Go to primary content
Oracle® Application Express Application Builder User's Guide
Release 5.0
E39147-04
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
21.5 Translating Data That Supports List of Values
You create a dynamic translation to translate dynamic pieces of data. For example, you might use a dynamic translation on a list of values based on a database query.
Dynamic translations differ from messages in that you query a specific string rather than a message name. You define dynamic translations on the Dynamic Translations page. You then use the APEX_LANG.LANG API to return the dynamic translation string identified by the p_primary_text_string parameter.
21.5.1 Defining a Dynamic Translation
You define dynamic translations on the Dynamic Translations page. A dynamic translation consists of a translate-from language string, a language code, and a translate-to string.
To define a dynamic translation:
  1. Navigate to the Translate Application page:
    1. On the Workspace home page, click the Application Builder icon.
    2. Select an application.
    3. Click Shared Components.
    4. Under Globalization, click Translate Application.
  2. On the Translate Application page under Translation Utilities, select Dynamic Translations.
  3. On the Dynamic Translations page, click Create and specify the following:
    1. Language - Select a target language.
    2. Translate From Text - Enter the source text to be translated.
    3. Translate To Text - Enter the translated text.
  4. Click Create.
