Skip Headers
Oracle® Data Provider for .NET Developer's Guide
12c Release 1 (12.1.0.1.0)
E41125-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleCustomTypeMappingAttribute Class
The OracleCustomTypeMappingAttribute class is used to mark a custom type factory class or struct with information that is used by ODP.NET when a custom type is used to represent an Oracle UDT.
Class Inheritance
System.Object
System.Attribute
System.OracleCustomTypeMappingAttribute
Declaration
// C#
[AttributeUsageAttribute(AttributeTargets.Class|AttributeTargets.Struct,
   AllowMultiple=false, Inherited=true)]
public sealed class OracleCustomTypeMappingAttribute : Attribute
Requirements
Provider ODP.NET, Unmanaged Driver
Assembly Oracle.DataAccess.dll
Namespace Oracle.DataAccess.Types
.NET Framework 2.0, 3.0, 3.5, 4.0, 4.5
Remarks
The OracleCustomTypeMapping attribute must be specified on the custom type factory class to indicate the Oracle UDT that the corresponding custom type represents. The Oracle UDT may be specified in the form schema_name.type_name.
For each Oracle UDT that the application uses, there must be a unique custom type factory, as follows:
If the OracleCustomTypeMappingAttribute is not specified, then custom type mappings must be specified through an XML configuration file, for example, app.config for Windows applications or the web.config for web applications, and the machine.config
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
OracleCustomTypeMappingAttribute Members
OracleCustomTypeMappingAttribute members are listed in the following tables.
OracleCustomTypeMappingAttribute Constructors
OracleCustomTypeMappingAttribute constructors are listed in Table 16-1.
Table 16-1 OracleCustomTypeMappingAttribute Constructors
Constructor Description
Instantiates a new instance of OracleCustomTypeMappingAttribute class
OracleCustomTypeMappingAttribute Static Methods
OracleCustomTypeMappingAttribute static methods are listed in Table 16-2.
Table 16-2 OracleCustomTypeMappingAttribute Static Methods
Method Description
Equals
Inherited from System.Attribute
GetCustomAttribute
GetCustomAttributes
IsDefined
ReferenceEquals
OracleCustomTypeMappingAttribute Properties
OracleCustomTypeMappingAttribute properties are listed in Table 16-3.
Table 16-3 OracleCustomTypeMappingAttribute Properties
Property Description
UdtTypeName
Specifies the Oracle user-defined type name that the custom class maps to
TypeId
OracleCustomTypeMappingAttribute Methods
OracleCustomTypeMappingAttribute methods are listed in Table 16-4.
Table 16-4 OracleCustomTypeMappingAttribute Methods
Method Description
Equals
GetHashCode
GetType
IsDefaultAttribute
Match
ToString
OracleCustomTypeMappingAttribute constructors create new instances of the OracleCustomTypeMappingAttribute class.
Overload List:
OracleCustomTypeMappingAttribute(string)
This constructor creates and initializes an OracleCustomTypeMappingAttribute using the specified Oracle user-defined type name.
Declaration
// C#
public OracleCustomTypeMappingAttribute(string udtTypeName)
Parameters
  • udtTypeName
    The Oracle user-defined type name that the custom class maps to.
Remarks
The udtTypeName parameter is case-sensitive. The udtTypeName is specified in the form of schema_name.type_name.
OracleCustomTypeMappingAttribute static methods are listed in Table 16-5.
Table 16-5 OracleCustomTypeMappingAttribute Static Methods
Method Description
Equals
GetCustomAttribute
GetCustomAttributes
IsDefined
ReferenceEquals
OracleCustomTypeMappingAttribute properties are listed in Table 16-6.
Table 16-6 OracleCustomTypeMappingAttribute Properties
UdtTypeName
TypeId
UdtTypeName
This property specifies the Oracle user-defined type name that the custom class maps to.
Declaration
// C#
public string UdtTypeName {get; set;}
Property Value
A string that represents an Oracle user-defined type name.
Remarks
UdtTypeName is case-sensitive. It is specified in the form of schema_name.type_name.
OracleCustomTypeMappingAttribute methods are listed in Table 16-7.
Table 16-7 OracleCustomTypeMappingAttribute Methods
Method Description
Equals
GetHashCode
GetType
IsDefaultAttribute
Match
ToString
