Skip Headers
Oracle® Data Provider for .NET Developer's Guide
12c Release 1 (12.1.0.1.0)
E41125-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleBoolean Structure
The OracleBoolean structure represents a logical value that is either TRUE or FALSE.
Class Inheritance
System.Object
  System.ValueType
    Oracle.DataAccess.Types.OracleBoolean
Declaration
// C#
public struct OracleBoolean : IComparable, INullable, IXmlSerializable
Requirements
Provider ODP.NET, Unmanaged Driver ODP.NET, Managed Driver
Assembly Oracle.DataAccess.dll Oracle.ManagedDataAccess.dll
Namespace Oracle.DataAccess.Types Oracle.ManagedDataAccess.Types
.NET Framework 2.0, 3.0, 3.5, 4.0, 4.5 4.0, 4.5
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Remarks
A OracleBoolean structure represents three possible values: TRUE, FALSE, and NULL. A non-zero value is interpreted as TRUE.
Example
// C#
using System;
using System.Data;
using Oracle.DataAccess.Types;
 class OracleBooleanSample
    static void Main(string[] args)
      OracleBoolean oracleBoolean1 = new OracleBoolean(true);
      OracleBoolean oracleBoolean2 = new OracleBoolean(0);
      Console.WriteLine("oracleBoolean1 : " + oracleBoolean1);
      Console.WriteLine("oracleBoolean2 : " + oracleBoolean2);
OracleBoolean Members
OracleBoolean members are listed in the following tables:
OracleBoolean Constructors
OracleBoolean constructors are listed in Table 14-14
Table 14-14 OracleBoolean Constructors
Constructor Description
Instantiates a new instance of OracleBoolean structure (Overloaded)
OracleBoolean Static Fields
The OracleBoolean static fields are listed in Table 14-15.
Table 14-15 OracleBoolean Static Fields
Field Description
False
Represents a false value that can be assigned to an OracleBoolean instance
Null
Represents a null value that can be assigned to an OracleBoolean instance
One
Indicates a constant representing the positive one value
True
Represents a true value that can be assigned to an OracleBoolean instance
Zero
Indicates a constant representing the zero value
OracleBoolean Static Methods
OracleBoolean static methods are listed in Table 14-16
Table 14-16 OracleBoolean Static Methods
Methods Description
And
Returns the result of bitwise AND operation of two OracleBoolean instances
Equals
Determines whether or not the two OracleBoolean values are equal
GreaterThan
Determines whether or not the first of two OracleBoolean values is greater than the second
GreaterThanOrEquals
Determines whether or not the first of two OracleBoolean values is greater than or equal to the second
LessThan
Determines whether or not the first of two OracleBoolean values is less than the second
LessThanOrEquals
Determines whether or not the first of two OracleBoolean values is less than or equal to the second
NotEquals
Determines whether or not two OracleBoolean values are not equal
OnesComplement
Returns the result of a one's complement operation on the specified OracleBoolean value
Or
Returns the result of bitwise OR operation of two OracleBoolean instances
Parse
Returns an OracleBoolean structure and sets its value using a string
Xor
Returns the result of a bitwise exclusive OR operation of two OracleBoolean instances
OracleBoolean Static Operators
The OracleBoolean static operators are listed in Table 14-17.
Table 14-17 OracleBoolean Static Operators
Field Description
operator >
operator >=
operator <
operator <=
Dtermines whether or not the first of two OracleBoolean values is less than or equal to the second
operator ==
Indicates whether or not the two OracleBoolean instances are equal
operator !=
operator !
Determines the result of a NOT operation on a OracleBoolean
operator ~
operator false
Determines whether or not the specified OracleBoolean value is false
operator true
Determines whether or not the specified OracleBoolean value is true
operator &
operator |
operator ^
Returns the result of bitwise exclusive OR operation of two OracleBoolean instances
The OracleBoolean Static Type conversions
The OracleBoolean static type conversions are listed in Table 14-18
Table 14-18 OracleBoolean Static Type Conversions
Field Description
implicit operator OracleBoolean
Returns the OracleBoolean representation of a boolean value
explicit operator bool
Returns the boolean representation of the OracleBoolean value
explicit operator OracleBoolean
Converts a structure to an OracleBoolean structure (Overloaded)
OracleBoolean Properties
The OracleBoolean properties are listed in Table 14-25.
Table 14-19 OracleBoolean Properties
Properties Description
ByteValue
Returns a byte that represents the OracleBoolean structure
IsFalse
Indicates whether or not the value of the current instance is false
IsNull
Indicates whether or not the current instance has a null value
IsTrue
Indicates whether or not the value of the current instance is true
Value
Returns a boolean value that represents the current instance
OracleBoolean Instance Methods
The OracleBoolean instance methods are listed in Table 14-20.
Table 14-20 OracleBoolean Instance Methods
Method Description
CompareTo
Compares the current instance to the supplied object and returns an integer that represents their relative values
Equals
Determines whether or not an object is an instance of OracleBoolean, and whether or not the value of the object is equal to the current instance
GetHashCode
Returns a hash code for the current instance
ToString
Returns the string representation of the current instance
The OracleBoolean constructors instantiates a new instance of the OracleBoolean structure.
Overload List:
  • OracleBoolean(bool)
    This constructor creates a new instance of the OracleBoolean structure and sets its value to the supplied Boolean value.
  • OracleBoolean(int)
    This constructor creates a new instance of the OracleBoolean structure and sets its value to the supplied Int32 value.
OracleBoolean(bool)
Declaration
// C#
public OracleBoolean(bool value) ;
Parameters
  • value
    The provided Boolean value.
OracleBoolean(int)
Declaration
// C#
public OracleBoolean(int value)
Parameters
  • value
    The provided Int32 value.
The OracleBoolean static fields are listed in Table 14-21.
Table 14-21 OracleBoolean Static Fields
Field Description
False
Null
One
True
Zero
False
This static field represents a false value that can be assigned to an OracleBoolean instance.
Declaration
// C#
public static readonly OracleBoolean False;
Null
This static field represents a null value that can be assigned to an OracleBoolean instance.
Declaration
// C#
public static readonly OracleBoolean Null;
One
This static field indicates a constant representing the positive one value.
Declaration
// C#
public static readonly OracleBoolean One;
True
This static field represents a true value that can be assigned to an OracleBoolean instance.
Declaration
// C#
public static readonly OracleBoolean True;
Zero
This static field indicates a constant representing the zero value.
Declaration
// C#
public static readonly OracleBoolean Zero;
OracleBoolean static methods are listed in Table 14-22
Table 14-22 OracleBoolean Static Methods
Methods Description
And
Equals
GreaterThan
GreaterThanOrEquals
LessThan
LessThanOrEquals
NotEquals
OnesComplement
Or
Parse
Xor
And
This method returns the result of bitwise AND operation of two OracleBoolean instances.
Declaration
// C#
public static OracleBoolean And(OracleBoolean value1, OracleBoolean value2);
Parameters
  • value1
    An OracleBoolean instance
  • value2
Return Value
An OracleBoolean that contains the value of the result of bitwise AND operation of two OracleBoolean instances.
Remarks
If either of the specified OracleBoolean instances is null, an OracleBoolean with a null value will be returned.
Equals
This method returns an OracleBoolean that indicates whether or not the two OracleBoolean instances are equal.
Declaration
// C#
public static OracleBoolean Equal(OracleBoolean value1, OracleBoolean value2);
Parameters
  • value1
  • value2
Return Value
An OracleBoolean that is true if the specified two OracleBoolean instances are equal; otherwise, returns an OracleBoolean that is false.
Remarks
GreaterThan
This method determines if the first of two OracleBoolean values is greater than the second.
Declaration
// C#
public static OracleBoolean GreaterThan(OracleBoolean value1, OracleBoolean value2);
Parameters
  • value1
    The first OracleBoolean
  • value2
    The second OracleBoolean
Return Value
An OracleBoolean that is true if the first of two OracleBoolean values is greater than the second; otherwise, returns false.
