Skip Headers
Oracle® Data Provider for .NET Developer's Guide
12c Release 1 (12.1.0.1.0)
E41125-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleAQNotificationType Enumeration
The OracleAQNotificationType enumeration type specifies the notification type of the received notification.
Table 12-36 lists all the OracleAQNotificationType enumeration values with a description of each enumerated value.
Table 12-36 OracleAQNotificationType Members
Member Name Description
Group
Indicates that the received notification is a grouping notification.
Regular
Indicates that the received notification is a regular notification.
Timeout
Indicates that the received notification is raised due to a timeout.
Requirements
Provider ODP.NET, Unmanaged Driver
Assembly Oracle.DataAccess.dll
Namespace Oracle.DataAccess.Client
.NET Framework 2.0, 3.0, 3.5, 4.0, 4.5
