Skip Headers
Oracle® Data Provider for .NET Developer's Guide
12c Release 1 (12.1.0.1.0)
E41125-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleErrorCollection Class
An OracleErrorCollection class represents a collection of all errors that are thrown by the Oracle Data Provider for .NET.
Class Inheritance
System.Object
  System.ArrayList
    Oracle.DataAccess.Client.OracleErrorCollection
Declaration
// C#
public sealed class OracleErrorCollection : ArrayList
Requirements
Provider ODP.NET, Unmanaged Driver ODP.NET, Managed Driver
Assembly Oracle.DataAccess.dll Oracle.ManagedDataAccess.dll
Namespace Oracle.DataAccess.Client Oracle.ManagedDataAccess.Client
.NET Framework 2.0, 3.0, 3.5, 4.0, 4.5 4.0, 4.5
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Remarks
A simple ArrayList that holds a list of OracleErrors.
If there are multiple errors, ODP.NET only returns the first error message on the stack.
Example
// C#
using System;
using System.Data;
using Oracle.DataAccess.Client;
class OracleErrorCollectionSample
  static void Main()
    string constr = "User Id=scott;Password=tiger;Data Source=oracle";
    OracleConnection con = new OracleConnection(constr);
    con.Open();
    // Create an OracleCommand object using the connection object
    OracleCommand cmd = con.CreateCommand();
    try
      cmd.CommandText = "insert into notable values (99, 'MyText')";
      cmd.ExecuteNonQuery();
    catch (OracleException ex)
      Console.WriteLine("Record is not inserted into the database table.");
      foreach (OracleError error in ex.Errors)
        Console.WriteLine("Error Message: " + error.Message);
        Console.WriteLine("Error Source: " + error.Source);
OracleErrorCollection Members
OracleErrorCollection members are listed in the following tables.
OracleErrorCollection Static Methods
OracleErrorCollection static methods are listed in Table 5-56.
Table 5-56 OracleErrorCollection Static Methods
Method Description
Equals
Inherited from System.Object (Overloaded)
OracleErrorCollection Properties
OracleErrorCollection properties are listed in Table 5-57.
Table 5-57 OracleErrorCollection Properties
Property Description
Capacity
Inherited from System.Collections.ArrayList
Count
IsReadOnly
IsSynchronized
Item
OracleErrorCollection Public Methods
OracleErrorCollection public methods are listed in Table 5-58.
Table 5-58 OracleErrorCollection Public Methods
Public Method Description
CopyTo
Equals
GetHashCode
GetType
ToString
The OracleErrorCollection static method is listed in Table 5-59.
Table 5-59 OracleErrorCollection Static Method
Method Description
Equals
OracleErrorCollection properties are listed in Table 5-60.
Table 5-60 OracleErrorCollection Properties
Capacity
Count
IsReadOnly
IsSynchronized
Item
OracleErrorCollection public methods are listed in Table 5-61.
Table 5-61 OracleErrorCollection Public Methods
CopyTo
Equals
GetHashCode
GetType
ToString
