| Oracle® Data Provider for .NET Developer's Guide 12c Release 1 (12.1.0.1.0) E41125-02 |
![]() Previous |
![]() Next |
An OracleDataReader object represents a forward-only, read-only, in-memory result set.
Unlike the DataSet, the OracleDataReader object stays connected and fetches one row at a time.
The following section contain related information:
Class Inheritance
System.Object
System.MarshalByRefObject
System.Data.Common.DataReader
System.Data.Common.DbDataReader
Oracle.DataAccess.Client.OracleDataReader
Declaration
// C# public sealed class OracleDataReader : DbDataReader, IEnumerable, IDataReader, IDisposable, IDataRecord
Requirements
| Provider | ODP.NET, Unmanaged Driver | ODP.NET, Managed Driver |
| Assembly | Oracle.DataAccess.dll |
Oracle.ManagedDataAccess.dll |
| Namespace | Oracle.DataAccess.Client |
Oracle.ManagedDataAccess.Client |
| .NET Framework | 2.0, 3.0, 3.5, 4.0, 4.5 | 4.0, 4.5 |
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Remarks
An OracleDataReader instance is constructed by a call to the ExecuteReader method of the OracleCommand object. The only properties that can be accessed after the DataReader is closed or has been disposed, are IsClosed and RecordsAffected.
To minimize the number of open database cursors, OracleDataReader objects should be explicitly disposed.
Example
The following OracleDataReader example retrieves the data from the EMP table:
/* Database Setup, if you have not done so yet.
connect scott/tiger@oracle
CREATE TABLE empInfo (
empno NUMBER(4) PRIMARY KEY,
empName VARCHAR2(20) NOT NULL,
hiredate DATE,
salary NUMBER(7,2),
jobDescription Clob,
byteCodes BLOB
Insert into empInfo(EMPNO,EMPNAME,JOBDESCRIPTION,byteCodes) values
(1,'KING','SOFTWARE ENGR', '5657');
(2,'SCOTT','MANAGER', '5960');
commit;
// C#
using System;
using System.Data;
using Oracle.DataAccess.Client;
class OracleDataReaderSample
static void Main()
string constr = "User Id=scott;Password=tiger;Data Source=oracle";
OracleConnection con = new OracleConnection(constr);
con.Open();
string cmdstr = "SELECT * FROM EMPINFO";
OracleConnection connection = new OracleConnection(constr);
OracleCommand cmd = new OracleCommand(cmdstr, con);
OracleDataReader reader = cmd.ExecuteReader();
// Declare the variables to retrieve the data in EmpInfo
short empNo;
string empName;
DateTime hireDate;
double salary;
string jobDesc;
byte[] byteCodes = new byte[10];
// Read the next row until end of row
while (reader.Read())
empNo = reader.GetInt16(0);
Console.WriteLine("Employee number: " + empNo);
empName = reader.GetString(1);
Console.WriteLine("Employee name: " + empName);
// The following columns can have NULL value, so it
// is important to call IsDBNull before getting the column data
if (!reader.IsDBNull(2))
hireDate = reader.GetDateTime(2);
Console.WriteLine("Hire date: " + hireDate);
if (!reader.IsDBNull(3))
salary = reader.GetDouble(3);
Console.WriteLine("Salary: " + salary);
if (!reader.IsDBNull(4))
jobDesc = reader.GetString(4);
Console.WriteLine("Job Description: " + jobDesc);
if (!reader.IsDBNull(5))
long len = reader.GetBytes(5, 0, byteCodes, 0, 10);
Console.Write("Byte codes: ");
for (int i = 0; i < len; i++)
Console.Write(byteCodes[i].ToString("x"));
Console.WriteLine();
// Clean up
reader.Dispose();
con.Dispose();
OracleDataReader members are listed in the following tables.
OracleDataReader Static Methods
The OracleDataReader static method is listed in Table 5-43.
Table 5-43 OracleDataReader Static Method
| Method | Description |
Inherited from |
OracleDataReader Properties
OracleDataReader properties are listed in Table 5-44.
Table 5-44 OracleDataReader Properties
| Property | Description |
Gets a value indicating the depth of nesting for the current row |
Specifies the size of |
Gets the number of columns in the result set |
Indicates whether the |
Gets the number of fields in the |
Indicates whether or not the data reader is closed |
Gets the value of the column (Overloaded) |
Specifies the amount that the |
Gets the number of rows changed, inserted, or deleted by execution of the SQL statement |
Gets the amount of memory the internal cache of the |
OracleDataReader Public Methods
OracleDataReader public methods are listed in Table 5-45.
Table 5-45 OracleDataReader Public Methods
| Public Method | Description |
Closes the |
Inherited from |
Releases any resources or memory allocated by the object |
Inherited from |
Not Supported |
Returns the byte value of the specified column |
Populates the provided byte array with up to the maximum number of bytes, from the specified offset (in bytes) of the column |
Not Supported |
Populates the provided character array with up to the maximum number of characters, from the specified offset (in characters) of the column |
Not Supported |
Returns the ODP.NET type name of the specified column |
Returns the |
Returns the |
Returns the |
Returns an |
Returns the |
Returns the |
Not Supported |
Inherited from |
Returns the |
Returns the |
Returns the |
Inherited by |
Returns the name of the specified column |
Returns an |
Returns an |
Returns an |
Returns an updatable |
Returns an |
Returns an |
Returns an |
Returns an |
Returns an |
Returns an |
Returns an |
Returns an |
Returns an |
Returns an |
Returns an |
Returns the specified column value as a ODP.NET type |
Gets all the column values as ODP.NET types |
Returns the |
Returns the provider-specific type of the specified column |
Returns an object that represents the underlying provider-specific value of the specified ordinal |
Returns an array of objects that represent the underlying provider-specific values |
Returns a |
Returns the string value of the specified column |
Returns the |
Inherited from |
Returns the column value as a .NET type |
Gets all the column values as .NET types |
Returns the value of an |
Indicates whether or not the column value is null |
Advances the data reader to the next result set when reading the results |
Reads the next row in the result set |
Inherited from |
The OracleDataReader static method is listed in Table 5-46.
OracleDataReader properties are listed in Table 5-47.
Table 5-47 OracleDataReader Properties
This property gets a value indicating the depth of nesting for the current row.
Declaration
// C#
public override int Depth {get;}
Property Value
The depth of nesting for the current row.
Implements
IDataReader
Exceptions
InvalidOperationException - The reader is closed.
Remarks
Default = 0
This property always returns zero because Oracle does not support nesting.
This property specifies the size of OracleDataReader's internal cache.
Declaration
// C#
public long FetchSize {get; set;}
Property Value
A long that specifies the amount of memory (in bytes) that the OracleDataReader uses for its internal cache.
Exceptions
ArgumentException - The FetchSize value specified is invalid.
Remarks
Default = The OracleCommand's FetchSize property value.
The FetchSize property is inherited by the OracleDataReader that is created by a command execution returning a result set. The FetchSize property on the OracleDataReader object determines the amount of data fetched into its internal cache for each database round-trip.
The RowSize and FetchSize properties handle UDT and XMLType data differently than other scalar data types. Because only a reference to the UDT and XMLType data is stored in the ODP.NET's internal cache, the RowSize property accounts for only the memory needed for the reference (which is very small) and not the actual size of the UDT and XMLType data. Thus, applications can inadvertently fetch a large number of UDT or XMLType instances from the database in a single database round-trip. This is because the actual size of UDT and XMLType data does not count against the FetchSize, and it would require numerous UDT and XMLType references to fill up the default cache size of 131072 bytes. Therefore, when fetching UDT or XMLType data, the FetchSize property must be appropriately configured to control the number of UDT and XMLType instances that are to be fetched, rather than the amount of the actual UDT and XMLType data to be fetched.
NOTE: For LOB and LONG data types, only the sizes specified in the InitialLOBFetchSize and InitialLONGFetchSize properties are accounted for by the RowSize property in addition to the metadata and reference information that is maintained by the cache for each LOB in the select list.
See Also:
This property returns the number of columns in the result set.
Declaration
// C#
public override int FieldCount {get;}
Property Value
The number of columns in the result set if one exists, otherwise 0.
Implements
IDataRecord
Exceptions
Remarks
Default = 0
This property has a value of 0 for queries that do not return result sets.
This property indicates whether the OracleDataReader has one or more rows.
Declaration
// C#
public override bool HasRows {get;}
Return Value
bool
Remarks
HasRows indicates whether or not the OracleDataReader has any rows.
The value of HasRows does not change based on the row position. For example, even if the application has read all the rows from the result set and the next Read method invocation will return false, the HasRows property still returns true since the result set was not empty to begin with.
Rows are fetched to determine the emptiness of the OracleDataReader when HasRows property is accessed for the first time after the creation of the OracleDataReader object.
Example
// C#
using System;
class HasRowsSample
static void Main()
con.Open();
"select * from emp where empno = 9999", con);
if (!reader.HasRows)
Console.WriteLine("The result set is empty.");
else
Console.WriteLine("The result set is not empty.");
con.Dispose();
See Also:
This property gets the number of fields in the OracleDataReader that are hidden.
Declaration
// C#
public int HiddenFieldcount { get; }
Property Value
The number of fields in the OracleDataReader that are hidden.
Exceptions
Remarks
OracleDataReader.FieldCount and OracleDataReader.VisibleFieldCount return the visible field count.
This property indicates whether or not the data reader is closed.
Declaration
// C#
public override bool IsClosed {get;}
Property Value
If the OracleDataReader is in a closed state, returns true; otherwise, returns false.
