Go to primary content
Oracle® Application Express Application Builder User's Guide
Release 5.0
E39147-04
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
24.7 Importing Export Files
Once you export an application and any related files, you must import them into the target Oracle Application Express instance before you can install them. Note that you cannot import an application created in a specific release into an earlier version. As a general rule, always import the application first and then the related files.
Tip:
You can simplify the steps needed to deploy an application by creating a custom packaged application. See "How to Create a Custom Packaged Application".
24.7.1 Importing an Application, Page or Component Export
To import an Application, Page or Component Export into a target Oracle Application Express instance:
  1. Navigate to the Import page:
    1. On the Workspace home page, click the Application Builder icon.
    2. On the Application Builder home page, click Import.
  2. For Import:
    1. Import file - Navigate to the file.
    2. File Type - Select Application, Page, or Component Export.
    3. Verify that File Character Set is correct.
    4. Click Next.
    Once you import a file, you have the option to install it.
  3. To install the file, click Next.
    The Install Application wizard appears.
  4. For the Install wizard:
    1. Parsing Schema - Select a schema.
      This is the schema against which all of the application's SQL and PL/SQL are parsed.
    2. Build Status - Select one of the following:
      • Run Application Only - Users can only run an application.
      • Run and Build Application - Users can run an application and developers can both run and edit an application.
      Selecting Run Application Only is an effective way to protect an application from modifications from other developers.
      Tip:
      If you select Run Application Only, the only way to change this setting after you import the application is to log in to Oracle Application Express Administration Services. See "Changing Application Build Status Set During Deployment" in Oracle Application Express Administration Guide.
    3. Install As Application - Select one of the following:
      • Auto Assign New Application ID
      • Reuse Application ID From Export File
      • Change Application ID
      Use these options to avoid application ID conflicts. These options come in handy when you have two versions of the same application in the same instance. For example, you might be migrating an application to a production instance and still need to maintain the development version.
    4. Click Install Application.
24.7.2 About Importing Application Groups
Application groups are exported with an application, application exports include an group ID, name, and comments. When importing an application, the application import follows these rules:
  • On import, an application uses an existing group if the ID matches.
  • If no application group exists with the same ID on the target system, then application import looks for another group ID with the same name. If a name match is found, the application is imported with the ID corresponding to this application group name.
  • If no ID or name matches existing application groups on the target system then a new application group is created. The new application group uses the application group ID if that ID is not used in that Oracle Application Express instance. If the group ID is being used, then a new ID is generated.
24.7.3 Importing a Websheet
To import a Websheet into a target Oracle Application Express instance:
  2. For Specify File:
    2. File Type - Select Websheet Application Export.
    3. Click Next.
  3. To install an imported file, click Next.
  4. For the Install Application wizard:
    1. Install As Application - Select one of the following:
    2. Click Install.
24.7.4 Importing Plug-ins
To import an exported plug-in file:
    2. File Type - Select Plug-in.
    4. Click Next.
  4. Click Install Plug-in.
If the plug-in with the same name exists, a dialog displays requesting permission to write over the existing plug-in.
24.7.5 Importing Themes
After you import an application into the target Oracle Application Express instance, you must import all related files.
To import a Theme Export file:
  2. On Import Definition, select the following:
    2. File Type - Select Theme Export.
    3. File Character Set - Verify that File Character Set is correct.
    4. Click Next.
  4. Click Install Theme.
24.7.6 Importing User Interface Defaults
User Interface Defaults enables you to assign default user interface properties to a table, column, or view within a specified schema.
To import User Interface Defaults:
  2. Select an application.
  3. On Import Definition:
    2. File Type - Select User Interface Defaults.
    4. Click Next.
  4. To install an imported file, click Next.
  5. Click Install User Interface Defaults.
See Also:
"Managing User Interface Defaults" in Oracle Application Express SQL Workshop Guide and "Exporting User Interface Defaults"
24.7.7 Importing Team Development Feedback
To import Team Development Feedback:
  2. Select Feedback.
  3. For File Character Set, verify that File Character Set is correct and click Next.
  5. Click Install Feedback.
