Go to primary content
Oracle® Application Express Application Builder User's Guide
Release 5.0
E39147-04
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
16.4 Creating a Navigation Bar Entry
This section explains how to create and edit navigation bar entries. Navigation bar entries offer an easy way to move users between pages in an application. For example, a navigation entry enables you to display a link from an image or text. The associated page template determines the location of a navigation bar.
16.4.1 About Navigation Bars
A navigation bar entry can be an image, text, or an image with text beneath it. You must supply the images and text to use in the navigation bar entries.
Description of nav_bar_2.png follows
Navigation bars are different from other shared components in that you do not need to reference them on a page-by-page basis. If your page template includes the #NAVIGATION_BAR# substitution string, the Application Express engine automatically includes any defined navigation bars when it renders the page.
16.4.2 Creating a Navigation Bar Entry
Before adding a navigation bar, you must create entries for the navigation bar. You can create a navigation bar entry from scratch or by copying an existing entry.
16.4.2.1 Creating a Navigation Bar Entry from Scratch
To create a navigation bar entry from scratch:
  1. Navigate to the Navigation Bar Entries page:
    1. Navigate to the Workspace home page.
    2. Click the Application Builder icon.
    3. Select an application.
    4. On the Application home page, click Shared Components.
    5. Under Navigation, click Navigation Bar Entries.
  2. Click Create.
    The Create Navigation Bar Entry Wizard appears.
  3. For Method, select From Scratch.
  4. For Type, select Navigation to URL.
    Tip:
    To learn more about Feedback, see "Creating a Navigation Bar Entry for Feedback."
  5. For Attributes, specify the following:
    1. Sequence - Specify the order of evaluation for this component.
      Tip:
      To review the existing entries, click the Existing Navigation Bar Entries link at the bottom of the page.
    2. Entry Label - Enter display text for this navigation bar entry.
    3. Icon Image Name - Enter an image name. For naming conventions, see field-level Help. See "Viewing Field-Level Help."
    4. Image ALT - Enter ALT text for navigation icons that are images. If you do not specify an image name, then this text displays.
    5. Image Height - Define the height of the image in pixels.
    6. Width - Defines the width of the image.
    7. Click Next.
  6. For Target, specify the following
    1. If the target location is a URL, specify:
      • Target is a - Select URL.
      • URL Target - Enter a URL. For example:
        http://www.yahoo.com
    2. If the target location is a page, specify:
      • Target is a - Select Page in this Application.
      • Page - Specify the target page number.
        To reset pagination, select reset pagination for this page.
        Select Printer Friendly to display the target page using the application's Printer Friendly template. Printer friendly templates optimize a page for printing. "Editing Themes" and "Optimizing a Page for Printing."
      • Request - Enter text that defines the built-in application item called REQUEST.
      • Clear Cache - Enter the page numbers where you would like to clear the user's session state. Separate multiple entries with commas.
    3. To set session state (that is, give a listed item a value):
      • Set these items - Enter the list of application item names for which you would like to set session state. Separate multiple items with commas. Setting the session state gives the listed item a value.
      • With these values - Enter a comma-delimited list of values for the items your specified.
        You can specify static values or substitution syntax (for example, &APP_ITEM_NAME.). Note that item values passed to f?p= in the URL cannot contain a colon. Additionally, item values cannot contain commas unless you enclose the entire value in backslashes (for example, \1234,56\).
    4. Click Next.
  7. To set a condition for displaying the navigation bar entry, select a condition type.
  8. Click Create.
Tip:
In order for a navigation bar to appear, your page template must include the #NAVIGATION_BAR# substitution string. To learn more, see "Page Templates."
16.4.2.2 Creating a Navigation Bar Entry for Feedback
Feedback is the process of gathering real-time comments, enhancement requests, and bugs from your application users. To add a feedback page to an application, you add a Feedback page.
To create a navigation bar entry for feedback:
  2. Click Create.
    The Create Navigation Bar Entry Wizard appears. Each wizard page displays a series of blocks on the left, representing the sequence of steps. The highlighted block indicates the step you are performing.
  4. For Type, select Feedback.
  5. For Feedback:
    1. Feedback Page - Select your feedback page.
    2. Entry Label - Enter the label of the new navigation bar entry.
    3. Display Sequence - The sequence for the new navigation bar entry. The sequence determines the order of evaluation.
  6. Click Create.
Tip:
In order for a navigation bar to appear, your page template must include the #NAVIGATION_BAR# substitution string. See"Page Templates."
16.4.3 Copying a Navigation Bar Entry
To copy a navigation bar entry:
  2. Click Create.
  3. For Method, select As a Copy of an Existing Navigation Bar and click Next.
  4. For Copy From Application, select an application and click Next.
  5. For New Names, enter the name on the new entry, and select whether to copy and subscribe.
  6. Click Copy Navigation Bar Entries.
16.4.4 Editing a Navigation Bar Entry
Once you create a navigation bar entry, you can edit it on the Navigation Bar Entries page.
To edit a navigation bar entry:
    The Navigation Bar Entries page appears.
  2. Select a navigation bar entry.
    The Edit page appears.
  3. Edit the appropriate attributes.
  4. To learn more about a specific item on a page, see field-level Help. See "Viewing Field-Level Help."
  5. Click Apply Changes.
16.4.5 Editing Multiple Navigation Bar Entries Simultaneously
To edit multiple navigation bar entries simultaneously:
  2. Click Grid Edit at the top of the page.
  3. Edit the appropriate attributes and click Apply Changes.
16.4.6 Accessing Navigation Bar Entry Reports
You can view the Navigation Bar Entry Subscription and Navigation Bar Entry History reports by clicking the appropriate tab at the top of the Navigation Bar Entries page.
The Subscription and History buttons only appear after you create a navigation bar.
  2. Click the appropriate tab:
    • Subscription - Click Subscription to access the Subscribed NavBars report. This report displays subscribed navigation bar entries in your application.
    • History - Click History to view the Navigation Bar History report. This report lists recent changes to navigation bars.
