Go to primary content
Oracle® Application Express Application Builder User's Guide
Release 5.0
E39147-04
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
22.5 Utilizing Debug Mode
Debug mode enables you to track down unexpected application behavior. This section describes how to enable and disable debug mode, access debug mode using f?p syntax, and view debug reports.
See Also:
"APEX_DEBUG" in Oracle Application Express API Reference
22.5.1 About Debug Mode
The Debug mode is a built in mechanism used to track down unexpected application behavior. You enable and disable debug mode for the current page and session by clicking the Debug and No Debug links in the Runtime Developer Toolbar. To view Debug reports, click the View Debug link in the Runtime Developer Toolbar.
Description of dev_toolbar.png follows
If an application runs in debug mode, Oracle Application Express writes information about how it processes each page request to a log table. You can control the logging level of detail, add debug calls in your own code, and analyze the written log information.
When debug is enabled, Oracle Application Express also uses its non-minified JavaScript files to better isolate where possible issues may be coming from with client-side-code.
22.5.2 Enabling and Disabling Debug Mode for an Application
You can configure whether end users can run the application in debug mode by using the Debugging attribute on the Edit Application Definition page. A developer who is logged into workspace where the application resides can always run the application in debug mode.
To enable or disable debug mode:
  1. On the Workspace home page, click the Application Builder icon.
  2. Select an application.
  3. Click the Edit Application Properties button to the right of the application name.
    The Edit Application page appears.
  4. Scroll down to Properties.
  5. For Debugging:
    • Yes. Enables the application debug mode using the browser at runtime.
    • No. Disables the application debug mode using the browser at runtime.
22.5.3 Running an Application in Debug Mode
You run and disable debug mode at runtime by clicking Debug and No Debug on the Runtime Developer Toolbar. By default, Debugging mode is disabled, unless you are logged into the application's workspace as a developer.
To enable or disable Debug mode at runtime:
  2. Select the desired application.
  3. Run the application.
  4. On the Runtime Developer Toolbar, click Debug.
    The debugging mode is enabled. Debug data is captured in the background.
  5. To disable debug mode, on the Runtime Developer Toolbar, click No Debug.
22.5.4 Viewing Debug Reports in Development Mode
To view debug reports in development mode:
  3. Click Utilities.
  4. On the Utilities page, click Debug Messages.
    The Debug page appears.
  5. Click the View Identifier to the left of the session you want to view.
    The Debug Message Data page appears.
  6. To view steps that took the longest, hover over that step on the graph above the report.
    The step details display.
  7. To go to that step in the report, click the bar.
    Debug sessions listed in the report live for at least 2 weeks and age out along with the activity log. This is usually more than adequate for debugging purposes.
22.5.5 About Using f?p Syntax to Access Debug Mode
You can also use f?p syntax to run an application in Debugging mode. Simply call the page and set the Debug argument to YES or LEVELn, where n is between 1 (least detailed) and 9 (most detailed). For example:
f?p=100:1:&APP_SESSION.::YES
22.5.6 Viewing Debug Reports from a Running Application
To view debug report from a running application:
  1. Locate and run the application in Debug mode. See "Running an Application in Debug Mode."
  2. Click View Debug on the Runtime Developer Toolbar.
    A list of Debug reports displays.
  3. Click the View Identifier to the left of the session you want to view.
  4. To view steps that took the longest, hover over that step on the graph above the report.
  5. To go to that step in the report, click the bar.
22.5.7 Viewing Debug Reports
To view debug reports:
  1. Click the Find icon.
    Description of find_icon.png follows
    The Items Finder appears.
  2. Click the Debug tab.
    The Debug report appears.
