Go to primary content
Oracle® Application Express Application Builder User's Guide
Release 5.0
E39147-04
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
18.1 Working with Shared Components
Shared components are common elements that can display or be applied on any page within an application. You can use the tools and wizards on the Shared Components page either at the application-level or on specific pages.
18.1.1 About the Advantages of Using Shared Components
Tabs, lists, breadcrumbs, and navigation bar entries are shared components. Shared components are common elements that can display or be applied on any page within an application. You can use the tools and wizards on the Shared Components page either at the application-level or on specific pages. The big advantage of shared components is that once you create them, you can add them to any page within your database application.
18.1.2 Accessing the Shared Components Page
To access the Shared Components page:
  1. On the Workspace home page, click Application Builder.
  2. Select an application.
  3. On the Application home page, click Shared Components.
    The Shared Components page appears.
  4. To create a shared component, select the appropriate link.
18.1.3 About the Shared Components Icon
Once you select an application, you access the Shared Components page by clicking the Shared Components icon at the top of the page. The Shared Components icon consists of a triangle above a circle and a square. This icon displays at the top of most Application Builder pages including the Application home page, Page Designer, Component View, Supporting Objects, and Utilities.
Description of shared_comp_icon.png follows
18.1.4 Shared Components Page
This section describes the regions and links on the Shared Components page.
18.1.4.1 Application Logic
Table 18-1 describes the links under Application Logic on the Shared Components page.
Table 18-1 Application Logic Links on the Shared Components Page
Link Description
Application Definition Attributes
Links to the Edit Application Definition page. Use this page to edit attributes for an application. Attributes are grouped into four categories: Definition, Security, Globalization, and User Interface.
See Also: "Managing Application Attributes"
Application Items
Application-level items do not display, but are used as global variables to the application. Commonly, you set the value of a page-level item using an application or page computations. .
See Also: "Managing Application-Level Items"
Application Processes
Use application processes to run PL/SQL logic:
  • At specific points for each page in an application
  • As defined by the conditions under which the process is set to execute
  • Upon the creation of a new session
Note that On Demand processes execute only when called from a page-level On Demand process or when called using Ajax from the browser.
See Also: "Understanding Application Processes"
Application Computations
Use application-level computations to assign values to application and page-level items for each page displayed or upon the creation of a new application session. You can also create an application-level computation and execute it conditionally on multiple pages.
See Also: "Understanding Application Computations"
18.1.4.2 Security
Table 18-2 describes the links under Security on the Shared Components page.
Table 18-2 Security Links on the Shared Components Page
Link Description
Security Attributes
Use the Edit Security Attributes page to configure general security attributes for all pages within an application.
See Also: "Configuring Security Attributes"
Authentication Schemes
Authentication is the process of establishing each user's identity before they can access your application. Authentication may require a user to enter a user name and password or may involve verification of a user's identity or use of a secure key.
See Also: "Establishing User Identity Through Authentication"
Authorization Schemes
Authorization restricts user access to specific controls or components based on predefined user privileges.
See Also: "Providing Security Through Authorization"
Session State Protection
Session State Protection is a built-in functionality that prevents hackers from tampering with the URLs within your application. URL tampering can adversely affect program logic, session state contents, and information privacy.
See Also: "Understanding Session State Protection"
Build Options
Use build options to conditionally display or process specific functionality within an application. You can use build options to control which features of an application are turned on for each application deployment.
See Also: "Using Build Options to Control Configuration".
18.1.4.3 Other Components
Table 18-3 describes the links under Security on the Shared Components page.
Table 18-3 Other Component Links on the Shared Components Page
Link Description
List of Values
A list of values (LOV) is a static or dynamic set of values used to display a popup list of values, select list, check box, or radio group.
See Also: "Creating Lists of Values at the Application Level"
Plug-ins
Application Builder includes built-in item types, region types, dynamic actions, and processes. Use plug-ins to add new declarative types in to your application.
See Also: "Implementing Plug-ins"
Component Settings
Use Component Settings to set application-level values for built-in Oracle Application Express components and installed plug-ins.
See Also: "Managing Component Settings"
Shortcuts
Use shortcuts to avoid repetitive coding of HTML or PL/SQL functions. You can create a shortcut to define a page control such as a button, HTML text, a PL/SQL procedure, or HTML. Once you define a shortcut, it is stored in a central repository so you can reference it from various locations within your application.
See Also: "Using Shortcuts"
18.1.4.4 Navigation
Table 18-4 describes the links under Navigation on the Shared Components page.
Table 18-4 Navigation Links on the Shared Components Page
Link Description
Lists
A list is a shared collection of links. You control the appearance of a list through list templates. Each list element has a display condition that enables you to control when it displays.
See Also: "Creating Lists"
Navigation Menu
A navigation menu is a list links that enables users to navigate the pages in an application. Navigation menus are only supported in applications using the Universal Theme - 42.
See Also: "About Navigation Menus"
Tabs
Tabs are an effective way to navigate users between pages in an application. You can create two types of tabs: standard tabs or parent tabs. A standard tab set is associated with a specific page and page number. A parent tab set functions as a container to hold a group of standard tabs.
See Also: "Creating Tabs"
Breadcrumbs
Breadcrumbs provide users with hierarchical navigation. A breadcrumb is a hierarchical list of links that display using templates. You can display a breadcrumb as a list of links or as a breadcrumb path.
See Also: "Creating Breadcrumbs"
Navigation Bar Entries
Navigation bar entries offer users a simple navigation path for moving between pages in an application. The location of a navigation bar depends upon the associated page template. Navigation bar entries can display as a link from an image or text. A navigation bar entry can be an image, an image with text beneath it, or text.
See Also: "Creating a Navigation Bar Entry"
18.1.4.5 User Interface
Table 18-5 describes the links under User interface on the Shared Components page.
Table 18-5 User interface Links on the Shared Components Page
Link Description
User Interface Attributes
Use User Interface page to specify user interface options for an application.
See Also: "Managing the Application User Interface"
Themes
A theme is a named collection of templates that defines the application user interface.
See Also: "Using Themes"
Templates
Templates control the look and feel of specific constructs within your application, such as pages, regions, items, and menus.
See Also: "Creating Custom Themes"
18.1.4.6 Files
Table 18-6 describes the links under User interface on the Shared Components page.
Table 18-6 Files Links on the Shared Components Page
Link Description
Static Application Files
Use this link to upload, edit, and delete static files associated with the current application, including style sheets (CSS), images and JavaScript files.
See Also: "Managing Static Application Files"
Static Workspace Files
See Also: "Managing Static Workspace Files"
18.1.4.7 Data References
Table 18-7 describes the links under User interface on the Shared Components page.
Table 18-7 Data References Links on the Shared Components Page
Link Description
Data Loading
Use Data Load Tables to define tables for use in the Data Loading create page wizard. A Data Load Table is an existing table in your schema that has been selected for use in the data loading process to upload data.
See Also: "Importing a Plug-in from the Plug-in Page"
Web Service References
Web service references in Application Builder are typically based on the Simple Object Access Protocol (SOAP) or Representational State Transfer (REST) architectures. You can create a reference to a Web service and then incorporate it into an application to process data submitted by a form, or to render output in the form or report.
See Also: "Implementing Web Services"
18.1.4.8 Reports
Table 18-8 describes the links under User interface on the Shared Components page.
Table 18-8 Data References Links on the Shared Components Page
Link Description
Report Queries
Use the Report Queries link to view a report of stored queries within the current application.
See Also: "Printing a Report Region by Defining a Report Query"
Report Layouts
Use Report Layouts with a report or shared query to render data in a printer-friendly format, such as Adobe Portable Document Format (PDF), Microsoft Word Rich Text Format (RTF), or Microsoft Excel (XLS) format.
See Also: "Formatting a Report Region or Report Query Using Report Layouts"
18.1.4.9 Globalization
Table 18-9 describes the links under User interface on the Shared Components page.
Table 18-9 Globalization Links on the Shared Components Page
Link Description
Globalization Attributes
You can develop applications that can run concurrently in different languages. Click this link to specify globalization options such as the Application Primary Language and Application Language Derived From attributes.
See Also: "Configuring Globalization Attributes" and "Understanding Application Translation and Globalization Support"
Text Messages
Text messages are named text strings that can be called from the PL/SQL code you write. This PL/SQL can be anonymous blocks within page processes and page regions, or in packages and procedures.
See Aso: "Translating Messages"
Translate Application
You can develop applications in Oracle Application Express that can run concurrently in different languages. A single Oracle database and Oracle Application Express instance can support an application in multiple languages. Translating an application involves multiple steps.
See Also: "Understanding Application Translation and Globalization Support" and "Understanding the Translation Process"
18.1.4.10 Tasks Region
The Tasks list on the right side of the Shared Components page contains these links:
