Go to primary content
Oracle® Application Express Application Builder User's Guide
Release 5.0
E39147-04
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
14.2 Optimizing a Page for Printing
You can optimize a page for printing by creating a specific Printer Friendly template and selecting that template on the Create/Edit Theme page. Generally, a Printer Friendly template optimizes a page for printing. For example, a Printer Friendly template might:
If the theme you select does not include a printer friendly template, you can create a Printer Friendly template by creating a new page template.
14.2.1 Selecting a Printer Friendly Template for an Application
To select a Printer Friendly template:
  1. Navigate to the Themes page:
    1. On the Workspace home page, click Application Builder.
    2. Select an application.
    3. Click Shared Components.
    4. Under User Interface, select Themes.
      The Themes page appears.
  2. Change to a report view by clicking the View Report icon.
  3. In the Themes list, click the theme name.
    The Create/Edit Theme page appears.
  4. Scroll down to Component Defaults.
  5. Make a selection from the Printer Friendly Page list.
  6. Click Apply Changes.
See Also:
"Editing Themes"
14.2.2 Using f?p Syntax to Toggle to Printer Friendly Mode
Once you create a Printer Friendly template and select it, you can use f?p syntax to toggle to Printer Friendly mode. Including the ninth f?p syntax argument (PrinterFriendly) renders the page in printer friendly mode (optimizing printed output). For example, you could include this argument when coding a link or creating a navigation bar icon.