Implements
IDataReader
Remarks
Default = true
IsClosed and RecordsAffected are the only two properties that are accessible after the OracleDataReader is closed.
This property gets the value of the column in .NET data type.
Overload List:
This property gets the .NET Value of the column specified by the column index.
This property gets the .NET Value of the column specified by the column name.
Declaration
// C#
public override object this[int index] {get;}
Parameters
index
The zero-based index of the column.
Property Value
The .NET value of the specified column.
Implements
IDataRecord
Remarks
Default = Not Applicable
In C#, this property is the indexer for this class.
Declaration
// C#
public override object this[string columnName] {get;}
Parameters
columnName
The name of the column.
Property Value
The .NET Value of the specified column.
Implements
IDataRecord
Remarks
A case-sensitive search is made to locate the specified column by its name. If this fails, then a case-insensitive search is made.
This property specifies the amount that the OracleDataReader initially fetches for LOB columns.
Declaration
// C#
public int InitialLOBFetchSize {get;}
Property Value
The size of the chunk to retrieve.
Exceptions
Remarks
For Oracle Database 10g release 2 (10.2) and later, the maximum value supported for InitialLOBFetchSize is 2 GB.
For releases prior to Oracle Database 10g release 2 (10.2), the maximum value supported for InitialLOBFetchSize is 32K.
Default is the OracleCommand.InitialLOBFetchSize, from which this value is inherited.
See Also:
This property specifies the amount that the OracleDataReader initially fetches for LONG and LONG RAW columns.
Declaration
// C#
public long InitialLONGFetchSize {get;}
Property Value
The size of the chunk to retrieve. The default is 0.
Exceptions
Remarks
The maximum value supported for InitialLONGFetchSize is 32767. If this property is set to a higher value, the provider resets it to 32767.
Default is OracleCommand.InitialLONGFetchSize, from which this value is inherited.
This property is read-only for the OracleDataReader.
See Also:
This property gets the number of rows changed, inserted, or deleted by execution of the SQL statement.
Declaration
// C#
public int RecordsAffected {get;}
Property Value
The number of rows affected by execution of the SQL statement.
Implements
IDataReader
Remarks
Default = 0
The value of -1 is returned for SELECT statements.
This property gets the amount of memory the internal cache of the OracleDataReader needs to store one row of data.
Declaration
// C#
public long RowSize {get;}
Property Value
A long that indicates the amount of memory (in bytes) that an OracleDataReader needs to store one row of data for the executed query.
Remarks
The RowSize property is set to a nonzero value when the OracleDataReader object is created. This property can be used at design time or dynamically during runtime, to set the FetchSize property, based on the number of rows. For example, to enable the OracleDataReader object to fetch N rows for each database round-trip, the OracleDataReader FetchSize property can be set dynamically to RowSize * N. Note that for the FetchSize property to take effect appropriately, it must be set before the first invocation of OracleDataReader.Read() for the particular result set.
ODP.NET now supports values up to 32K for VARCHAR2, NVARCHAR2 or RAW type columns in its calculation of RowSize value
This property gets the number of fields in the OracleDataReader that are not hidden.
Declaration
// C#
public override int VisibleFieldcount { get; }
Property Value
The number of fields that are not hidden.
Exceptions
Remarks
If an application sets the AddRowid property on an OracleCommand object to true, then the application can access the RowId but it is not a visible field. If RowId is added in the select statement list, then it is a visible field. OracleDataReader.VisibleFieldCount and OracleDataReader.FieldCount always have the same value.
Example
// C#
using System;
using System.Data;
using System.Data.Common;
class VisibleFieldCountSample
static void Main(string[] args)
string constr = "User Id=scott; Password=tiger; Data Source=oracle;";
DbProviderFactory factory =
DbProviderFactories.GetFactory("Oracle.DataAccess.Client");
using (DbConnection conn = factory.CreateConnection())
conn.ConnectionString = constr;
try
conn.Open();
OracleCommand cmd = (OracleCommand)factory.CreateCommand();
cmd.Connection = (OracleConnection)conn;
//to gain access to ROWIDs of the table
cmd.AddRowid = true;
cmd.CommandText = "select empno, ename from emp;";
int visFC = reader.VisibleFieldCount; //Results in 2
int hidFC = reader.HiddenFieldCount; // Results in 1
Console.Write("Visible field count: " + visFC);
Console.Write("Hidden field count: " + hidFC);
reader.Dispose();
cmd.Dispose();
catch (Exception ex)
Console.WriteLine(ex.Message);
Console.WriteLine(ex.StackTrace);
OracleDataReader public methods are listed in Table 5-48.
Table 5-48 OracleDataReader Public Methods
Closes the |
Inherited from |
Inherited from |
Not Supported |
Not Supported |
Not Supported |
Returns the |
Returns the |
Returns the |
Returns an |
Returns the |
Returns the |
Not Supported |
Inherited from |
Returns the |
Returns the |
Returns the |
Inherited by |
Returns an |
Returns an |
Returns an |
Returns an updatable Not Available in ODP.NET, Managed Driver |
Returns an |
Returns an |
Returns an |
Returns an |
Returns an |
Returns an Not Available in ODP.NET, Managed Driver |
Returns an |
Returns an |
Returns an |
Returns an |
Returns the |
Returns a |
Returns the |
Inherited from |
Inherited from |
This method closes the OracleDataReader.
Declaration
// C# public override void Close();
Implements
IDataReader
Remarks
The Close method frees all resources associated with the OracleDataReader.
Example
The code example for the OracleDataReader class includes the Close method. See OracleDataReader Overview "Example".
This method releases any resources or memory allocated by the object.
Declaration
// C# public void Dispose();
Implements
IDisposable
Remarks
The Dispose method also closes the OracleDataReader.
This method is not supported.
Declaration
// C#
public override bool GetBoolean(int index);
Parameters
index
The zero-based column index.
Implements
IDataRecord
Exceptions
NotSupportedException - This property is not supported.
This method returns the byte value of the specified column.
Declaration
// C#
public override byte GetByte(int index);
Parameters
index
Return Value
The value of the column as a byte.
Implements
IDataRecord
Exceptions
InvalidOperationException - The connection is closed, the reader is closed, Read() has not been called, or all rows have been read.
IndexOutOfRangeException - The column index is invalid.
InvalidCastException - The accessor method is invalid for this column type or the column value is NULL.
Remarks
IsDBNull should be called to check for NULL values before calling this method.
This method populates the provided byte array with up to the maximum number of bytes, from the specified offset (in bytes) of the column.
Declaration
// C# public override long GetBytes(int index, long fieldOffset, byte[] buffer, int bufferOffset, int length);
Parameters
index
fieldOffset
The offset within the column from which reading begins (in bytes).
buffer
The byte array that the data is read into.
bufferOffset
The offset within the buffer to begin reading data into (in bytes).
length
The maximum number of bytes to read (in bytes).
Return Value
The number of bytes read.
Implements
IDataRecord
Exceptions
Remarks
This method returns the number of bytes read into the buffer. This may be less than the actual length of the field if the method has been called previously for the same column.
If a null reference is passed for buffer, the length of the field in bytes is returned.
Declaration
// C#
public override long GetChar(int index);
Parameters
index
The zero based column index.
Implements
IDataRecord
Exceptions
This method populates the provided character array with up to the maximum number of characters, from the specified offset (in characters) of the column.
Declaration
// C# public override long GetChars(int index, long fieldOffset, char[] buffer, int bufferOffset, int length);
Parameters
index
fieldOffset
The index within the column from which to begin reading (in characters).
buffer
The character array that the data is read into.
bufferOffset
The index within the buffer to begin reading data into (in characters).
length
The maximum number of characters to read (in characters).
Return Value
The number of characters read.
Implements
IDataRecord
Exceptions
Remarks
This method returns the number of characters read into the buffer. This may be less than the actual length of the field, if the method has been called previously for the same column.
If a null reference is passed for buffer, the length of the field in characters is returned.
This method returns the ODP.NET type name of the specified column.
Declaration
// C#
public override string GetDataTypeName(int index);
Parameters
index
Return Value
The name of the ODP.NET type of the column.
Implements
IDataRecord
Exceptions
This method returns the DateTime value of the specified column.
Declaration
// C#
public override DateTime GetDateTime(int index);
Parameters
index
Return Value
The DateTime value of the column.
Implements
IDataRecord
Exceptions
Remarks
This method returns the decimal value of the specified NUMBER column.
Declaration
// C#
public override decimal GetDecimal(int index);
Parameters
index
Return Value
The decimal value of the column.
Implements
IDataRecord
Exceptions
Remarks
This method returns the double value of the specified NUMBER column or BINARY_DOUBLE column.
Declaration
// C#
public override double GetDouble(int index);
Parameters
index
Return Value
The double value of the column.
Implements
IDataRecord
Exceptions
Remarks
Starting with Oracle Database 10g, GetDouble now supports retrieval of data from BINARY_DOUBLE columns.
This method returns an IEnumerator that can be used to iterate through the collection (record set).
Declaration
// C# public override IEnumerator GetEnumerator();
Return Value
An IEnumerator that can be used to iterate through the collection (record set).
Exceptions
This method returns the type of the specified column.
Declaration
// C#
public override Type GetFieldType(int index);
Parameters
index
Return Value
The type of the default .NET type of the column.
Implements
IDataRecord
Exceptions
InvalidOperationException - The reader is closed, or the specified column is a UDT but no registered custom type mapping exists for the UDT.
Remarks
GetFieldType returns a type that corresponds to the value that the application obtains after invoking the GetValue accessor or Item property on the OracleDataReader. For example, if the column is a string, this method returns a .NET Type object for a .NET string.
