Go to primary content
Oracle® Application Express Application Builder User's Guide
Release 5.0
E39147-04
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
8.6 Runtime Developer Toolbar
When you run a desktop application from Application Builder, the Runtime Developer toolbar displays at the bottom of any editable running page. Use the Developer toolbar to quickly edit the current application or currently running page, or view session state. The Runtime Developer toolbar only displays if the Availability, Status attribute on the Application Definition page is set to Available with Developer Toolbar.
Description of dev_toolbar.png follows
The Runtime Developer toolbar does not display on locked packaged applications pages or on jQuery Mobile Smartphone pages.
The Runtime Developer toolbar consists of the following controls:
