Go to primary content
Oracle® Application Express Application Builder User's Guide
Release 5.0
E39147-04
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
8.7 Copying a Database Application Page in Page Designer
You can copy a page from the current application or from another application. During the copy process, you can also copy shared components or change mappings to shared components in the target application.
To copy a page:
  1. Navigate to the page you want to copy. See "Viewing a Page in Page Designer."
  2. On the Page Designer toolbar, click the Create menu and then select Page as Copy.
    Description of pd_copy_pg.png follows
  3. On Copy Page Option, select one of the following:
    • Page in this application
    • Page in another application
  4. Follow the on-screen instructions.