If the attribute is a UDT, this method may return either of the following:
A .NET Type of the custom type if a custom type mapping exists for the Oracle object or collection.
A .NET Type of string if the column is an Oracle REF.
This method returns the float value of the specified NUMBER column or BINARY_FLOAT column.
Declaration
// C#
public override float GetFloat(int index);
Parameters
index
Return Value
The float value of the column.
Implements
IDataRecord
Exceptions
Remarks
Starting with Oracle Database 10g, GetFloat now supports retrieval of data from BINARY_FLOAT columns.
Declaration
// C#
public override Guid GetGuid(int index);
Parameters
index
Implements
IDataRecord
Exceptions
This method returns the Int16 value of the specified NUMBER column.
Note: short is equivalent to Int16. |
Declaration
// C#
public override short GetInt16(int index);
Parameters
index
Return Value
The Int16 value of the column.
Implements
IDataRecord
Exceptions
Remarks
This method returns the Int32 value of the specified NUMBER column.
Note: int is equivalent to Int32. |
Declaration
// C#
public override int GetInt32(int index);
Parameters
index
Return Value
The Int32 value of the column.
Implements
IDataRecord
Exceptions
Remarks
This method returns the Int64 value of the specified NUMBER column.
Note: long is equivalent to Int64. |
Declaration
// C#
public override long GetInt64(int index);
Parameters
index
Return Value
The Int64 value of the column.
Implements
IDataRecord
Exceptions
Remarks
This method returns the name of the specified column.
Declaration
// C#
public override string GetName(int index);
Parameters
index
Return Value
Implements
IDataRecord
Exceptions
This method returns an OracleBFile object of the specified BFILE column.
Declaration
// C#
public OracleBFile GetOracleBFile(int index);
Parameters
index
Return Value
The OracleBFile value of the column.
Exceptions
Remarks
This method returns an OracleBinary structure of the specified column.
Declaration
// C#
public OracleBinary GetOracleBinary(int index);
Parameters
index
Return Value
The OracleBinary value of the column.
Exceptions
Remarks
GetOracleBinary is used on the following Oracle types:
BFILE
BLOB
LONG RAW
RAW
This method returns an OracleBlob object of the specified BLOB column.
Declaration
// C#
public OracleBlob GetOracleBlob(int index);
Parameters
index
Return Value
The OracleBlob value of the column.
Exceptions
Remarks
GetOracleBlobForUpdate returns an updatable OracleBlob object of the specified BLOB column.
Overload List:
This method returns an updatable OracleBlob object of the specified BLOB column.
GetOracleBlobForUpdate(int, int)
This method returns an updatable OracleBlob object of the specified BLOB column using a WAIT clause.
Declaration
// C#
public OracleBlob GetOracleBlobForUpdate(int index);
Parameters
index
Return Value
An updatable OracleBlob object.
Exceptions
Remarks
When the OracleCommand's ExecuteReader() method is invoked, all the data fetched by the OracleDataReader is from a particular snapshot. Therefore, calling an accessor method on the same column always returns the same value. However, the GetOracleBlobForUpdate() method incurs a database round-trip to obtain a reference to the current BLOB data while also locking the row using the FOR UPDATE clause. This means that the OracleBlob obtained from GetOracleBlob() can have a different value than the OracleBlob obtained from GetOracleBlobForUpdate() since it is not obtained from the original snapshot.
The returned OracleBlob object can be used to safely update the BLOB because the BLOB column has been locked after a call to this method.
Invoking this method internally executes a SELECT..FOR UPDATE statement without a WAIT clause. Therefore, the statement can wait indefinitely until a lock is acquired for that row.
Example
The following example gets the OracleBlob object for update from the reader, updates the OracleBlob object, and then commits the transaction.
hiredate DATE,
salary NUMBER(7,2),
byteCodes BLOB
commit;
// C#
using System;
using System.Data;
using Oracle.DataAccess.Types;
class GetOracleBlobForUpdateSample
static void Main()
con.Open();
// Get the ByteCodes for empno = 1
string cmdstr = "SELECT BYTECODES, EMPNO FROM EMPINFO where EMPNO = 1";
// Since we are going to update the OracleBlob object, we will
//have to create a transaction
OracleTransaction txn = con.BeginTransaction();
// Get the reader
OracleBlob byteCodesBlob;
// Read the first row
reader.Read();
if (!reader.IsDBNull(0))
byteCodesBlob = reader.GetOracleBlobForUpdate(0);
// Close the reader
reader.Close();
// Update the ByteCodes object
byte[] addedBytes = new byte[2] {0, 0};
byteCodesBlob.Append(addedBytes, 0, addedBytes.Length);
// Now commit the transaction
txn.Commit();
Console.WriteLine("Blob Column successfully updated");
else
reader.Dispose();
// Close the connection
con.Dispose();
Declaration
// C# public OracleBlob GetOracleBlobForUpdate(int index, int wait);
Parameters
index
wait
The number of seconds the method waits to acquire a lock.
Return Value
Exceptions
Remarks
Invoking this method internally executes a SELECT..FOR UPDATE statement which locks the row.
Different WAIT clauses are appended to the statement, depending on the wait value. If the wait value is:
0
"NOWAIT" is appended at the end of a SELECT..FOR UPDATE statement. The statement executes immediately whether the lock is acquired or not. If the lock is not acquired, an exception is thrown.
n
"WAIT n" is appended at the end of a SELECT..FOR UPDATE statement. The statement executes as soon as the lock is acquired. However, if the lock cannot be acquired by n seconds, this method call throws an exception.
The WAIT n" feature is only available for Oracle9i or later. For any version lower than Oracle9i, n is implicitly treated as -1 and nothing is appended at the end of a SELECT..FOR UPDATE statement.
-1
Nothing is appended at the end of the SELECT..FOR UPDATE. The statement execution waits indefinitely until a lock can be acquired.
Example
The GetOracleBlobForUpdate methods are comparable. See "Example" for a code example demonstrating usage.
This method returns an OracleClob object of the specified CLOB column.
Declaration
// C#
public OracleClob GetOracleClob(int index);
Parameters
index
Return Value
The OracleClob value of the column.
Exceptions
Remarks
GetOracleClobForUpdate returns an updatable OracleClob object of the specified CLOB column.
Overload List:
This method returns an updatable OracleClob object of the specified CLOB column.
GetOracleClobForUpdate(int, int)
This method returns an updatable OracleClob object of the specified CLOB column using a WAIT clause.
Declaration
// C#
public OracleClob GetOracleClobForUpdate(int index);
Parameters
index
Return Value
An updatable OracleClob.
Exceptions
Remarks
When the OracleCommand's ExecuteReader() method is invoked, all the data fetched by the OracleDataReader is from a particular snapshot. Therefore, calling an accessor method on the same column always returns the same value. However, the GetOracleClobForUpdate() method incurs a database round-trip to obtain a reference to the current CLOB data while also locking the row using the FOR UPDATE clause. This means that the OracleClob obtained from GetOracleClob() can have a different value than the OracleClob obtained from GetOracleClobForUpdate() since it is not obtained from the original snapshot.
The returned OracleClob object can be used to safely update the CLOB because the CLOB column is locked after a call to this method.
Example
The following example gets the OracleClob object for update from the reader, updates the OracleClob object, and then commits the transaction.
hiredate DATE,
salary NUMBER(7,2),
byteCodes BLOB
commit;
// C#
using System;
using System.Data;
class GetOracleClobForUpdateSample
static void Main()
con.Open();
// Get the job description for empno = 1
string cmdStr = "SELECT JOBDESCRIPTION, EMPNO FROM EMPINFO where EMPNO = 1";
OracleCommand cmd = new OracleCommand(cmdStr, con);
// Since we are going to update the OracleClob object, we will
// have to create a transaction
// Get the reader
OracleClob jobDescClob;
reader.Read();
jobDescClob = reader.GetOracleClobForUpdate(0);
// Close the reader
reader.Close();
// Update the job description Clob object
char[] jobDesc = "-SALES".ToCharArray();
jobDescClob.Append(jobDesc, 0, jobDesc.Length);
txn.Commit();
Console.WriteLine("Clob Column successfully updated");
else
reader.Close();
con.Close();
Declaration
// C# public OracleClob GetOracleClobForUpdate(int index, int wait);
Parameters
index
wait
Return Value
Exceptions
Remarks
0
n
-1
Example
The GetOracleClobForUpdate methods are comparable. See "Example" for a code example demonstrating usage.
This method returns an OracleDate structure of the specified DATE column.
Declaration
// C#
public OracleDate GetOracleDate(int index);
Parameters
index
Return Value
The OracleDate value of the column.
Exceptions
Remarks
This method returns an OracleDecimal structure of the specified NUMBER column.
Declaration
// C#
public OracleDecimal GetOracleDecimal(int index);
Parameters
index
Return Value
The OracleDecimal value of the column.
Exceptions
Remarks
This method returns an OracleIntervalDS structure of the specified INTERVAL DAY TO SECOND column.
Declaration
// C#
public OracleIntervalDS GetOracleIntervalDS(int index);
Parameters
index
Return Value
The OracleIntervalDS value of the column.
Exceptions
Remarks
This method returns an OracleIntervalYM structure of the specified INTERVAL YEAR TO MONTH column.
Declaration
// C#
public OracleIntervalYM GetOracleIntervalYM(int index);
Parameters
index
Return Value
The OracleIntervalYM value of the column.
Exceptions
Remarks
This method returns an OracleRef object of the specified REF column.
Declaration
// C#
public OracleRef GetOracleRef(int index);
Parameters
index
Return Value
The OracleRef object of the specified column.
Exceptions
InvalidOperationException - The connection is closed, the reader is closed, the Read method has not been called, or all rows have been read.
InvalidCastException - The accessor method is invalid for this column type.
This method returns an OracleString structure of the specified column.
Declaration
// C#
public OracleString GetOracleString(int index);
Parameters
index
Return Value
The OracleString value of the column.
Exceptions
Remarks
If the column is an Oracle REF column, the string returned is a hexadecimal value that represents the REF in the database.
This method returns an OracleTimeStamp structure of the Oracle TimeStamp column.
Declaration
// C#
public OracleTimeStamp GetOracleTimeStamp(int index);
Parameters
index
Return Value
The OracleTimeStamp value of the column.
Exceptions
Remarks
GetOracleTimeStamp is used with the Oracle Type TimeStamp.
This method returns an OracleTimeStampLTZ structure of the specified Oracle TimeStamp WITH LOCAL TIME ZONE column.
Declaration
// C#
public OracleTimeStampLTZ GetOracleTimeStampLTZ(int index);
Parameters
index
Return Value
The OracleTimeStampLTZ value of the column.
Exceptions
Remarks
GetOracleTimeStampLTZ is used with the Oracle Type TimeStamp with Local Time Zone columns.
This method returns an OracleTimeStampTZ structure of the specified Oracle TimeStamp WITH TIME ZONE column.
Declaration
// C#
public OracleTimeStampTZ GetOracleTimeStampTZ(int index);
Parameters
index
Return Value
The OracleTimeStampTZ value of the column.
Exceptions
Remarks
Used with the Oracle Type TimeStamp with Local Time Zone columns
This method returns an OracleXmlType object of the specified XMLType column.
Declaration
// C#
public OracleXmlType GetOracleXmlType(int index);
Parameters
index
Return Value
The OracleXmlType value of the column.
Exceptions
Remarks
Requirements
This property can only be used with Oracle9i Release 2 (9.2) or later.
This method returns the specified column value as an ODP.NET type.
Declaration
// C#
public object GetOracleValue(int index);
Parameters
index
Return Value
The value of the column as an ODP.NET type.
Exceptions
Remarks
If the column is an Oracle object or Oracle collection column and a custom type mapping exists, then a custom type is returned.
If the column is an Oracle REF column, then an OracleRef is returned.
This method gets all the column values as ODP.NET types.
Declaration
// C#
public int GetOracleValues(object[] values);
Parameters
values
An array of objects to hold the ODP.NET types as the column values.
Return Value
The number of ODP.NET types in the values array.
Exceptions
Remarks
This method provides a way to retrieve all column values rather than retrieving each column value individually.
The number of column values retrieved is the minimum of the length of the values array and the number of columns in the result set.
This method returns the 0-based ordinal (or index) of the specified column name.
Declaration
// C#
public override int GetOrdinal(string name);
Parameters
name
The specified column name.
Return Value
The index of the column.
Implements
IDataRecord
Exceptions
Remarks
This method returns the provider-specific type of the specified column.
Declaration
// C#public override Type GetProviderSpecificFieldType(int index);
Parameters
index
A zero-based column index.
Return Value
The provider-specific type of the specified column. This is a member of the Oracle.DataAccess.Types namespace.
Exceptions
Remarks
GetProviderSpecficFieldType returns a type that corresponds to the value the application obtains after invoking the GetProviderSpecificValue accessor on the OracleDataReader. For example, if the column is a string, this method returns a .NET Type object for an OracleString.
If the attribute is a UDT, this method may return any of the following:
A .NET Type of the custom type, if the column is an Oracle object or Oracle collection column and a custom type mapping exists.
A .NET Type of OracleRef if the column is an Oracle REF.
This method returns an object that represents the underlying provider-specific value of the specified ordinal.
Declaration
// C#
public override object GetProviderSpecificValue (int index);
Parameters
index
Return Value
An Object that is a representation of the underlying provider-specific field type.
Exceptions
InvalidOperationException - The connection is closed, the reader is closed, Read() has not been called or all rows have been read.
Remarks
If the column is an Oracle object or collection column, and a custom type mapping exists, a custom type is returned.
If the column is an Oracle REF column, an OracleRef is returned.
This method returns an array of objects that represent the underlying provider-specific values.
Declaration
// C#
public override int GetProviderSpecificValues(object [ ] values);
Parameters
values
An array of objects.
Return Value
The number of Object instances in the array.
Exceptions
This method returns a DataTable that describes the column metadata of the OracleDataReader.
Declaration
// C# public override DataTable GetSchemaTable();
Return Value
A DataTable that contains the metadata of the result set.
Implements
IDataReader
Exceptions
InvalidOperationException - The connection is closed or the reader is closed.
Remarks
The OracleDataReader.GetSchemaTable method returns the SchemaTable.
The OracleDataReader SchemaTable is a DataTable that describes the column metadata of the OracleDataReader.
The value of ColumnSize can show value up to 32K depending on the definition of VARCHAR2, NVARCHAR2, or RAW type columns in the table definition.
The columns of the SchemaTable are in the order shown.
Table 5-49 OracleDataReader SchemaTable
| Name | Name Type | Description |
The name of the column. |
The |
The maximum possible length of a value in the column.
See " |
The maximum precision of the column, if the column is a numeric data type. This column has valid values for Oracle |
The scale of the column. This column has valid values for Oracle |
Indicates whether or not the column is unique.
The default is The value of this property is the same for each occurrence of the base table column in the select list. |
Indicates whether or not the column is a key column.
This set of columns can be generated from one of the following in descending order of priority:
An explicitly selected |
The name of the column in the database if an alias is used for the column. |
The name of the schema in the database that contains the column. |
The name of the table or view in the database that contains the column. |
Maps to the common language runtime type. |
The database column type ( |
This value is always |
The type name of the UDT. |
An |
Example
This example creates and uses the SchemaTable from the reader.
hiredate DATE,
salary NUMBER(7,2),
byteCodes BLOB
commit;
// C#
using System;
using System.Data;
class GetSchemaTableSample
static void Main()
con.Open();
string cmdstr = "SELECT EMPNO,EMPNAME FROM EMPINFO where EMPNO = 1";
//get the reader
//get the schema table
DataTable schemaTable = reader.GetSchemaTable();
//retrieve the first column info.
DataRow row = schemaTable.Rows[0];
//print out the column info
Console.WriteLine("Column name: " + row["COLUMNNAME"]);
Console.WriteLine("Precision: " + row["NUMERICPRECISION"]);
Console.WriteLine("Scale: " + row["NUMERICSCALE"]);
reader.Close();
con.Close();
This method returns the string value of the specified column.
Declaration
// C#
public override string GetString(int index);
Parameters
index
Return Value
The string value of the column.
Implements
IDataRecord
Exceptions
Remarks
Call the IsDBNull method to check for null values before calling this method.
If the column is an Oracle REF column, the string returned is a hexadecimal string that represents the REF in the database.
This method returns the TimeSpan value of the specified INTERVAL DAY TO SECOND column.
Declaration
// C#
public TimeSpan GetTimeSpan(int index);
Parameters
index
Return Value
The TimeSpan value of the column.
Implements
IDataRecord
Exceptions
Remarks
This method returns the column value as a .NET type.
Declaration
// C#
public override object GetValue(int index);
Parameters
index
Return Value
The value of the column as a .NET type.
Implements
IDataRecord
Exceptions
InvalidOperationException - The connection is closed, the reader is closed, Read() has not been called, all rows have been read, or no valid custom type mapping has been specified for the Oracle Object or Oracle Collection column.
Remarks
If the column is an Oracle Object or an Oracle Collection column, the .NET custom type corresponding to the custom type mapping is returned.
If the column is an Oracle REF column, a hexidecimal value is returned as a .NET string that represents the REF in the database.
If the UDT is NULL, DBNull.Value is returned
This method gets all the column values as .NET types.
Declaration
// C#
public override int GetValues(object[ ] values);
Parameters
values
An array of objects to hold the .NET types as the column values.
Return Value
The number of objects in the values array.
Implements
IDataRecord
Exceptions
Remarks
This method returns the contents of an XMLType column as an instance of an .NET XmlTextReader object.
Declaration
// C#
public XmlReader GetXmlReader(int index);
Parameters
index
Return Value
A .NET XmlTextReader.
Exceptions
Remarks
This method indicates whether or not the column value is NULL.
Declaration
// C#
public override bool IsDBNull(int index);
Parameters
index
Return Value
Returns true if the column is a NULL value; otherwise, returns false.
Implements
IDataRecord
Exceptions
InvalidOperationException - The reader is closed, Read() has not been called, or all rows have been read.
Remarks
This method should be called to check for NULL values before calling the other accessor methods.
Example
The code example for the OracleDataReader class includes the IsDBNull method. See "Example".
This method advances the data reader to the next result set.
Declaration
// C# public override bool NextResult();
Return Value
Returns true if another result set exists; otherwise, returns false.
Implements
IDataReader
Exceptions
Remarks
NextResult is used when reading results from stored procedure execution that return more than one result set.
This method reads the next row in the result set.
Declaration
// C# public override bool Read();
Return Value
Returns true if another row exists; otherwise, returns false.
Implements
IDataReader
Exceptions
Remarks
The initial position of the data reader is before the first row. Therefore, the Read method must be called to fetch the first row. The row that was just read is considered the current row. If the OracleDataReader has no more rows to read, it returns false.
Example
The code example for the OracleDataReader class includes the Read method. See "Example".
