Go to primary content
Oracle® Application Express Application Builder User's Guide
Release 5.0
E39147-04
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
18.2 Managing Component Settings
This section describes how to use the Component Settings page to configure application-level values for built-in Oracle Application Express components and installed plug-ins.
18.2.1 Editing Component Settings
To edit component settings:
  1. Navigate to the Shared Components page:
    1. On the Workspace home page, click Application Builder.
    2. Select an application.
    3. On the Application home page, click Shared Components.
      The Shared Components page appears.
  2. Under Other Components, click Component Settings.
    The Component Settings page displays as an interactive report. To customize the report, use the Search bar at the top of the page. To learn more, see "About the Search Bar."
  3. Edit the settings and click Apply Changes.
18.2.2 Viewing the Component Settings History Report
You can view a report of modifications made to Oracle Application Express components and installed plug-ins on the Component Settings History page.
To view the Component Settings History report:
  3. Click the History tab.
    The History page displays as an interactive report. To customize the report, use the Search bar at the top of the page. To learn more, see "About the Search Bar."
