Go to primary content
Oracle® Application Express Application Builder User's Guide
Release 5.0
E39147-04
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
1.3 Understanding the Workspace Home Page
When you sign in to Oracle Application Express development environment, the Workspace home page appears. A workspace is a virtual private database which enables multiple users to work within the same Oracle Application Express installation while keeping their objects, data and applications private. This section describes the Workspace home page.
1.3.1 Workspace Home Page
Description of workspace_home.png follows
The following large icons display in the center of the page:
An menu bar also displays at the top of the page. Click a menu to access an alternate navigation path to different components within Application Builder, SQL Workshop, Team Development, and Packaged Apps.
Description of bldr_hm_menus.png follows
1.3.2 Top Applications and Top Users Dashboards
The Top Applications and Top Users regions display at the bottom of the page. These regions offer real time information about development activities in the current workspace.
1.3.3 News and Messages
Description of wrkspc_home_news.png follows
The News and Messages region can display three types of messages:
  • News entries
  • System messages
  • Workspace Announcements
News entries include a date to the left of the message text. Developers can create news entries to communicate with other workspace users. To add a news entry, click the Create News Entry icon which resembles a plus sign (+). To edit existing news entries, click Edit News Entry which resembles a greater than sign (>).
Both workspace announcements and system messages include a gold icon to the left of message text. A textual identifier, either System Message or Workspace Announcement, also displays beneath the message text.
See Also:
"Managing News Entries" and "Defining a System Message" and "Defining a Workspace Announcement" in Oracle Application Express Administration Guide
1.3.4 Developer Navigation Tools
This section describes Developer Navigation tools available in the header region on many Oracle Application Express pages, including the Workspace home page, Application Builder home page, the Application home page, Page Designer, Component View, and Shared Components.
1.3.4.1 Global Search Field
Description of search_wrkspc.png follows
The Search field displays in the header region in upper right corner of most Application Builder pages. By default, this Search field supports regular expressions. How the search field works depends upon the page you are on. Consider the following examples:
  • Workspace home page - Search for application names.
  • Application Builder home page - Search for application metadata across all applications.
  • Application home page - Search for metadata for the Application home page and other pages within Application Builder.
  • Team Development home page - Search the Team Development home page and other pages within Team Development.
  • Workspace Administration home page - Search for users.
Within Application Builder the following special syntax can be used to navigate to a specific page or search for a regular expression:
page
application_ID:page
application_ID-page
regexp:expression
Where:
  • application_ID is the numeric identification number (or ID) that identifies an application.
  • page is the numeric identification number that identifies a specific page.
  • regexp: is literal text.
  • expression is a regular expression to search for.
The following example navigates you to page 10 of application 570:
10
570-10
570:10
You can also use this syntax to navigate to the Shared Components page of a given application:
application_ID:s
application_ID-s
Where:
The following example demonstrates how to navigate to the Shared Components page of application 570:
570:s
570-s
1.3.4.2 Administration Menu
Description of admin_menu.png follows
The Administration menu displays to the right of the Global Search field and features an outline person with a wrench. Clicking this menu displays the following options:
1.3.4.3 Help Menu
Description of help_ico.png follows
The Help menu resembles a question mark. Clicking Help displays the following menu items:
1.3.4.4 Account Menu
Description of edit_profile.png follows
The Account menu displays in the upper right corner of the page and features an outline of a person. The Account menu displays your username, current workspace, and user role. If Single Sign On (SSO) is enabled, the link Change Workspace also appears. Key controls on this menu include:
  • Edit Profile. Click Edit Profile to edit your first and last name, upload or choose a photo image, alter your email address (if SSO is not enabled), and reset your password. See "Editing Your Account Profile and Preferences."
    Tip:
    If you are using Single Sign-on authentication, Change Workspace also displays. Click Change Workspace to view a list of workspaces you have access to.
  • Preferences. Click Preferences to change your default schema, default date format, and control how Application Builder runs applications. See "Editing User Preferences."
  • Sign Out - Click Sign Out to log out the current workspace. See "Signing Out of a Workspace."
1.3.5 Available Updates Region
The Available Updates region indicates if updates are available for Oracle Application Express and the Oracle REST Data Services. If your installation is current the following message displays:
System is up-to-date
To configure updates, click Set Preferences for Available Updates. You can enable or disable updates by selecting Yes or No from Check for Available Updates.
Tip:
To perform this check Application Express transmits the version number of Oracle Application Express and other system components to Oracle Corporation. In order to continuously improve our products, Oracle is interested in learning about product usage. To that end, statistics can occasionally be sent to Oracle describing the product features in use. No personally identifiable information is sent. To review Oracle's privacy policy see:
http://www.oracle.com/us/legal/privacy/overview/index.html
1.3.6 Accessibility Mode Region
The Accessibility Mode list displays in the lower right side of the page. Use the Accessibility Mode list to identify if a page is optimized for screen readers. Available options include: Standard, Screen Reader, and High Contrast.
