width:1;font-size:12;}
.AxisLine{stroke:#000000;stroke-width:2;fill:#FFFFFF;}
.GridLine{stroke:#000000;stroke-width:0.3;stroke-dasharray:2,4;fill:none;}
g.dataholder rect{stroke:#000000;stroke-width:0.5;}
.legenditem rect{stroke:#000000;stroke-width:0.5;}
Table 12-1 describes all supported CSS classes. Note that certain classes only apply to specific chart types.
Table 12-1 Available SVG Chart CSS Classes
Class Description
text
Defines the appearance of text that displays in a chart.
tspan
Defines the appearance of text that displays in a chart. tspan should match the definition of text.
text.title
Overrides the default chart text. Use this class for title text.
text.moredatafound
Defines the appearance of more datafound text.
rect.legend
Creates the rectangular box that holds the chart legend.
To remove the legend border, change rect.legend to the following:
rect.legend{fill:#CCCC99;stroke:none;}
text.legend
Defines the text that appears in the chart legend.
#background
Creates the entire background for the SVG plug-in.
For a solid white background with no border, change #background to the following:
#background{fill:#FFFFFF;stroke:#FFFFFF;stroke-width:2;}
Not applicable to pie and dial charts. Creates the background of the rectangle that holds the chart data.
For a clear background, change rect.chartholderbackground to the following:
rect.chartholderbackground(display:none;)
#timestamp
Only applicable if the Asynchronous Update chart attribute is set to Yes. Controls the appearance of the update timestamp test.
To disable the display of the timestamp, use defines #timestamp as follows in the Custom CSS, Inline attribute.
"#timestamp{display:none;}"
See Also: "Enabling Asynchronous Updates"
text.tic
Dial charts only. Defines the numbers on a dial chart.
line.tic
Dial charts only. Defines the graduation mark that displays directly beneath the number on a dial chart.
#dial
Dial charts only. Defines the value that displays on the dial chart.
#dial.alert
Dial charts only. Defines a value (called an alert value) that renders in a dial chart using a different display.
#dialbackground
Dial charts only. Creates the background of a dial chart.
#dialcenter
Dial charts only. Creates the center of the dial on a dial chart.
Dial charts only. Works with #dialbackground to create specific graphic effect.
#low
Dial charts only. Defines the historical low watermark of the data being displayed on a chart.
#high
Dial charts only. Defines the historical high watermark of the data being displayed on a chart.
#XAxisTitle
Defines the title that appears on the x-axis
#YAxisTitle
Defines the title that appears on the y-axis.
.XAxisValue
Defines the value that appears on the x-axis.
.YAxisValue
Defines the value that appears on the y-axis.
.AxisLabel
Similar to the axis value.
.nodatafound
Defines the text element that displays if no information is available.
.AxisLine
Indicates zero on charts that have negative values.
.GridLine
Creates the horizontal and vertical lines on the chart.
g.dataholder rect
Applies a blanket style to all data that displays in the chart.
.legenditem rect
Applies a blanket style to all rectangular items in the legend.
12.3.6.3 Referencing a Custom SVG Chart Cascading Style Sheet
You can reference a custom cascading style sheet for a chart using the CSS section of the Chart Attributes page. When you reference an external CSS, you can reference it entirely or simply override specific styles.
To reference a custom chart CSS:
  1. Upload the CSS to Application Builder. See "About Uploading Cascading Style Sheets".
  2. Navigate to the page containing the chart. See "Viewing a Page in Component View".
  3. Access the Chart Attributes page:
  4. On the Chart Attributes page, scroll down to the CSS section.
  5. From Use Custom CSS, select Yes.
  6. To reference an external CSS exclusively:
    1. In Custom CSS, Link, enter a link to a custom CSS. For example:
      #IMAGE_PREFIX#themes/theme_4/svg.css
    2. Specify that the CSS should be used exclusively. In Custom CSS, Inline enter the following:
  7. To reference a custom CSS and override specific styles:
    1. In Custom CSS, Link, enter a link to a custom style sheet. For example:
    2. In Custom CSS, Inline, enter the custom CSS styles you want to override.
12.3.6.4 Specifying Custom CSS Styles Inline for SVG Charts
You can override specific styles within the default CSS, using the Custom CSS, Inline attribute on the Chart Attributes page.
To override specific styles within the default CSS:
  1. Create a chart. See "Understanding SVG Chart Support."
  2. Navigate to the page. See "Viewing a Page in Component View."
  4. Scroll down to CSS.
  6. In Custom CSS, Inline, enter the custom CSS styles you want to override.
12.3.6.5 Displaying SVG Charts in Other Languages
To display an SVG chart in another language, you edit the text and tspan classes to reflect the correct language.
To display an SVG chart in another language:
  3. Scroll down to CSS.
  4. From Use Custom CSS, select Yes.
  5. In Custom CSS, Inline, edit the text and tspan classes to reflect the correct language. The following example demonstrates how to change a chart to Korean:
    text{font-family:Batang;fill:#000000;}
    tspan{font-family:Batang;fill:#000000;}
12.3.7 Understanding HTML Chart Support
Previous releases of Oracle Application Express supported the creation of HTML charts. Although existing HTML charts are still supported, Oracle Application Express no longer supports the creation of new HTML charts with the Create wizards. A new HTML chart region type plug-in is available for download from OTN. This plug-in enables users to create HTML chart regions in their applications.
12.3.7.1 Upgrading an HTML Chart to HTML5
To upgrade an HTML chart to HTML5:
  3. Navigate to the page. See "Viewing a Page in Component View".
  4. Access the Chart Attributes page:
  5. From the Tasks list, click Upgrade to HTML5 Chart.
  6. Click Upgrade.
12.3.7.2 Upgrading All HTML Charts to HTML5
To upgrade all HTML charts to HTML5:
  4. For Upgrade HTML Charts to HTML5 Charts, click the number of candidate objects.
12.3.8 About Saving Flash Charts
To support the saving of an image, AnyChart requires the use of a server-side script that resides on http://www.anychart.com. When you attempt to save an image, the data is sent to the server in Base64 encoding. It is then decoded on the server and the decoded response is returned.
If you want to support the saving of charts locally, you must host the decoding script on your local server. The Flash chart would also require you use of the AnyChart JavaScript function getPNG. By default, the chart region uses embedded HTML tags and does not use any AnyChart JavaScript calls. To make use of the AnyChart JavaScript call, you must modify the region source of your Flash charts.
See Also:
"Saving chart as image or vector file" in AnyChart User's Guide for more information on adding support to save Flash charts locally.
12.3.9 Using Custom XML with Flash and HTML5 Charts
There are additional chart settings that cannot be controlled using the standard attributes on the Chart attributes page. To further control the look and feel of a chart, you can use custom XML.
To use custom XML:
  1. Access the Chart Attributes page:
  2. Scroll down to Chart XML.
  3. From Use Custom XML, select Yes.
    If you select to use custom XML, regions with attributes that no longer apply are hidden. To display these regions again, select No for Use Custom XML.
  4. Edit the XML.
Tip:
For more information on supported chart XML formats, see the Online XML Reference at:
