| Oracle® Data Provider for .NET Developer's Guide 12c Release 1 (12.1.0.1.0) E41125-02 |
![]() Previous |
![]() Next |
The OracleIntervalYM structure represents the Oracle INTERVAL YEAR TO MONTH data type to be stored in or retrieved from a database. Each OracleIntervalYM stores a period of time in years and months.
Class Inheritance
System.Object
System.ValueType
Oracle.DataAccess.Types.OracleIntervalYM
Declaration
// C# public struct OracleIntervalYM : IComparable
Requirements
| Provider | ODP.NET, Unmanaged Driver | ODP.NET, Managed Driver |
| Assembly | Oracle.DataAccess.dll |
Oracle.ManagedDataAccess.dll |
| Namespace | Oracle.DataAccess.Types |
Oracle.ManagedDataAccess.Types |
| .NET Framework | 2.0, 3.0, 3.5, 4.0, 4.5 | 4.0, 4.5 |
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
// C#
using System;
using Oracle.DataAccess.Types;
class OracleIntervalYMSample
static void Main()
OracleIntervalYM iYMMax = OracleIntervalYM.MaxValue;
double totalYears = iYMMax.TotalYears;
totalYears -= 1;
OracleIntervalYM iYMMax_1 = new OracleIntervalYM(totalYears);
// Calculate the difference
OracleIntervalYM iYMDiff = iYMMax - iYMMax_1;
// Prints "iYMDiff.ToString() = +000000001-00"
Console.WriteLine("iYMDiff.ToString() = " + iYMDiff.ToString());
OracleIntervalYM members are listed in the following tables:
OracleIntervalYM Constructors
OracleIntervalYM constructors are listed in Table 14-74
Table 14-74 OracleIntervalYM Constructors
| Constructor | Description |
Instantiates a new instance of |
OracleIntervalYM Static Fields
The OracleIntervalYM static fields are listed in Table 14-75.
Table 14-75 OracleIntervalYM Static Fields
| Field | Description |
Represents the maximum value for an |
Represents the minimum value for an |
Represents a null value that can be assigned to an |
Represents a zero value for an |
OracleIntervalYM Static Methods
The OracleIntervalYM static methods are listed in Table 14-76.
Table 14-76 OracleIntervalYM Static Methods
| Methods | Description |
Determines whether or not two |
Determines whether or not one |
Determines whether two |
Returns an |
Returns a new instance of an |
OracleIntervalYM Static Operators
The OracleIntervalYM static operators are listed in Table 14-77.
Table 14-77 OracleIntervalYM Static Operators
| Operator | Description |
Adds two |
Subtracts one |
Negates an |
Multiplies an |
Divides an |
OracleIntervalYM Type Conversions
The OracleIntervalYM conversions are listed in Table 14-78.
Table 14-78 OracleIntervalYM Type Conversions
Converts an |
Converts a string to an |
Converts the number of months to an |
OracleIntervalYM Properties
The OracleIntervalYM properties are listed in Table 14-79.
Table 14-79 OracleIntervalYM Properties
| Properties | Description |
Returns an array of bytes that represents the Oracle |
Indicates whether or not the current instance has a null value |
Gets the months component of an |
Returns the total number, in years, that represents the period of time in the current |
Specifies the total number of months that is stored in the |
Gets the years component of an |
OracleIntervalYM Methods
The OracleIntervalYM methods are listed in Table 14-80.
Table 14-80 OracleIntervalYM Methods
Compares the current |
Determines whether or not the specified |
Returns a hash code for the |
GetType |
Inherited from |
Converts the current |
The OracleIntervalYM constructors creates a new instance of the OracleIntervalYM structure.
Overload List:
This method creates a new instance of the OracleIntervalYM structure using the supplied total number of months for a period of time.
This method creates a new instance of the OracleIntervalYM structure and sets its value using the supplied string.
This method creates a new instance of the OracleIntervalYM structure and sets its value using the total number of years.
This method creates a new instance of the OracleIntervalYM structure and sets its value using years and months.
This method creates a new instance of the OracleIntervalYM structure and sets its value to the provided byte array, which is in an internal Oracle INTERVAL DAY TO SECOND format.
Declaration
// C#
public OracleIntervalYM (long totalMonths);
Parameters
totalMonths
The number of total months for a time interval. Range is -12,000,000,000 < totalMonths < 12,000,000,000.
Exceptions
ArgumentOutOfRangeException - The totalMonths parameter is out of the specified range.
Declaration
// C#
public OracleIntervalYM (string intervalStr);
Parameters
intervalStr
A string representing the Oracle INTERVAL YEAR TO MONTH.
Remarks
The value specified in the supplied intervalStr must be in Year-Month format.
Exceptions
ArgumentException - The intervalStr parameter is not in the valid format or intervalStr has an invalid value.
ArgumentNullException - The intervalStr parameter is null.
Example
"1-2" means 1 year and 2 months.
Declaration
// C#
public OracleIntervalYM (double totalYears);
Parameters
totalYears
Number of total years. Range is -1,000,000,000 < totalYears > 1,000,000,000.
Exceptions
ArgumentOutOfRangeException - The totalYears parameter is out of the specified range.
ArgumentException - The totalYears parameter cannot be used to construct a valid OracleIntervalYM.
Declaration
// C# public OracleIntervalYM (int years, int months);
Parameters
years
Number of years. Range of year is (-999,999,999 to 999,999,999).
months
Number of months. Range of month is (-11 to 11).
Remarks
The sign of all the arguments must be the same.
Exceptions
ArgumentOutOfRangeException - The argument value for one or more of the parameters is out of the specified range.
ArgumentException - The argument values of the parameters cannot be used to construct a valid OracleIntervalYM.
Declaration
// C#
public OracleIntervalYM (byte[] bytes);
Parameters
bytes
A byte array that is in an internal Oracle INTERVAL YEAR TO MONTH format.
Exceptions
ArgumentException - The supplied byte array is not in an internal Oracle INTERVAL YEAR TO MONTH format or the supplied byte array has an invalid value.
ArgumentNullException - bytes is null.
Remarks
The supplied byte array must be in an internal Oracle INTERVAL YEAR TO MONTH format.
The OracleIntervalYM static fields are listed in Table 14-81.
Table 14-81 OracleIntervalYM Static Fields
This static field represents the maximum value for an OracleIntervalYM structure.
Declaration
// C# public static readonly OracleIntervalYM MaxValue;
Remarks
Year is 999999999 and Month is 11.
This static field represents the minimum value for an OracleIntervalYM structure.
Declaration
// C# public static readonly OracleIntervalYM MinValue;
Remarks
Year is -999999999 and Month is -11.
This static field represents a null value that can be assigned to an OracleIntervalYM instance.
Declaration
// C# public static readonly OracleIntervalYM Null;
The OracleIntervalYM static methods are listed in Table 14-82.
Table 14-82 OracleIntervalYM Static Methods
Returns an |
This static method determines whether or not two OracleIntervalYM values are equal.
Declaration
// C# public static bool Equals(OracleIntervalYM val1, OracleIntervalYM val2);
Parameters
val1
An OracleIntervalYM structure.
val2
Return Value
Returns true if two OracleIntervalYM values represent the same time interval, otherwise, returns false.
Remarks
The following rules apply to the behavior of this method.
Any OracleIntervalYM that has a value compares greater than an OracleIntervalYM that has a null value.
Two OracleIntervalYMs that contain a null value are equal.
This static method determines whether or not the first of two OracleIntervalYM values is greater than the second.
Declaration
// C# public static bool GreaterThan(OracleIntervalYM val1, OracleIntervalYM val2);
Parameters
val1
The first OracleIntervalYM.
val2
The second OracleIntervalYM.
Return Value
Returns true if the first of two OracleIntervalYM values is greater than the second; otherwise, returns false.
Remarks
This static method determines whether or not the first of two OracleIntervalYM values is greater than or equal to the second.
Declaration
// C# public static bool GreaterThanOrEqual(OracleIntervalYM val1, OracleIntervalYM val2);
Parameters
val1
val2
Return Value
Returns true if the first of two OracleIntervalYM values is greater than or equal to the second; otherwise returns false.
Remarks
This static method determines whether or not the first of two OracleIntervalYM values is less than the second.
Declaration
// C# public static bool LessThan(OracleIntervalYM val1, OracleIntervalYM val2);
Parameters
val1
val2
Return Value
Returns true if the first of two OracleIntervalYM values is less than the second; otherwise, returns false.
Remarks
This static method determines whether or not the first of two OracleIntervalYM values is less than or equal to the second.
Declaration
// C# public static bool LessThanOrEqual(OracleIntervalYM val1, OracleIntervalYM val2);
Parameters
val1
val2
Return Value
Returns true if the first of two OracleIntervalYM values is less than or equal to the second. Returns false otherwise.
Remarks
This static method determines whether two OracleIntervalYM values are not equal.
Declaration
// C# public static bool NotEquals(OracleIntervalYM val1, OracleIntervalYM val2);
Parameters
val1
val2
Return Value
Returns true if two OracleIntervalYM values are not equal. Returns false otherwise.
Remarks
This static method returns an OracleIntervalYM structure and sets its value for time interval using a string.
Declaration
// C#
public static OracleIntervalYM Parse (string intervalStr);
Parameters
intervalStr
Return Value
Returns an OracleIntervalYM structure.
Exceptions
Remarks
The value specified in the supplied intervalStr must be in the Year-Month format.
Example
This static method returns a new instance of an OracleIntervalYM with the specified year precision.
Declaration
// C# public static OracleIntervalYM SetPrecision(OracleIntervalYM value1, int yearPrecision);
Parameters
value1
yearPrecision
The year precision provided. Range of year precision is (0 to 9).
Return Value
An OracleIntervalDS instance.
Exceptions
ArgumentOutOfRangeException - yearPrecision is out of the specified range.
Remarks
Depending on the value specified in the supplied yearPrecision, 0 or more leading zeros are displayed in the string returned by ToString().
Example
An OracleIntervalYM with a value of "1-2" results in the string "001-2" when SetPrecision() is called with the year precision set to 3.
The OracleIntervalYM static operators are listed in Table 14-83.
Table 14-83 OracleIntervalYM Static Operators
Adds two |
Subtracts one |
Negates an |
Multiplies an |
Divides an |
This static operator adds two OracleIntervalYM values.
Declaration
// C# public static OracleIntervalYM operator + (OracleIntervalYM val1, OracleIntervalYM val2);
Parameters
val1
val2
Return Value
OracleIntervalYM
Remarks
If either argument has a null value, the returned OracleIntervalYM structure has a null value.
This static operator determines if two OracleIntervalYM values are equal.
Declaration
// C# public static bool operator == (OracleIntervalYM val1, OracleIntervalYM val2);
Parameters
val1
val2
Return Value
Returns true if they are equal; otherwise returns false.
Remarks
This static operator determines if the first of two OracleIntervalYM values is greater than the second.
Declaration
// C# public static bool operator > (OracleIntervalYM val1, OracleIntervalYM val2);
Parameters
val1
val2
Return Value
Returns true if one OracleIntervalYM value is greater than another; otherwise, returns false.
Remarks
This static operator determines if the first of two OracleIntervalYM values is greater than or equal to the second.
Declaration
// C# public static bool operator >= (OracleIntervalYM val1, OracleIntervalYM val2);
Parameters
val1
val2
Return Value
Returns true if one OracleIntervalYM value is greater than or equal to another; otherwise, returns false.
Remarks
This static operator determines whether two OracleIntervalYM values are not equal.
Declaration
// C# public static bool operator != (OracleIntervalYM val1, OracleIntervalYM val2)
Parameters
val1
val2
Return Value
Returns true if two OracleIntervalYM values are not equal; otherwise, returns false.
Remarks
This static operator determines if the first of two OracleIntervalYM values is less than the second.
Declaration
// C# public static bool operator < (OracleIntervalYM val1, OracleIntervalYM val2);
Parameters
val1
val2
Return Value
Remarks
This static operator determines if the first of two OracleIntervalYM values is less than or equal to the second.
Declaration
// C# public static bool operator <= (OracleIntervalYM val1, OracleIntervalYM val2);
Parameters
val1
val2
Return Value
Returns true if the first of two OracleIntervalYM values is less than or equal to the second; otherwise, returns false.
Remarks
This static operator subtracts one OracleIntervalYM structure from another.
Declaration
// C# public static OracleIntervalYM operator - (OracleIntervalYM val1, OracleIntervalYM val2);
Parameters
val1
val2
Return Value
Remarks
This static operator negates an OracleIntervalYM structure.
Declaration
// C#
public static OracleIntervalYM operator - (OracleIntervalYM val);
Parameters
val
An OracleIntervalYM.
Return Value
Remarks
If the supplied OracleIntervalYM structure has a null value, the returned OracleIntervalYM structure has a null value.
This static operator multiplies an OracleIntervalYM value by a number.
Declaration
// C# public static OracleIntervalYM operator * (OracleIntervalYM val1, int multiplier);
Parameters
val1
multiplier
A multiplier.