Remarks
GreaterThanOrEquals
This method determines if the first of two OracleBoolean values is greater than or equal to the second.
Declaration
// C#
public static OracleBoolean GreaterThanOrEquals(OracleBoolean value1, OracleBoolean value2);
Parameters
  • value1
  • value2
Return Value
An OracleBoolean that is true if the first of two OracleBoolean values is greater than or equal to the second; otherwise, returns false.
Remarks
LessThan
This method determines if the first of two OracleBoolean values is less than the second.
Declaration
// C#
public static OracleBoolean LessThan(OracleBoolean value1, OracleBoolean value2);
Parameters
  • value1
  • value2
Return Value
An OracleBoolean that is true if the first of two OracleBoolean values is less than the second; otherwise, returns false.
Remarks
LessThanOrEquals
This method determines if the first of two OracleBoolean values is less or equal than the second.
Declaration
// C#
public static OracleBoolean LessThanOrEquals(OracleBoolean value1, OracleBoolean value2);
Parameters
  • value1
  • value2
Return Value
An OracleBoolean that is true if the first of two OracleBoolean values is less than or equal to the second; otherwise, returns false.
Remarks
NotEquals
This method determines if two OracleBoolean values are not equal.
Declaration
// C#
public static OracleBoolean NotEquals(OracleBoolean value1, OracleBoolean value2);
Parameters
  • value1
  • value2
Return Value
An OracleBoolean that is true if two OracleBoolean values are not equal; otherwise, returns false.
Remarks
OnesComplement
This method returns the result of a one's complement operation on the specified OracleBoolean value.
Declaration
// C#
public static OracleBoolean OnesComplement(OracleBoolean value1);
Parameters
  • value1
Return Value
An OracleBoolean that contains the value of the result of a one's complement operation on the specified OracleBoolean value.
Remarks
If the specified OracleBoolean instance is null, an OracleBoolean with a null value will be returned.
Or
This method returns the result of bitwise OR operation of two OracleBoolean instances.
Declaration
// C#
public static OracleBoolean Or(OracleBoolean value1, OracleBoolean value2);
Parameters
  • value1
  • value2
Return Value
An OracleBoolean that contains the value of the result of bitwise OR operation of two OracleBoolean instances.
Remarks
Parse
This method converts a string to an OracleBoolean.
Declaration
// C#
public static OracleBoolean Parse(string str);
Parameters
  • str
    The string being converted.
Return Value
A new OracleBoolean structure.
Exceptions
ArgumentNullException – The str parameter is null.
IndexOutOfRangeException – The str parameter is an empty string.
Xor
This method returns the result of a bitwise exclusive OR operation of two OracleBoolean instances.
Declaration
// C#
public static OracleBoolean Xor(OracleBoolean value1, OracleBoolean value2);
Parameters
  • value1
  • value2
Return Value
An OracleBoolean that contains the value of the result of bitwise exclusive OR operation of two OracleBoolean instances.
Remarks
The OracleBoolean static operators are listed in Table 14-23.
Table 14-23 OracleBoolean Static Operators
Field Description
operator >
operator >=
operator <
operator <=
operator ==
operator !=
operator !
operator ~
operator false
operator true
operator &
operator |
operator ^
operator >
This method determines whether or not the first of two OracleBoolean values is greater than the second.
Declaration
// C#
public static operator  > (OracleBoolean value1, OracleBoolean value2);
Parameters
  • value1
  • value2
Return Value
Remarks
operator >=
This method determines whether or not the first of two OracleBoolean values is greater than or equal to the second.
Declaration
// C#
public static operator  >= (OracleBoolean value1, OracleBoolean value2);
Parameters
  • value1
  • value2
Return Value
Remarks
operator <
This method determines whether or not the first of two OracleBoolean values is less than the second.
