Go to primary content
Oracle® Application Express Application Builder User's Guide
Release 5.0
E39147-04
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
21.4 Translating Messages
This section describes when and how to translate messages is an Oracle Application Express application.
21.4.1 About Translating Messages
You may need to translate messages if your application:
  • Includes PL/SQL regions or PL/SQL processes, or calls a PL/SQL package, procedure, or function. If it does, you may need to translate the generated HTML.
  • Uses a language that is not one of the ten languages into which Oracle Application Express is translated. If it does, you may need to translate messages used in reports.
21.4.2 Translating Messages Used in PL/SQL Procedures
This section explains how to translate messages used in PL/SQL procedures.
21.4.2.1 About Translating Messages Used in PL/SQL Procedures
If your application includes PL/SQL regions or PL/SQL processes or calls PL/SQL package, procedures, or functions, you may need to translate generated HTML. First, you define each message on the Translatable Messages page. Second, you use the APEX_LANG.MESSAGE API to translate the messages from PL/SQL stored procedures, functions, triggers, or packaged procedures and functions.
21.4.2.2 Defining a Translation Message
You create translatable messages on the Translate Messages page.
To define a new translation message:
  1. Navigate to the Translate Application page:
    1. On the Workspace home page, click the Application Builder icon.
    2. Select an application.
    3. Click Shared Components.
    4. Under Globalization, click Text Messages.
  2. On the Translate Messages page, click Create Text Message.
  3. On Identify Text Message:
    1. Name - Enter a name to identify the message.
    2. Language - Select the language for which the message would be used.
    3. Used in JavaScript - Select Yes if the message is used in APEX.LANG API calls in JavaScript code.
    4. Text - Enter the text to be returned when the text message is called.
      For example, you could define the message GREETING_MSG in English as:
      Good morning %0
      Or, you could define the message GREETING_MSG in German as:
      Guten Tag %0
  4. Click Create Text Message.
21.4.3 Translating Messages Used Internally by Oracle Application Express
Oracle Application Express is translated into German, Spanish, French, Italian, Japanese, Korean, Brazilian Portuguese, Simplified Chinese, and Traditional Chinese. If your application uses a language that is not among the ten languages into which Oracle Application Express is translated, you must translate messages displayed by the Application Express reporting engine.
For example, if you develop a Russian application and want to include report messages, such as pagination, in Russian, you must translate the strings used in messages displayed in reports.
21.4.3.1 Creating Text Messages
To create a translation message:
  3. On Identify Text Message, specify the following:
    1. Name - Enter the name of each message that must be translated. See "Internal Messages Requiring Translation" and "Interactive Report Messages Requiring Translation."
    2. Language - Select the language for which the message will be used.
    3. Text - Enter the text to be returned when the text message is called. If the English text message contains positional substitution values (for example, %0, %1), ensure that your defined message also contains the same named and number of positional substitution values.
21.4.3.2 Editing Text Messages
To edit text messages:
  2. On edit a text message:
    1. Click the message name.
    2. Make the appropriate edits.
    3. Click Apply Changes.
  3. To access a Grid Edit page:
    1. Click Grid Edit.
      The Grid Edit page appears.
    Tip:
    To add a new message from the Grid Edit page, click Add Text Message at the bottom of the page.
21.4.3.3 Internal Messages Requiring Translation
Table 21-2 lists the internal messages that require translation.
Table 21-2 Internal Messages Requiring Translation
Message Name English Text
APEX.AUTHENTICATION.LOGIN_THROTTLE.COUNTER
Please wait <span id="apex_login_throttle_sec">%0</span> seconds to login again.
APEX.AUTHENTICATION.LOGIN_THROTTLE.ERROR
The login attempt has been blocked.
APEX.DATA_HAS_CHANGED
Current version of data in database has changed since user initiated update process. current checksum = "%0" application checksum = "%1".
APEX.DATEPICKER.ICON_TEXT
Popup Calendar: %0
APEX.DATEPICKER_VALUE_GREATER_MAX_DATE
#LABEL# is greater than specified maximum date %0.
APEX.DATEPICKER_VALUE_INVALID
#LABEL# does not match format %0.
APEX.DATEPICKER_VALUE_LESS_MIN_DATE
#LABEL# is less than specified minimum date %0.
APEX.DATEPICKER_VALUE_NOT_BETWEEN_MIN_MAX
#LABEL# is not between the valid range of %0 and %1.
APEX.DATEPICKER_VALUE_NOT_IN_YEAR_RANGE
#LABEL# is not within valid year range of %0 and %1.
APEX.FILE_BROWSE.DOWNLOAD_LINK_TEXT
Download
APEX.GO_TO_ERROR
Go to error
APEX.ITEM_TYPE.SLIDER.VALUE_NOT_BETWEEN_MIN_MAX
APEX.ITEM_TYPE.SLIDER.VALUE_NOT_MULTIPLE_OF_STEP
#LABEL# is not a multiple of %0.
APEX.ITEM_TYPE.YES_NO.INVALID_VALUE
#LABEL# must match to the values %0 and %1.
APEX.ITEM_TYPE.YES_NO.NO_LABEL
No
APEX.ITEM_TYPE.YES_NO.YES_LABEL
Yes
APEX.NUMBER_FIELD.VALUE_GREATER_MAX_VALUE
#LABEL# is greater than specified maximum %0.
