Go to primary content
Oracle® Application Express Application Builder User's Guide
Release 5.0
E39147-04
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
D.2 Understanding Privileges Granted to PUBLIC
This section describes public synonyms that exist and for which the execute privilege is granted to PUBLIC for the packages, procedures, functions, tables, and views owned by the Oracle Application Express product schema, (for example, APEX_050000).
D.2.1 Packages
Public synonyms exist and execute privilege is granted to PUBLIC for the following packages owned by the Oracle Application Express product schema, (for example, APEX_050000):
APEXWS
APEX_MIG_PROJECTS_UPDATE
APEX_UI_DEFAULT_UPDATE
HTMLDB_CUSTOM_AUTH
HTMLDB_ITEM
HTMLDB_LANG
HTMLDB_SITE_ADMIN_PRIVS
WWV_FLOW_APPLICATION_INSTALL
HTMLDB_UTIL
WWV_FLOW
WWV_FLOW_API
WWV_FLOW_AUDIT
WWV_FLOW_CSS_API
WWV_FLOW_AUDIT
WWV_FLOW_COLLECTION
WWV_FLOW_CSS
WWV_FLOW_CSS_API
WWV_FLOW_CUSTOMIZE
WWV_FLOW_CUSTOM_AUTH
WWV_FLOW_CUSTOM_AUTH_LDAP
WWV_FLOW_CUSTOM_AUTH_STD
WWV_FLOW_DEBUG_MESSAGE
WWV_FLOW_EPG_INCLUDE_MODULES
WWV_FLOW_FILE_MGR
WWV_FLOW_FND_USER_API
WWV_FLOW_GLOBAL
WWV_FLOW_HINT
WWV_FLOW_HTML_API
WWV_FLOW_ID
WWV_FLOW_IMAGE_API
WWV_FLOW_ITEM
WWV_FLOW_ITEM_HELP
WWV_FLOW_JAVASCRIPT
WWV_FLOW_LANG
WWV_FLOW_LDAP
WWV_FLOW_LOOKUP_TABLES
WWV_FLOW_MAIL
WWV_FLOW_PLSQL_JOB
WWV_FLOW_PLUGIN
WWV_FLOW_PLUGIN_UTIL
WWV_FLOW_PREFERENCES
WWV_FLOW_RANDOM
WWV_FLOW_RENDER_SHORTCUT
WWV_FLOW_REST
WWV_FLOW_SVG
WWV_FLOW_USER_API
WWV_FLOW_UTILITIES
WWV_FLOW_WEBSERVICES_API
WWV_FLOW_WS_IMPORT_API
WWV_MIG_ACC_LOAD
WWV_RENDER_CALENDAR2
WWV_RENDER_CHART2
Execute privilege is granted to PUBLIC for the following packages owned by the Oracle Application Express product schema, (for example, APEX_050000):
WWV_CALCULATOR
WWV_FLOW_FLASH_CHART
WWV_FLOW_GENERATE_DDL
WWV_FLOW_IMAGE_GENERATOR
WWV_FLOW_TREE_GLOBAL_VARS
D.2.2 Procedures
Public synonyms exist and execute privilege is granted to PUBLIC for the following procedures owned by the Oracle Application Express product schema, (for example, APEX_050000):
APEX
APEX_ADMIN
DEVELOPMENT_SERVICE_HOME
DEVELOPMENT_SERVICE_HOME_LOGIN
DEVELOPMENT_SERVICE_SIGNUP
F
HTMLDB
HTMLDB_ADMIN
HTMLDB_LOGIN
P
WS
WWV_FLOW_INIT_HTP_BUFFER
Z
D.2.3 Functions
Public synonyms exist and execute privilege is granted to PUBLIC for the following functions owned by the Oracle Application Express product schema, (for example, APEX_050000):
NV
V
Execute privilege is granted to PUBLIC for the following function owned by the Oracle Application Express product schema, (for example, APEX_050000):
WWV_POPUP_FILTER
D.2.4 Tables
Public synonyms exist and select privilege is granted to PUBLIC for the following tables owned by the Oracle Application Express product schema, (for example, APEX_050000):
WWV_FLOW_DUAL100
WWV_FLOW_TEMP_TABLE
WWV_FLOW_LOV_TEMP
D.2.5 Views
Public synonyms exist and select privilege is granted to PUBLIC for the following views owned by the Oracle Application Express product schema, (for example, APEX_050000):
APEX_APPLICATIONS
APEX_APPLICATION_ALL_AUTH
APEX_APPLICATION_AUTH
APEX_APPLICATION_AUTHORIZATION
APEX_APPLICATION_BC_ENTRIES
APEX_APPLICATION_BREADCRUMBS
APEX_APPLICATION_BUILD_OPTIONS
APEX_APPLICATION_CACHING
APEX_APPLICATION_COMPUTATIONS
APEX_APPLICATION_GROUPS
APEX_APPLICATION_ITEMS
APEX_APPLICATION_LISTS
APEX_APPLICATION_LIST_ENTRIES
APEX_APPLICATION_LOVS
APEX_APPLICATION_LOV_ENTRIES
APEX_APPLICATION_NAV_BAR
APEX_APPLICATION_PAGES
APEX_APPLICATION_PAGE_BRANCHES
APEX_APPLICATION_PAGE_BUTTONS
APEX_APPLICATION_PAGE_COMP
APEX_APPLICATION_PAGE_DA
APEX_APPLICATION_PAGE_DA_ACTS
APEX_APPLICATION_PAGE_DB_ITEMS
APEX_APPLICATION_PAGE_FLASH5
APEX_APPLICATION_PAGE_FLASH5_S
APEX_APPLICATION_PAGE_FLASH_CH
APEX_APPLICATION_PAGE_GROUPS
APEX_APPLICATION_PAGE_IR
APEX_APPLICATION_PAGE_IR_CAT
APEX_APPLICATION_PAGE_IR_CGRPS
APEX_APPLICATION_PAGE_IR_COL
APEX_APPLICATION_PAGE_IR_COMP
APEX_APPLICATION_PAGE_IR_COND
APEX_APPLICATION_PAGE_IR_GRPBY
APEX_APPLICATION_PAGE_IR_PIVOT
APEX_APPLICATION_PAGE_IR_PVAGG
APEX_APPLICATION_PAGE_IR_PVSRT
APEX_APPLICATION_PAGE_IR_RPT
APEX_APPLICATION_PAGE_IR_SUB
APEX_APPLICATION_PAGE_ITEMS
APEX_APPLICATION_PAGE_MAP
APEX_APPLICATION_PAGE_PROC
APEX_APPLICATION_PAGE_REGIONS
APEX_APPLICATION_PAGE_RPT
APEX_APPLICATION_PAGE_RPT_COLS
APEX_APPLICATION_PAGE_TREES
APEX_APPLICATION_PAGE_VAL
APEX_APPLICATION_PARENT_TABS
APEX_APPLICATION_PROCESSES
APEX_APPLICATION_SHORTCUTS
APEX_APPLICATION_SUBSTITUTIONS
APEX_APPLICATION_SUPP_OBJECTS
APEX_APPLICATION_SUPP_OBJ_BOPT
APEX_APPLICATION_SUPP_OBJ_CHCK
APEX_APPLICATION_SUPP_OBJ_SCR
APEX_APPLICATION_TABS
APEX_APPLICATION_TEMPLATES
APEX_APPLICATION_TEMP_BC
APEX_APPLICATION_TEMP_BUTTON
APEX_APPLICATION_TEMP_CALENDAR
APEX_APPLICATION_TEMP_LABEL
APEX_APPLICATION_TEMP_LIST
APEX_APPLICATION_TEMP_PAGE
APEX_APPLICATION_TEMP_POPUPLOV
APEX_APPLICATION_TEMP_REGION
APEX_APPLICATION_TEMP_REPORT
APEX_APPLICATION_THEMES
APEX_APPLICATION_TRANSLATIONS
APEX_APPLICATION_TRANS_MAP
APEX_APPLICATION_TREES
APEX_APPLICATION_WEB_SERVICES
APEX_APPL_PLUGINS
APEX_APPL_PLUGIN_ATTRIBUTES
APEX_APPL_PLUGIN_ATTR_VALUES
APEX_APPL_PLUGIN_EVENTS
APEX_APPL_PLUGIN_FILES
APEX_DEBUG_MESSAGES
APEX_DEVELOPER_ACTIVITY_LOG
APEX_DICTIONARY
APEX_MIGRATION_ACC_FORMS
APEX_MIGRATION_ACC_PROJECTS
APEX_MIGRATION_ACC_QUERIES
APEX_MIGRATION_ACC_RPTS
APEX_MIGRATION_ACC_TABLES
APEX_MIGRATION_PROJECTS
APEX_MIGRATION_REV_FORMS
APEX_MIGRATION_REV_QUERIES
APEX_MIGRATION_REV_RPTS
APEX_MIGRATION_REV_TABLES
APEX_RELEASE
APEX_STANDARD_CONDITIONS
APEX_TEAM_BUGS
APEX_TEAM_FEEDBACK
APEX_TEAM_MILESTONES
APEX_TEAM_TODOS
APEX_THEMES
APEX_UI_DEFAULTS_ATTR_DICT
APEX_UI_DEFAULTS_COLUMNS
APEX_UI_DEFAULTS_GROUPS
APEX_UI_DEFAULTS_LOV_DATA
APEX_UI_DEFAULTS_TABLES
APEX_WORKSPACES
APEX_WORKSPACE_ACCESS_LOG
APEX_WORKSPACE_ACTIVITY_LOG
APEX_WORKSPACE_APEX_USERS
APEX_WORKSPACE_CLICKS
APEX_WORKSPACE_DEVELOPERS
APEX_WORKSPACE_FILES
APEX_WORKSPACE_LOG_SUMMARY
APEX_WORKSPACE_LOG_SUMMARY_USR
APEX_WORKSPACE_SCHEMAS
APEX_WORKSPACE_SESSIONS
APEX_WORKSPACE_SQL_SCRIPTS
APEX_WS_APPLICATIONS
APEX_WS_APP_PAGES
APEX_WS_DATA_GRID
APEX_WS_DATA_GRID_COL
WWV_FLOW_CLICKTHRU_LOG
WWV_FLOW_COLLECTIONS
WWV_FLOW_FEEDBACK_TYPES
WWV_FLOW_GROUP_USERS
WWV_FLOW_LISTS_OF_VALUES$_V
WWV_FLOW_LIST_OF_VALUES_DATA_V
WWV_FLOW_MONTHS_MON
WWV_FLOW_MONTHS_MONTH
WWV_FLOW_PLSQL_JOBS
WWV_FLOW_USERS
WWV_FLOW_USER_ACCESS_LOG
WWV_FLOW_USER_ACTIVITY_LOG
WWV_FLOW_USER_MAIL_LOG
WWV_FLOW_YEARS
Additionally, insert is granted on the following:
WWV_FLOW_FILES
Additionally, the following views have select privilege granted to PUBLIC, but no synonym:
WWV_FLOW_HOURS_12
WWV_FLOW_HOURS_24
WWV_FLOW_MINUTES
WWV_FLOW_MINUTES_5
D.2.6 Sequences
The following sequences have public synonyms and select privilege granted to public:
WWV_FLOW_SESSION_SEQ
WWV_SEQ
D.2.7 Types
The following types have execute granted to public but no synonyms:
WWV_FLOW_TREE_ENTRY
WWV_FLOW_TREE_SUBS