Return Value
Remarks
This static operator divides an OracleIntervalYM value by a number.
Declaration
// C#
public static OracleIntervalYM operator / (OracleIntervalYM val1, int divisor);
Parameters
val1
divisor
A divisor.
Return Value
Remarks
The OracleIntervalYM conversions are listed in Table 14-84.
Table 14-84 OracleIntervalYM Type Conversions
Converts an |
This type conversion operator converts an OracleIntervalYM to a number that represents the number of months in the time interval.
Declaration
// C#
public static explicit operator long (OracleIntervalYM val);
Parameters
val
Return Value
A long number in months.
Exceptions
OracleNullValueException - The OracleIntervalYM structure has a null value.
This type conversion operator converts the string intervalStr to an OracleIntervalYM structure.
Declaration
// C#
public static explicit operator OracleIntervalYM (string intervalStr);
Parameters
intervalStr
A string representation of an Oracle INTERVAL YEAR TO MONTH.
Return Value
Exceptions
ArgumentException - The supplied intervalStr parameter is not in the correct format or has an invalid value.
Remarks
The returned OracleIntervalDS structure contains the same time interval represented by the supplied intervalStr. The value specified in the supplied intervalStr must be in Year-Month format.
This type conversion operator converts the total number of months as time interval to an OracleIntervalYM structure.
Declaration
// C#
public static implicit operator OracleIntervalYM (long months);
Parameters
months
The number of months to be converted. Range is (-999,999,999 * 12)-11 <= months <= (999,999,999 * 12)+11.
Return Value
Exceptions
ArgumentOutOfRangeException - The months parameter is out of the specified range.
The OracleIntervalYM properties are listed in Table 14-85.
Table 14-85 OracleIntervalYM Properties
This property returns an array of bytes that represents the Oracle INTERVAL YEAR TO MONTH in Oracle internal format.
Declaration
// C#
public byte[] BinData {get;}
Property Value
A byte array that represents an Oracle INTERVAL YEAR TO MONTH in Oracle internal format.
Exceptions
OracleNullValueException - The current instance has a null value.
This property indicates whether or not the value has a null value.
Declaration
// C#
public bool IsNull {get;}
Property Value
Returns true if value has a null value; otherwise, returns false.
This property gets the months component of an OracleIntervalYM.
Declaration
// C#
public int Months {get;}
Property Value
An int representing the months component.
Exceptions
This property returns the total number, in years, that represents the period of time in the current OracleIntervalYM structure.
Declaration
// C#
public double TotalYears {get;}
Property Value
A double representing the total number of years.
Exceptions
This property gets the total number of months that is stored in the OracleIntervalYM structure.
Declaration
// C#
public long Value {get;}
Property Value
The total number of months representing the time interval.
Exceptions
The OracleIntervalYM methods are listed in Table 14-86.
Table 14-86 OracleIntervalYM Methods
GetType |
Inherited from |
This method compares the current OracleIntervalYM instance to the supplied object, and returns an integer that represents their relative values.
Declaration
// C#
public int CompareTo(object obj);
Parameters
obj
The supplied object.
Return Value
The method returns a number:
Less than zero: if the current OracleIntervalYM represents a shorter time interval than obj.
Zero: if the current OracleIntervalYM and obj represent the same time interval.
Greater than zero: if the current OracleIntervalYM represents a longer time interval than obj.
Implements
IComparable
Exceptions
ArgumentException - The obj parameter is not of type OracleIntervalYM.
Remarks
The comparison must be between OracleIntervalYMs. For example, comparing an OracleIntervalYM instance with an OracleBinary instance is not allowed. When an OracleIntervalYM is compared with a different type, an ArgumentException is thrown.
Overrides Object
This method determines whether or not the specified object has the same time interval as the current instance.
Declaration
// C# public overridebool Equals(objectobj);
Parameters
obj
Return Value
Returns true if the specified object instance is of type OracleIntervalYM and has the same time interval; otherwise, returns false.
Remarks
Overrides Object
This method returns a hash code for the OracleIntervalYM instance.
Declaration
// C# public override int GetHashCode();
Return Value
An int representing a hash code.
Overrides Object
This method converts the current OracleIntervalYM structure to a string.
Declaration
// C# public override string ToString();
Return Value
A string that represents the current OracleIntervalYM structure.
Remarks
If the current instance has a null value, the returned string contain "null".