APEX.NUMBER_FIELD.VALUE_INVALID
#LABEL# must be Numeric.
APEX.NUMBER_FIELD.VALUE_INVALID2
#LABEL# does not match number format %0 (For example, %1).
APEX.NUMBER_FIELD.VALUE_LESS_MIN_VALUE
#LABEL# is less than specified minimum %0.
APEX.NUMBER_FIELD.VALUE_NOT_BETWEEN_MIN_MAX
APEX.PAGE_ITEM_IS_REQUIRED
#LABEL# must have some value.
APEX.POPUP_LOV.ICON_TEXT
Popup List of Values: %0.
APEX.REGION.JQM_LIST_VIEW.SEARCH
Search
APEX.REGION.JQM_LIST_VIEW.LOAD_MORE
Load more
FLOW.SINGLE_VALIDATION_ERROR
1 error has occurred.
FLOW.VALIDATION_ERROR
%0 errors have occurred.
INVALID_CREDENTIALS
Invalid Login Credentials .
OUT_OF_RANGE
Invalid set of rows requested, the source data of the report has been modified.
PAGINATION.NEXT
Next
PAGINATION.NEXT_SET
Next Set
PAGINATION.PREVIOUS
Previous
PAGINATION.PREVIOUS_SET
Previous Set
REPORT_TOTAL
report total
RESET
reset pagination
SINCE_DAYS_AGO
%0 days ago
SINCE_DAYS_FROM_NOW
%0 days from now
SINCE_HOURS_AGO
%0 hours ago
SINCE_HOURS_FROM_NOW
%0 hours from now
SINCE_MINUTES_AGO
%0 minutes ago
SINCE_MINUTES_FROM_NOW
%0 minutes from now
SINCE_MONTHS_AGO
%0 months ago
SINCE_MONTHS_FROM_NOW
%0 months from now
SINCE_NOW
Now
SINCE_SECONDS_AGO
%0 seconds ago
SINCE_SECONDS_FROM_NOW
%0 seconds from now
SINCE_WEEKS_AGO
%0 weeks ago
SINCE_WEEKS_FROM_NOW
%0 weeks from now
SINCE_YEARS_AGO
%0 years ago
SINCE_YEARS_FROM_NOW
%0 years from now
TOTAL
Total
WWV_FLOW_UTILITIES.CAL
Calendar
WWV_FLOW_UTILITIES.CLOSE
Close
WWV_FLOW_UTILITIES.OK
Ok
WWV_RENDER_REPORT3.FOUND_BUT_NOT_DISPLAYED
Minimum row requested: %0, rows found but not displayed: %1
WWV_RENDER_REPORT3.SORT_BY_THIS_COLUMN
Sort by this column.
WWV_RENDER_REPORT3.UNSAVED_DATA
This form contains unsaved changes. Press Ok to proceed without saving your changes.
WWV_RENDER_REPORT3.X_Y_OF_MORE_THAN_Z
row(s) %0 - %1 of more than %2
WWV_RENDER_REPORT3.X_Y_OF_Z
row(s)%0 - %1 of %2
WWV_RENDER_REPORT3.X_Y_OF_Z_2
%0 - %1 of %2
21.4.3.4 Interactive Report Messages Requiring Translation
Table 21-3 lists the interactive report messages that require translation.
Table 21-3 Interactive Report Messages Requiring Translation
4150_COLUMN_NUMBER
Column %0
APEXIR_3D
3D
APEXIR_ACTIONS
Actions
APEXIR_ACTIONS_MENU
Actions Menu
APEXIR_ADD
Add
APEXIR_ADD_FUNCTION
Add Function
APEXIR_ADD_GROUP_BY_COLUMN
Add Group By Column
APEXIR_ADD_PIVOT_COLUMN
Add Pivot Column
APEXIR_ADD_ROW_COLUMN
Add Row Column
APEXIR_ADD_SUBSCRIPTION
Add Subscription
APEXIR_AGG_AVG
Average
APEXIR_AGG_COUNT
Count
APEXIR_AGG_MAX
Maximum
APEXIR_AGG_MEDIAN
Median
APEXIR_AGG_MIN
Minimum
APEXIR_AGG_MODE
Mode
APEXIR_AGG_SUM
Sum
APEXIR_AGGREGATE
Aggregate
APEXIR_AGGREGATE_DESCRIPTION
Aggregates are displayed after each control break and at the end of the report.
APEXIR_AGGREGATION
Aggregation
APEXIR_ALL
All
APEXIR_ALL_COLUMNS
All Columns
APEXIR_ALL_ROWS
All Rows
APEXIR_ALTERNATIVE
Alternative
APEXIR_ALTERNATIVE_DEFAULT_NAME
Alternative Default: %0
APEXIR_AND
and
APEXIR_APPLY
Apply
APEXIR_AS_OF
As of %0
APEXIR_ASCENDING
Ascending
APEXIR_AVERAGE_X
Average %0
APEXIR_BETWEEN
between
APEXIR_BGCOLOR
Background Color
APEXIR_BLUE
blue
APEXIR_BOTTOM
Bottom
APEXIR_CALENDAR
Calendar
APEXIR_CANCEL
Cancel
APEXIR_CATEGORY
Category
APEXIR_CELL
Cell
APEXIR_CHART
Chart
APEXIR_CHART_INITIALIZING
Initializing...
