Skip Headers
Oracle® Data Provider for .NET Developer's Guide
12c Release 1 (12.1.0.1.0)
E41125-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleAQDequeueOptions Class
An OracleAQDequeueOptions object represents the options available when dequeuing a message from an OracleAQQueue object.
Class Inheritance
System.Object
Declaration
// C#
public sealed class OracleAQDequeueOptions : ICloneable
Requirements
Provider ODP.NET, Unmanaged Driver
Assembly Oracle.DataAccess.dll
Namespace Oracle.DataAccess.Client
.NET Framework 2.0, 3.0, 3.5, 4.0, 4.5
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
OracleAQDequeueOptions Members
OracleAQDequeueOptions members are listed in the following tables.
OracleAQDequeueOptions Constructor
The OracleAQDequeueOptions constructor is listed in Table 12-4.
Table 12-4 OracleAQDequeueOptions Constructor
Constructor Description
Instantiates a new instance of the OracleAQDequeueOptions class
OracleAQDequeueOptions Properties
OracleAQDequeueOptions properties are listed in Table 12-5.
Table 12-5 OracleAQDequeueOptions Properties
Property Description
ConsumerName
Specifies the consumer name for which to dequeue the message
Correlation
Specifies the correlation identifier of the message to be dequeued
DeliveryMode
Specifies the expected delivery mode of the message being dequeued
DequeueMode
Specifies the locking behavior associated with the dequeue operation
MessageId
Specifies the message identifier of the message to be dequeued
NavigationMode
Specifies the position of the message that will be retrieved
ProviderSpecificType
Specifies whether the payload of a dequeued message is provided as an ODP.NET specific type or a .NET type
Visibility
Specifies whether or not the new message is dequeued as part of the current transaction
Wait
Specifies the wait time, in seconds, for a message that matches the search criteria
OracleAQDequeueOptions Public Methods
OracleAQDequeueOptions public methods are listed in Table 12-6.
Table 12-6 OracleAQDequeueOptions Public Methods
Public Method Description
Clone
Creates a copy of an OracleAQDequeueOptions object.
The OracleAQDequeueOptions constructor creates an instance of the OracleAQDequeueOptions class and sets all its properties to their default values.
Declaration
// C#
public OracleAQDequeueOptions();
OracleAQDequeueOptions properties are listed in Table 12-7.
Table 12-7 OracleAQDequeueOptions Properties
ConsumerName
Correlation
DeliveryMode
DequeueMode
MessageId
NavigationMode
Visibility
Wait
ConsumerName
This instance property specifies the consumer name for which to dequeue the message.
Declaration
// C#
public string ConsumerName {get;set;}
Property Value
A string.
Remarks
The ConsumerName property only accesses those messages that match the consumer name. If a queue is not set up for multiple consumers, then this field should be set to null.
Correlation
This instance property specifies the correlation identifier of the message to be dequeued.
Declaration
// C#
public string Correlation {get;set;}
Property Value
A string.
Remarks
This property specifies the identification of the message to be dequeued. Special pattern matching characters, such as the percent sign (%) and the underscore (_) can be used. If more than one message satisfies the pattern, then the order of dequeuing is undetermined.
The maximum length of Correlation is 128.
MessageId and Correlation are two independent identifiers. While MessageId is unique for a message, a group of messages can be assigned the same Correlation. Also, pattern matching is possible only with Correlation.
DeliveryMode
This instance property specifies the expected delivery mode of the message being dequeued.
Declaration
// C#
public OracleAQMessageDeliveryMode DeliveryMode {get;set;}
Property Value
An OracleAQMessageDeliveryMode enumerated value.
Remarks
This property specifies the type of messages to be dequeued. It can be set to dequeue either persistent or buffered messages, or both from a queue. The following values are valid:
  • OracleAQMessageDeliveryMode.Persistent
  • OracleAQMessageDeliveryMode.Buffered
  • OracleAQMessageDeliveryMode.PersistentOrBuffered
The default value is OracleAQMessageDeliveryMode.Persistent.
Buffered messaging is supported in all queue tables created with a database compatibility level of 8.1 or higher.
DequeueMode
This instance property specifies the locking behavior associated with the dequeue operation.
Declaration
// C#
public OracleAQDequeueMode DequeueMode {get;set;}
Property Value
An OracleAQDequeueMode enumerated value.
Exceptions
ArgumentOutOfRangeException - The specified DequeueMode value is invalid.
Remarks
The default value is OracleAQDequeueMode.Remove.
MessageId
This instance property specifies the message identifier of the message to be dequeued.
Declaration
// C#
public byte[] MessageId {get;set;}
Property Value
A byte[ ].
Remarks
The dequeue operation succeeds only if the message ID of the message being dequeued matches with the message ID specified.
NavigationMode
This instance property specifies the position of the message that will be retrieved.
Declaration
// C#
public OracleAQNavigationMode NavigationMode {get;set;}
Property Value
An OracleAQNavigationMode enumerated value.
Exceptions
ArgumentOutOfRangeException - The specified NavigationMode value is invalid.
Remarks
The default value is OracleAQNavigationMode.NextMessage.
This property specifies whether the payload of a dequeued message is provided as an ODP.NET specific type or a .NET type.
Declaration
// C#
public bool ProviderSpecificType {get;set;}
Property Value
A bool.
Remarks
The default value of this property is false. For a discussion of how this property affects payload type, refer to "MessageType" under the OracleAQQueue class.
Visibility
This instance property specifies whether or not the new message is dequeued as part of the current transaction.
Declaration
// C#
public OracleAQVisibilityMode Visibility {get;set;}
Property Value
An OracleAQVisibilityMode enumerated value.
Exceptions
ArgumentOutOfRangeException - The Visibility value specified is invalid.
Remarks
The default value is OracleAQVisibilityMode.OnCommit. You must use transactions when using the default value for this property. This ensures that applications do not lose messages and the messages are appropriately removed from the queue after the dequeue operation is successful. If transactions are not used when using the default visibility mode of OracleAQVisibilityMode.OnCommit, then messages are not removed from the queue.
Using the alternative visibility mode value, OracleAQVisibilityMode.Immediate can eliminate the need to create, commit, and rollback a transaction. However, if an error occurs during the dequeue operation, then the message may be lost.
The visibility parameter is ignored when DequeueMode is set to OracleAQDequeueMode.Browse.
Wait
This instance property specifies the wait time, in seconds, for a message that matches the search criteria.
Declaration
// C#
public int Wait {get;set;}
Property Value
Any positive integer value or 0 or -1.
Exceptions
ArgumentOutOfRangeException - The specified Wait value is invalid.
Remarks
The default value is -1, which implies an infinite wait. The following values are valid:
  • Positive integer: Wait time in seconds.
  • -1: Wait forever.
  • 0: Do not wait.
A value of less than -1 raises an ArgumentOutOfRangeException.
This parameter is ignored if messages in the same group are being dequeued.
The OracleAQDequeueOptions public method is listed in Table 12-8.
Table 12-8 OracleAQDequeueOptions Public Methods
Clone
Clone
This method creates a copy of an OracleAQDequeueOptions object.
Declaration
// C#
public object Clone();
Return Value
An OracleAQDequeueOptions object.
Implements
ICloneable.
Remarks
The cloned object has the same property values as the object being cloned.
