Skip Headers
Oracle® Data Provider for .NET Developer's Guide
12c Release 1 (12.1.0.1.0)
E41125-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleBulkCopyOptions Enumeration
The OracleBulkCopyOptions enumeration specifies the values that can be combined with an instance of the OracleBulkCopy class and used as options to determine its behavior and the behavior of the WriteToServer methods for that instance.
Table 17-15 lists all the OracleBulkCopyOptions enumeration values with a description of each enumerated value.
Table 17-15 OracleBulkCopyOptions Enumeration Members
Member Name Description
Default
Indicates that the default value for all options are to be used
UseInternalTransaction
Indicates that each batch of the bulk copy operation occurs within a transaction. If the connection used to perform the bulk copy operation is already part of a transaction, an InvalidOperationException exception is raised.
If this member is not specified, BatchSize number of rows are sent to the database, without any transaction-related activity.
All bulk copy operations are agnostic of any local or distributed transaction created by the application.
Requirements
Provider ODP.NET, Unmanaged Driver
Assembly Oracle.DataAccess.dll
Namespace Oracle.DataAccess.Client
.NET Framework 2.0, 3.0, 3.5, 4.0, 4.5