APEXIR_CHART_LABEL_NOT_NULL
Chart label must be specified
APEXIR_CHART_MAX_ROW_CNT
The maximum row count for a chart query limits the number of rows in the base query, not the number of rows displayed. Your base query exceeds the maximum row count of %0. Please apply a filter to reduce the number of records in your base query.
APEXIR_CHART_TYPE
Chart Type
APEXIR_CHECK_ALL
Check All
APEXIR_CHOOSE_DOWNLOAD_FORMAT
Choose report download format
APEXIR_CLEAR
clear
APEXIR_COLUMN
Column
APEXIR_COLUMN_FILTER
Filter...
APEXIR_COLUMN_HEADING
Column Heading
APEXIR_COLUMN_HEADING_MENU
Column Heading Menu
APEXIR_COLUMN_INFO
Column Information
APEXIR_COLUMN_N
Column %0
APEXIR_COLUMNS
Columns
APEXIR_COMPARISON_CONTAINS
contains
APEXIR_COMPARISON_DOESNOT_CONTAIN
does not contain
APEXIR_COMPARISON_IN
in
APEXIR_COMPARISON_IS_IN_LAST
is in the last
APEXIR_COMPARISON_IS_IN_NEXT
is in the next
APEXIR_COMPARISON_IS_NOT_NULL
is not null
APEXIR_COMPARISON_IS_NULL
is null
APEXIR_COMPARISON_ISNOT_IN_LAST
is not in the last
APEXIR_COMPARISON_ISNOT_IN_NEXT
is not in the next
APEXIR_COMPARISON_LIKE
like
APEXIR_COMPARISON_NOT_IN
not in
APEXIR_COMPARISON_NOT_LIKE
not like
APEXIR_COMPARISON_REGEXP_LIKE
matches regular expression
APEXIR_COMPUTATION
Computation
APEXIR_COMPUTATION_EXPRESSION
Computation Expression
APEXIR_COMPUTATION_FOOTER
Create a computation using column aliases.
APEXIR_COMPUTATION_FOOTER_E1
(B+C)*100
APEXIR_COMPUTATION_FOOTER_E2
INITCAP(B)||', '||INITCAP(C)
APEXIR_COMPUTATION_FOOTER_E3
CASE WHEN A = 10 THEN B + C ELSE B END
APEXIR_COMPUTE
Compute
APEXIR_CONTROL_BREAK
Control Break
APEXIR_CONTROL_BREAK_COLUMNS
Control Break Columns
APEXIR_CONTROL_BREAKS
Control Breaks
APEXIR_COUNT_DISTINCT
Count Distinct
APEXIR_COUNT_DISTINCT_X
Count Distinct
APEXIR_COUNT_X
Count %0
APEXIR_DAILY
Daily
APEXIR_DATA_AS_OF
Report data as of %0 minutes ago.
APEXIR_DATE
Date
APEXIR_DAY
Day
APEXIR_DEFAULT
Default
APEXIR_DEFAULT_REPORT_TYPE
Default Report Type
APEXIR_DELETE
Delete
APEXIR_DELETE_CHECKED
Delete Checked
APEXIR_DELETE_CONFIRM
Would you like to delete these report settings?
APEXIR_DELETE_CONFIRM_JS_DIALOG
Would you like to perform this delete action?
APEXIR_DELETE_DEFAULT_REPORT
Delete Default Report
APEXIR_DELETE_REPORT
Delete Report
APEXIR_DESCENDING
Descending
APEXIR_DESCRIPTION
Description
APEXIR_DETAIL_VIEW
Single Row View
APEXIR_DIRECTION
Direction
APEXIR_DISABLE
Disable
APEXIR_DISABLED
Disabled
APEXIR_DISPLAY
Display
APEXIR_DISPLAY_IN_REPORT
Display in Report
APEXIR_DISPLAYED
Displayed
APEXIR_DISPLAYED_COLUMNS
Displayed Columns
APEXIR_DO_NOT_AGGREGATE
- Do not aggregate -
APEXIR_DO_NOT_DISPLAY
Do Not Display
APEXIR_DOWN
Down
APEXIR_DOWNLOAD
Download
APEXIR_DUPLICATE_PIVOT_COLUMN
Duplicate pivot column. Pivot column list must be unique.
APEXIR_EDIT
Edit
APEXIR_EDIT_ALTERNATIVE_DEFAULT
Edit Alternative Default
APEXIR_EDIT_CHART
Edit Chart Settings
APEXIR_EDIT_CHART2
Edit Chart
APEXIR_EDIT_FILTER
Edit Filter
APEXIR_EDIT_GROUP_BY
Edit Group By
APEXIR_EDIT_HIGHLIGHT
Edit Highlight
APEXIR_EDIT_PIVOT
Edit Pivot
APEXIR_EMAIL
Email
APEXIR_EMAIL_ADDRESS
Email Address
APEXIR_EMAIL_BCC
Bcc
APEXIR_EMAIL_BODY
Body
APEXIR_EMAIL_CC
Cc
APEXIR_EMAIL_FREQUENCY
Frequency
APEXIR_EMAIL_NOT_CONFIGURED
Email has not been configured for this application. Please contact your administrator.