Declaration
// C#
public static operator  < (OracleBoolean value1, OracleBoolean value2);
Parameters
  • value1
  • value2
Return Value
Remarks
operator <=
This method determines whether or not the first of two OracleBoolean values is less than or equal to the second.
Declaration
// C#
public static operator  <= (OracleBoolean value1, OracleBoolean value2);
Parameters
  • value1
  • value2
Return Value
Remarks
operator ==
Declaration
// C#
public static operator  == (OracleBoolean value1, OracleBoolean value2);
Parameters
  • value1
  • value2
Return Value
An OracleBoolean that is true if the specified two OracleBoolean instances are equal; otherwise, returns false.
Remarks
operator !=
This method determines whether or not two OracleBoolean values are not equal.
Declaration
// C#
public static operator  != (OracleBoolean value1, OracleBoolean value2);
Parameters
  • value1
  • value2
Return Value
Remarks
operator !
This method determines the result of a NOT operation on a OracleBoolean.
Declaration
// C#
public static operator  ! (OracleBoolean value1);
Parameters
  • value1
Return Value
An OracleBoolean that is true if the specified OracleBoolean value is true; otherwise, returns false.
Remarks
operator ~
Declaration
// C#
public static operator ~ (OracleBoolean value1);
Parameters
  • value1
Return Value
Remarks
operator false
This method determines whether or not the specified OracleBoolean value is false.
Declaration
// C#
public static operator false (OracleBoolean value1);
Parameters
  • value1
Return Value
An OracleBoolean that is true if specified OracleBoolean value is false; otherwise, returns false.
Remarks
This property will return false if the current instance is null.
operator true
This method determines whether or not the specified OracleBoolean value is true.
Declaration
// C#
public static operator true (OracleBoolean value1);
Parameters
  • value1
Return Value
An OracleBoolean that is true if specified OracleBoolean value is true; otherwise, returns false.
Remarks
operator &
Declaration
// C#
public static operator & (OracleBoolean value1, OracleBoolean value2);
Parameters
  • value1
  • value2
Return Value
Remarks
operator |
Declaration
// C#
public static operator | (OracleBoolean value1, OracleBoolean value2);
Parameters
  • value1
  • value2
Return Value
Remarks
operator ^
This method returns the result of bitwise exclusive OR operation of two OracleBoolean instances.
Declaration
// C#
public static operator ^ (OracleBoolean value1, OracleBoolean value2);
Parameters
  • value1
  • value2
Return Value
Remarks
The OracleBoolean static type conversions are listed in Table 14-24
Table 14-24 OracleBoolean Static Type Conversions
Field Description
This method returns the OracleBoolean representation of a boolean value.
Declaration
// C#
public static implicit operator OracleBoolean(bool value1);
Parameters
  • value1
Return Value
An OracleBoolean.
This method returns the boolean representation of the OracleBoolean value.
Declaration
// C#
public static explicit operator bool(OracleBoolean value1);
Parameters
  • value1
    An OracleBoolean structure
Return Value
A boolean
Exception
OracleNullValueExceptionOracleBoolean has a null value.
explicit operator OracleBoolean converts the provided structure to an OracleBoolean structure.
Overload List
explicit operator OracleBoolean(byte)
This method converts the supplied byte to an OracleBoolean structure.
Declaration
// C#
public static explicit operator OracleBoolean(byte value1);
Parameters
  • value1
    A byte
Return Value
An OracleBoolean structure.
explicit operator OracleBoolean(Decimal)
This method converts the supplied Decimal to an OracleBoolean structure.
Declaration
// C#
public static explicit operator OracleBoolean(Decimal value1);
Parameters
  • value1
    A Decimal
Return Value
explicit operator OracleBoolean(Double)
This method converts the supplied Double to an OracleBoolean structure.
Declaration
// C#
public static explicit operator OracleBoolean(Double value1);
Parameters
  • value1
    A Double
Return Value
explicit operator OracleBoolean(Int16)
This method converts the supplied Int16 to an OracleBoolean structure.
Declaration
// C#
public static explicit operator OracleBoolean(Int16 value1);
Parameters
  • value1
    An Int16
Return Value
explicit operator OracleBoolean(int)
This method converts the supplied int to an OracleBoolean structure.
Declaration
// C#
public static explicit operator OracleBoolean(int value1);
Parameters
  • value1
    An int
Return Value
explicit operator OracleBoolean(Int64)
This method converts the supplied Int64 to an OracleBoolean structure.
Declaration
// C#
public static explicit operator OracleBoolean(Int64 value1);
Parameters
  • value1
    An Int64
Return Value
explicit operator OracleBoolean(Single)
This method converts the supplied Single to an OracleBoolean structure.
Declaration
// C#
public static explicit operator OracleBoolean(Single value1);
Parameters
  • value1
    A Single
Return Value
explicit operator OracleBoolean(String)
This method converts the supplied String to an OracleBoolean structure.
Declaration
// C#
public static explicit operator OracleBoolean(String value1);
Parameters
  • value1
    A String
Return Value
Table 14-25 OracleBoolean Properties
ByteValue
IsFalse
IsNull
IsTrue
Value
ByteValue
This property returns a byte that represents the OracleBoolean structure.
Declaration
// C#
public byte ByteValue {get;}
Property Value
A byte that represents the value of OracleBoolean structure.
Exceptions
OracleNullValueException – The current instance has a null value.
IsFalse
This property indicates whether or not the value of the current instance is false.
Declaration
// C#
public bool IsFalse {get;}
Property Value
A bool value that returns true if the current instance is false; otherwise, returns false.
Remarks
IsNull
This property indicates whether or not the current instance has a null value.
Declaration
// C#
public bool IsNull {get;}
Property Value
A bool value that returns true if the current instance has a null value; otherwise, returns false.
IsTrue
This property indicates whether or not the value of the current instance is true.
Declaration
// C#
public bool IsTrue {get;}
Property Value
A bool value that returns true if the current instance is true; otherwise, returns false.
Remarks
Value
This property returns a boolean value that represents the current instance.
Declaration
// C#
public bool Value {get;}
Property Value
Exceptions
The OracleBoolean instance methods are listed in Table 14-26.
Table 14-26 OracleBoolean Instance Methods
Method Description
CompareTo
Equals
GetHashCode
ToString
CompareTo
This method compares the current instance to the supplied object and returns an integer that represents their relative values.
Declaration
// C#
public int CompareTo(object obj);
Parameter
  • obj
    The supplied instance.
Return Value
The method returns a number:
  • Less than zero: if the value of the current instance is less than obj.
  • Zero: if the value of the current instance is equal to obj.
  • Greater than zero: if the value of the current instance is greater than obj.
Implements
IComparable
Exceptions
ArgumentException - The parameter is not of type OracleBoolean.
Remarks
The following rules apply to the behavior of this method.
  • The comparison must be between OracleBoolean. For example, comparing an OracleBoolean instance with an OracleBinary instance is not allowed. When an OracleBoolean is compared with a different type, an ArgumentException is thrown.
  • Any OracleBoolean that has a value compares greater than an OracleBoolean that has a null value.
  • Two OracleBoolean that contain a null value are equal.
Equals
Overrides Object
This method determines whether or not an object is an instance of OracleBoolean, and whether or not the value of the object is equal to the current instance.
Declaration
// C#
public override bool Equals(object obj);
Parameter
  • obj
    An OracleBoolean instance.
Return Value
Returns true if obj is an instance of OracleBoolean, and the value of obj is equal to the current instance; otherwise, returns false.
Remarks
  • Two OracleBooleans that contain a null value are equal.
GetHashCode
Overrides Object
This method returns a hash code for the current instance.
Declaration
// C#
public override int GetHashCode();
Return Value
Returns a hash code.
ToString
Overrides Object
This method returns the string representation of the current instance.
Declaration
// C#
public override string ToString();
Return Value
Returns the OracleBoolean value in a string representation.
Remarks
If the current instance has a null value, the returned string is null.