APEXIR_EMAIL_REQUIRED
Email Address must be specified.
APEXIR_EMAIL_SEE_ATTACHED
See attached.
APEXIR_EMAIL_SUBJECT
Subject
APEXIR_EMAIL_SUBJECT_REQUIRED
Email Subject must be specified.
APEXIR_EMAIL_TO
To
APEXIR_ENABLE
Enable
APEXIR_ENABLE_DISABLE_ALT
Enable/Disable
APEXIR_ENABLED
Enabled
APEXIR_ERROR
Error
APEXIR_EXAMPLES
Examples
APEXIR_EXAMPLES_WITH_COLON
Examples:
APEXIR_EXCLUDE_NULL
Exclude Null Values
APEXIR_EXPAND_COLLAPSE_ALT
Expand/Collapse
APEXIR_EXPRESSION
Expression
APEXIR_FILTER
Filter
APEXIR_FILTER_EXPRESSION
Filter Expression
APEXIR_FILTER_TYPE
Filter Type
APEXIR_FILTERS
Filters
APEXIR_FINDER_ALT
Select columns to search.
APEXIR_FLASHBACK
Flashback
APEXIR_FLASHBACK_DESCRIPTION
A flashback query enables you to view the data as it existed at a previous point in time.
APEXIR_FLASHBACK_ERROR_MSG
Unable to perform flashback request.
APEXIR_FORMAT
Format
APEXIR_FORMAT_MASK
Format Mask
APEXIR_FUNCTION
Function
APEXIR_FUNCTION_N
Function %0
APEXIR_FUNCTIONS
Functions
APEXIR_FUNCTIONS_OPERATORS
Functions / Operators
APEXIR_GO
Go
APEXIR_GREEN
green
APEXIR_GROUP_BY
Group By
APEXIR_GROUP_BY_COL_NOT_NULL
Group by column must be specified
APEXIR_GROUP_BY_COLUMN
Group By Column
APEXIR_GROUP_BY_MAX_ROW_CNT
The maximum row count for a Group By query limits the number of rows in the base query, not the number of rows displayed. Your base query exceeds the maximum row count of %0. Please apply a filter to reduce the number of records in your base query.
APEXIR_GROUP_BY_SORT
Group By Sort
APEXIR_GROUP_BY_SORT_ORDER
Group By Sort Order
APEXIR_HCOLUMN
Horizontal Column
APEXIR_HELP
Help
APEXIR_HELP_01
An Interactive Report displays a predetermined set of columns. The report may be further customized with an initial filter clause, a default sort order, control breaks, highlighting, computations, aggregates and a chart. Each Interactive Report can then be further customized and the results can be viewed, or downloaded, and the report definition can be stored for later use.
<p/>
An Interactive Report can be customized in three ways: the search bar, actions menu and column heading menu.
APEXIR_HELP_ACTIONS_MENU
The actions menu is used to customize the display of your Interactive Report.
APEXIR_HELP_AGGREGATE
Aggregates are mathematical computations performed against a column. Aggregates are displayed after each control break and at the end of the report within the column they are defined.
<p/>
<ul><li><b>Aggregation</b> allows you to select a previously defined aggregation to edit.</li>
<li><b>Function</b> is the function to be performed (e.g. SUM, MIN).</li>
<li><b>Column</b> is used to select the column to apply the mathematical function to. Only numeric columns will be displayed.</li></ul>
APEXIR_HELP_CHART
You can include one chart per Interactive Report. Once defined, you can switch between the chart and report views using links below the search bar.
<p/>
<ul><li><b>Chart Type</b> identifies the chart type to include. Select from horizontal bar, vertical bar, pie or line.</li>
<li><b>Label</b> allows you to select the column to be used as the label.</li>
<li><b>Axis Title for Label</b> is the title that will display on the axis associated with the column selected for Label. This is not available for pie chart.</li>
<li><b>Value</b> allows you to select the column to be used as the value. If your function is a COUNT, a Value does not need to be selected.</li>
<li><b>Axis Title for Value</b> is the title that will display on the axis associated with the column selected for Value. This is not available for pie chart.</li>
<li><b>Function</b> is an optional function to be performed on the column selected for Value.</li></ul>
APEXIR_HELP_COLUMN_HEADING_MENU
Clicking on any column heading exposes a column heading menu.
<p/>
<ul><li><b>Sort Ascending icon</b> sorts the report by the column in ascending order.</li>
<li><b>Sort Descending icon</b> sorts the report by the column in descending order.</li>
<li><b>Hide Column</b> hides the column.</li>
<li><b>Break Column</b> creates a break group on the column. This pulls the column out of the report as a master record.</li>
<li><b>Column Information</b> displays help text about the column, if available.</li>
<li><b>Text Area</b> is used to enter case insensitive search criteria (no need for wild cards). Entering a value will reduce the list of values at the bottom of the menu. You can then select a value from the bottom and the selected value will be created as a filter using '=' (e.g. column = 'ABC'). Alternatively, you can click the flashlight icon and the entered value will be created as a filter with the 'LIKE' modifier (e.g. column LIKE '%ABC%').<li><b>List of Unique Values</b> contains the first 500 unique values that meet your filters. If the column is a date, a list of date ranges is displayed instead. If you select a value, a filter will be created using '=' (e.g. column = 'ABC').</li></ul>
APEXIR_HELP_COMPUTE
Computations allow you to add computed columns to your report. These can be mathematical computations (e.g. NBR_HOURS/24) or standard Oracle functions applied to existing columns (some have been displayed for example, others, like TO_DATE, can also be used).
<p/>
<ul><li><b>Computation</b> allows you to select a previously defined computation to edit.</li>
<li><b>Column Heading</b> is the column heading for the new column.</li>
<li><b>Format Mask</b> is an Oracle format mask to be applied against the column (e.g. S9999).</li>
<li><b>Computation</b> is the computation to be performed. Within the computation, columns are referenced using the aliases displayed.</li>
</ul>
<p/>
Below computation, the columns in your query are displayed with their associated alias. Clicking on the column name or alias will write them into the Computation. Next to Columns is a Keypad. These are simply shortcuts of commonly used keys. On the far right are Functions.
<p/>
An example computation to display Total Compensation is:
<p/>
<pre>CASE WHEN A = 'SALES' THEN B + C ELSE B END</pre>
(where A is ORGANIZATION, B is SALARY and C is COMMISSION)
APEXIR_HELP_CONTROL_BREAK
Used to create a break group on one or several columns. This pulls the columns out of the Interactive Report and displays them as a master record.
APEXIR_HELP_DETAIL_VIEW
To view the details of a single row at a time, click the single row view icon on the row you want to view. If available, the single row view will always be the first column. Depending on the customization of the Interactive Report, the single row view may be the standard view or a custom page that may allow update.
APEXIR_HELP_DOWNLOAD
Allows the current result set to be downloaded. The download formats will differ depending upon your installation and report definition but may include CSV, XLS, PDF, or RTF.
APEXIR_HELP_FILTER
Used to add or modify the where clause on the query. You first select a column (it does not need to be one that is displayed), select from a list of standard Oracle operators (=, !=, not in, between), and enter an expression to compare against. The expression is case sensitive and you can use % as a wildcard (for example, STATE_NAME like A%).
APEXIR_HELP_FLASHBACK
Performs a flashback query to allow you to view the data as it existed at a previous point in time. The default amount of time that you can flashback is 3 hours (or 180 minutes) but the actual amount will differ per database.
APEXIR_HELP_FORMAT
<p>Format enable you to customize the display of the report. Format contains the following submenu:</p> <ul><li>Sort</li> <li>Control Break</li> <li>Highlight</li> <li>Compute</li> <li>Aggregate</li> <li>Chart</li> <li>Group By</li> <li>Pivot</li> </ul>
APEXIR_HELP_GROUP_BY
You can define one Group By view per saved report. Once defined, you can switch between the group by and report views using view icons on the Search bar. To create a Group By view, you select: <p></p><ul> <li>the columns on which to group</li> <li>the columns to aggregate along with the function to be performed (average, sum, count, etc.)</li> </ul>
APEXIR_HELP_HIGHLIGHT
Highlighting allows you to define a filter. The rows that meet the filter are highlighted using the characteristics associated with the filter.
<p/>
<ul><li><b>Name</b> is used only for display.</li>
<li><b>Sequence</b> identifies the sequence in which the rules will be evaluated.</li>
<li><b>Enabled</b> identifies if the rule is enabled or disabled.</li>
<li><b>Highlight Type</b> identifies whether the Row or Cell should be highlighted. If Cell is selected, the column referenced in the Highlight Condition is highlighted.</li>
<li><b>Background Color</b> is the new color for the background of the highlighted area.</li>
<li><b>Text Color</b> is the new color for the text in the highlighted area.</li>
<li><b>Highlight Condition</b> defines your filter condition.</li></ul>
APEXIR_HELP_PIVOT
You can define one Pivot view per saved report. Once defined, you can switch between the pivot and report views using view icons on the Search bar. To create a Pivot view, you select: <p></p> <ul> <li>the columns on which to pivot</li> <li>the columns to display as rows</li> <li>the columns to aggregate along with the function to be performed (average, sum, count, etc.)</li> </ul>
APEXIR_HELP_REPORT_SETTINGS
If you have customized your Interactive Report, the report settings will be displayed below the Search Bar and above the report. If you have saved customized reports, they will be shown as tabs. You can access your alternate views by clicking the tabs. Below the tabs are the report settings for the current report. This area can be collapsed and expanded using the icon on the left.
<p/>
For each report setting, you can:
<ul><li><b>Edit</b> by clicking the name.</li>
<li><b>Disable/Enable</b> by unchecking or checking the Enable/Disable check box. This is used to temporarily turn off and on the setting.</li>
<li><b>Remove</b> by click the Remove icon. This permanently removes the setting.</li></ul>
<p/>
If you have created a chart, you can toggle between the report and chart using the Report View and Chart View links shown on the right. If you are viewing the chart, you can also use the Edit Chart link to edit the chart settings.
APEXIR_HELP_RESET
Resets the report back to the default settings, removing any customizations that you have made.
APEXIR_HELP_ROWS_PER_PAGE
Sets the number of records to display per page.
APEXIR_HELP_SAVE_REPORT
Saves the customized report for future use. You provide a name and optional description and can make the report accessible to the public (that is, all users who can access the primary default report). You can save four types of interactive reports:
  • Primary Default (Developer Only). The Primary Default is the report that initially displays. Primary Default reports cannot be renamed or deleted.
  • Alternative Report (Developer Only). Enables developers to create multiple report layouts. Only developers can save, rename, or delete an Alternative Report.
  • Public Report (End user). Can be saved, renamed, or deleted by the end user who created it. Other users can view and save the layout as another report.
  • Private Report (End user). Only the end user that created the report can view, save, rename or delete the report.
If you save customized reports, a Reports selector displays in the Search bar to the left of the Rows selector (if this feature is enabled).
APEXIR_HELP_SEARCH_BAR
At the top of each report page is a search region. The region provides the following features:
<p/>
<ul><li><b>Select columns icon</b> allows you to identify which column to search (or all).</li>
<li><b>Text area</b> allows for case insensitive search criteria (no need for wild cards).</li>
<li><b>Rows</b> selects the number of records to display per page.</li>
<li><b>[Go] button</b> executes the search.</li>
<li><b>Actions Menu icon</b> displays the actions menu (discussed next).</li></ul>
<p/>
Please note that all features may not be available for each report.
APEXIR_HELP_SEARCH_BAR_ACTIONS_MENU
<li><b>Actions Menu</b> enables you to customize a report. See the sections that follow.</li>
APEXIR_HELP_SEARCH_BAR_FINDER
<li><b>Select columns icon</b> enables you to identify which column to search (or all).</li>
APEXIR_HELP_SEARCH_BAR_REPORTS
<li><b>Reports</b> displays alternate default and saved private or public reports.</li>
APEXIR_HELP_SEARCH_BAR_ROWS
<li><b>Rows</b> sets the number of records to display per page.</li>
APEXIR_HELP_SEARCH_BAR_TEXTBOX
<li><b>Text area</b> enables you to enter case insensitive search criteria (wild card characters are implied).</li> <li><b>Go button</b> executes the search. Hitting the enter key will also execute the search when the cursor is in the search text area.</li>
APEXIR_HELP_SEARCH_BAR_VIEW
<li><b>View Icons</b> switches between the icon, report, detail, chart, group by, and pivot views of the report if they are defined.</li>
APEXIR_HELP_SELECT_COLUMNS
Used to modify the columns displayed. The columns on the right are displayed. The columns on the left are hidden. You can reorder the displayed columns using the arrows on the far right. Computed columns are prefixed with <b>**</b>.
APEXIR_HELP_SORT
Used to change the column(s) to sort on and whether to sort ascending or descending. You can also specify how to handle nulls (use the default setting, always display them last or always display them first). The resulting sorting is displayed to the right of column headings in the report.
APEXIR_HELP_SUBSCRIPTION
When you add a subscription, you provide an email address (or multiple email addresses, separated by commas), email subject, frequency, and start and end dates. The resulting emails include an HTML version of the interactive report containing the current data using the report setting that were present when the subscription was added.
APEXIR_HIDE_COLUMN
Hide Column
APEXIR_HIGHLIGHT
Highlight
APEXIR_HIGHLIGHT_CONDITION
Highlight Condition
APEXIR_HIGHLIGHT_TYPE
Highlight Type
APEXIR_HIGHLIGHT_WHEN
Highlight When
APEXIR_HIGHLIGHTS
Highlights
APEXIR_INACTIVE_SETTING
1 inactive setting
APEXIR_INACTIVE_SETTINGS
%0 inactive settings
APEXIR_INTERACTIVE_REPORT_HELP
Interactive Report Help
APEXIR_INVALID
Invalid
APEXIR_INVALID_COMPUTATION
Invalid computation expression. %0
APEXIR_INVALID_END_DATE
The end date must be greater than the start date.
APEXIR_INVALID_FILTER
Invalid filter expression. %0
APEXIR_INVALID_FILTER_QUERY
Invalid filter query
APEXIR_INVALID_SETTING
1 invalid setting
APEXIR_INVALID_SETTINGS
%0 invalid settings
APEXIR_IS_IN_THE_LAST
%0 is in the last %1
APEXIR_IS_IN_THE_NEXT
%0 is in the next %1
APEXIR_IS_NOT_IN_THE_LAST
%0 is not in the last %1
APEXIR_IS_NOT_IN_THE_NEXT
%0 is not in the next %1
APEXIR_KEYPAD
Keypad
APEXIR_LABEL
Label
APEXIR_LABEL_AXIS_TITLE
APEXIR_LABEL_PREFIX
Label Prefix
APEXIR_LAST_DAY
Last Day
APEXIR_LAST_HOUR
Last Hour
APEXIR_LAST_MONTH
Last Month
APEXIR_LAST_WEEK
Last Week
APEXIR_LAST_X_DAYS
Last %0 Days
APEXIR_LAST_X_HOURS
Last %0 Hours
APEXIR_LAST_X_YEARS
Last %0 Years
APEXIR_LAST_YEAR
Last Year
APEXIR_LINE
Line
APEXIR_MAX_QUERY_COST
The query is estimated to exceed the maximum allowed resources. Please modify your report settings and try again.
APEXIR_MAX_ROW_CNT
This query returns more then %0 rows, please filter your data to ensure complete results.
APEXIR_MAX_X
Maximum %0
APEXIR_MEDIAN_X
Median %0
APEXIR_MIN_AGO
%0 minutes ago
APEXIR_MIN_X
Minimum %0
APEXIR_MONTH
Month
APEXIR_MONTHLY
Monthly
APEXIR_MORE_DATA
More Data
APEXIR_MOVE
Move
APEXIR_MOVE_ALL
Move All
APEXIR_NAME
Name
APEXIR_NEW_AGGREGATION
New Aggregation
APEXIR_NEW_CATEGORY
- New Category -
APEXIR_NEW_COMPUTATION
New Computation
APEXIR_NEXT
&gt;
APEXIR_NEXT_DAY
Next Day
APEXIR_NEXT_HOUR
Next Hour
APEXIR_NEXT_MONTH
Next Month
APEXIR_NEXT_WEEK
Next Week
APEXIR_NEXT_X_DAYS
Next %0 Days
APEXIR_NEXT_X_HOURS
Next %0 Hours
APEXIR_NEXT_X_YEARS
Next %0 Years
APEXIR_NEXT_YEAR
Next Year
APEXIR_NO
No
APEXIR_NO_AGGREGATION_DEFINED
No aggregation defined.
APEXIR_NO_COLUMN_INFO
No column information available.
APEXIR_NO_COMPUTATION_DEFINED
No computation defined.
APEXIR_NO_END_DATE
- No End Date -
APEXIR_NONE
- None -
APEXIR_NOT_VALID_EMAIL
Not a valid email address.
APEXIR_NULL_SORTING
Null Sorting
APEXIR_NULLS_ALWAYS_FIRST
Nulls Always First
APEXIR_NULLS_ALWAYS_LAST
Nulls Always Last
APEXIR_NUMERIC_FLASHBACK_TIME
Flashback time must be numeric.
APEXIR_NUMERIC_SEQUENCE
Sequence must be numeric.
APEXIR_OPERATOR
Operator
APEXIR_ORANGE
orange
APEXIR_OTHER
Other
APEXIR_PERCENT_OF_TOTAL_COUNT_X
Percent of Total Count %0 (%)
APEXIR_PERCENT_OF_TOTAL_SUM_X
Percent of Total Sum %0 (%)
APEXIR_PERCENT_TOTAL_COUNT
APEXIR_PERCENT_TOTAL_SUM
APEXIR_PIE
Pie
APEXIR_PIVOT
Add Pivot Column
APEXIR_PIVOT_AGG_NOT_NULL
Aggregate must be specified.
APEXIR_PIVOT_AGG_NOT_ON_ROW_COL
You cannot aggregate on a column selected to as row column.
APEXIR_PIVOT_COLUMN_N
Pivot Column %0
APEXIR_PIVOT_COLUMN_NOT_NULL
Pivot column must be specified.
APEXIR_PIVOT_COLUMNS
Pivot Columns
APEXIR_PIVOT_MAX_ROW_CNT
The maximum row count for a Pivot query limits the number of rows in the base query, not the number of rows displayed. Your base query exceeds the maximum row count of %0. Please apply a filter to reduce the number of records in your base query.
APEXIR_PIVOT_SORT
Pivot Sort
APEXIR_PREVIOUS
&lt;
APEXIR_PRIMARY
Primary
APEXIR_PRIMARY_REPORT
Primary Report
APEXIR_PRIVATE
Private
APEXIR_PUBLIC
Public
APEXIR_RED
red
APEXIR_REMOVE
Remove
APEXIR_REMOVE_AGGREGATE
Remove Aggregate
APEXIR_REMOVE_ALL
Remove All
APEXIR_REMOVE_CHART
Remove Chart
APEXIR_REMOVE_CONTROL_BREAK
Remove Control Break
APEXIR_REMOVE_FILTER
Remove Filter
APEXIR_REMOVE_FLASHBACK
Remove Flashback
APEXIR_REMOVE_GROUP_BY
Remove Group By
APEXIR_REMOVE_HIGHLIGHT
Remove Highlight
APEXIR_REMOVE_PIVOT
Remove Pivot
APEXIR_RENAME_DEFAULT_REPORT
Rename Default Report
APEXIR_RENAME_REPORT
Rename Report
APEXIR_REPORT
Report
APEXIR_REPORT_ALIAS_DOES_NOT_EXIST
Saved Interactive report with alias %0 does not exist.
APEXIR_REPORT_DISPLAY_COLUMN_LIMIT_REACHED
The number of display columns in the report reached the limit. Please click Select Columns under Actions menu to minimize the report display column list.
APEXIR_REPORT_DOES_NOT_EXIST
Report does not exist.
APEXIR_REPORT_ID_DOES_NOT_EXIST
Saved Interactive Report ID %0 does not exist.
APEXIR_REPORT_SETTINGS
Report Settings
APEXIR_REPORT_VIEW
&lt; Report View
APEXIR_REPORTS
Reports
APEXIR_RESET
Reset
APEXIR_RESET_CONFIRM
Restore report to the default settings.
APEXIR_ROW
Row
APEXIR_ROW_COL_DIFF_FROM_PIVOT_COL
Row column must be different from the pivot column.
APEXIR_ROW_COLUMN_N
Row Column %0
APEXIR_ROW_COLUMN_NOT_NULL
Row column must be specified.
APEXIR_ROW_COLUMNS
Row Columns
APEXIR_ROW_FILTER
Row Filter
APEXIR_ROW_OF
Row %0 of %1
APEXIR_ROW_ORDER
Row Order
APEXIR_ROW_TEXT_CONTAINS
Row text contains
APEXIR_ROWS
Rows
APEXIR_ROWS_PER_PAGE
Rows Per Page
APEXIR_RPT_DISP_COL_EXCEED
APEXIR_SAVE
Save
APEXIR_SAVE_AS_DEFAULT
Save as Default
APEXIR_SAVE_DEFAULT_CONFIRM
The current report settings are used as the default for all users.
APEXIR_SAVE_DEFAULT_REPORT
Save Default Report
APEXIR_SAVE_REPORT
Save Report
APEXIR_SAVE_REPORT_DEFAULT
Save Report *
APEXIR_SAVED_REPORT
Saved Report
APEXIR_SAVED_REPORT_MSG
Saved Report = "%0"
APEXIR_SEARCH
Search
APEXIR_SEARCH_BAR
Search Bar
APEXIR_SEARCH_COLUMN
Search: %0
APEXIR_SEARCH_REPORT
Search Report
APEXIR_SELECT_CATEGORY
- Select Category -
APEXIR_SELECT_COLUMN
- Select Column -
APEXIR_SELECT_COLUMNS
Select Columns
APEXIR_SELECT_COLUMNS_FOOTER
Computed columns are prefixed with **.
APEXIR_SELECT_FUNCTION
- Select Function -
APEXIR_SELECT_GROUP_BY_COLUMN
- Select Group By Column -
APEXIR_SELECT_PIVOT_COLUMN
- Select Pivot Column -
APEXIR_SELECT_ROW
Select Row
APEXIR_SELECT_ROW_COLUM
- Select Row Column -
APEXIR_SELECT_SORT_COLUMN
- Select Sort Column -
APEXIR_SELECT_VALUE
Select Value
APEXIR_SELECTED_COLUMNS
Selected Columns
APEXIR_SEND
Send
APEXIR_SEQUENCE
Sequence
APEXIR_SORT
Sort
APEXIR_SORT_ASCENDING
Sort Ascending
APEXIR_SORT_COLUMN
Sort Column
APEXIR_SORT_DESCENDING
Sort Descending
APEXIR_SORT_ORDER
Sort Order
APEXIR_SPACE_AS_IN_ONE_EMPTY_STRING
space
APEXIR_STATUS
Status
APEXIR_SUBSCRIPTION
Subscription
APEXIR_SUBSCRIPTION_ENDING
Ending
APEXIR_SUBSCRIPTION_STARTING_FROM
Starting From
Starting From
APEXIR_SUM_X
Sum %0
APEXIR_TABLE_SUMMARY
Region = %0, Report = %1, View = %2, Displayed Rows Start = %3, Displayed Rows End = %4, Total Rows = %5
APEXIR_TEXT_COLOR
Text Color
APEXIR_TIME_DAYS
days
APEXIR_TIME_HOURS
hours
APEXIR_TIME_MINS
minutes
APEXIR_TIME_MONTHS
months
APEXIR_TIME_WEEKS
weeks
APEXIR_TIME_YEARS
years
APEXIR_TOGGLE
Toggle
APEXIR_TOP
Top
APEXIR_UNAUTHORIZED
Unauthorized
APEXIR_UNGROUPED_COLUMN
Ungrouped Column
APEXIR_UNIQUE_COLUMN_HEADING
Column Heading must be unique.
APEXIR_UNIQUE_HIGHLIGHT_NAME
Highlight Name must be unique.
APEXIR_UNSUPPORTED_DATA_TYPE
unsupported data type
APEXIR_UP
Up
APEXIR_VALID_COLOR
Please enter a valid color.
APEXIR_VALID_FORMAT_MASK
Please enter a valid format mask.
APEXIR_VALUE
Value
APEXIR_VALUE_AXIS_TITLE
APEXIR_VALUE_REQUIRED
Value Required
APEXIR_VCOLUMN
Vertical Column
APEXIR_VIEW_CHART
View Chart
APEXIR_VIEW_DETAIL
View Detail
APEXIR_VIEW_GROUP_BY
View Group By
APEXIR_VIEW_ICONS
View Icons
APEXIR_VIEW_PIVOT
View Pivot
APEXIR_VIEW_REPORT
View Report
APEXIR_WEEK
Week
APEXIR_WEEKLY
Weekly
APEXIR_WORKING_REPORT
Working Report
APEXIR_X_DAYS
%0 days
APEXIR_X_HOURS
%0 hours
APEXIR_X_MINS
%0 minutes
APEXIR_X_MONTHS
%0 months
APEXIR_X_WEEKS
%0 weeks
APEXIR_X_YEARS
%0 years
APEXIR_YEAR
Year
APEXIR_YELLOW
yellow
APEXIR_YES
Yes
IR_AS_DEFAULT_REPORT_SETTING
As Default Report Settings
IR_AS_NAMED_REPORT
As Named Report
IR_STAR
Only displayed for developers
LAYOUT.T_CONDITION_EXPR2
Expression 2
OUT_OF_RANGE
REPORT
Report
REPORTING_PERIOD
Reporting Period
RESET
Reset Pagination
SAVED_REPORTS.PRIMARY.DEFAULT
Primary Default
%0 - %1 of %2
